menu selection
Results 1 to 7 of 7
Thread: menu selection
    May 2010
    Default lcd menu
    i have change the port and still the same...
    serin2 portc.7,84,[wait("z"),dta(0),DTA(1),DTA(2),DTA(3),DTA(4),DTA(5),DTA(6),DTA(7),DTA(8),dta(9),dta(10),dta(11),dta(12),DTA(13),DTA(14),DTA(15)]
    pause 50
    serout2 portc.5,16468,[dta(0),DTA(1),DTA(2),DTA(3),DTA(4),DTA(5),DTA(6),DTA(7),DTA(8),dta(9),dta(10),dta(11),dta(12),DTA(13),DTA(14),DTA(15),13]
    LCDOUT $FE,1,dta(0),DTA(1),DTA(2),DTA(3),DTA(4),DTA(5),DTA(6),DTA(7),DTA(8),dta(9),dta(10),dta(11),dta(12),DTA(13),DTA(14),DTA(15)
    Jun 2005
    Surrey, England
    [QUOTE=NURULHAIZA;90813]i have change the port and still the same...
    I am not sure that this was the answer to your question - the problem is that you are stuck in item 1 of your menu largely because you are polling your buttons for a few microseconds every 5 seconds - not much hope of happening to be pressing at the right time:
    if portB.1=1 then 'arrow down TAKES A FEW MICROSECONDS
    push = push+1 : goto selection : endif
    if portA.1=1 then 'arrow up
    push = push-1 : goto selection : endif
    pause 5000 'DO NOTHING FOR 5 SECONDS
    I suggest you have a much shorter pause (eg PAUSE 50) and it may be more responsive!
    Also it is not clear you have made portB.1 an input - I like to use
    INPUT portB.1
    but you could also use the TRIS register also
    Peter
    May 2010
    Unhappy menu selection
    guys i have tried everything that you told me...but it still the same....once the rx received data from tx and display it on LCD it will stop there and will not execute the other loop. do i need to change anything at tx?
    Let's try to debug this...
    Your code is running to here?
    TEMP:
    'SNIP
        LCDOUT $FE,$C0,dta(0),DTA(1),DTA(2),DTA(3),DTA(4),DTA(5),DTA(6),DTA(7),DTA(8),dta(9),dta(10),dta(11),dta(12),DTA(13),DTA(14),DTA(15)
    Then ends up here
    'ADD LED TO FLASH TO SEE IF IT IS HERE OR DISPLAY "AT MAIN" TO THE LCD
        pause 5000
    Then when you get here
    selection:
    "DISPLAY THE VALUE OF "push" TO THE LCD
        pause 200
        if push=1 then screen1
        if push=2 then screen2
        if push=3 then screen3
        if push=4 then screen4
        if push=5 then screen5
        if push=6 then screen6
        if push=7 then screen7
        if push=8 then screen8
        if push=9 then
            push = 1 : goto screen1 : endif
        if push=0 then
            push = 8 : goto screen8 : endif
    I have a sneaky suspicion you will need to use >= in place of =
    Does that make sense?
    Jun 2005
    Surrey, England
    Sorry to say but I have tested the menu selection on a simulator and if you change the pause to 50 it works fine (although I would have used a LOOKUP with BRANCHL), but leaving that aside, I suspect you have been naughty with your syntax - you define a word and then treat it like an array. A simple little test of:
    dta = 513
    dta1 = 514
    extra1 = 515
    extra2 =516
    LCDOUT dec dta(0), " ", dec dta(1), " ", dec DTA(2), " ", dec dta(3), " "
    gives this result:
    513 514 515 516
    indicating that
    dta(0) = dta
    dta(1) = the next defined variable etc
    quite unpredicable results - you must define an array and reference it with "square brackets" or better still with the STR expression. Eg:
    Buffer var byte[16]
    HSERIN 1000, tsync, [str Buffer\5]
    Peter
