dt int timer1 ignores offset value
Results 1 to 15 of 15
    Quote Originally Posted by DDDvvv View Post
    im aiming for 3840 hz, and thats = 64233 offset value.
    instead, im getting 3030 hz.
    What OSC are you running at?
    64233 would be close for 20Mhz.
    With 16Mhz OSC it would give 3.06 Khz.
    picmulticalc will not run in windows 7
    Turn on XP compatability mode for PicMultiCalc.
    Timer1 VAR WORD EXT ; what does the EXT stand for?
    The EXT (external) modifier.
    http://www.picbasic.co.uk/forum/showthread.php?t=3891
    Scroll down to ... Using EXT with Variables.
    Dec 2009
    Kalamazoo
    Smile
    thanks again for the reply. yes, i have the osc set for 16 mhz. there's my problem!
    about picmulticalc, it starts ok in windows 7 but when you click on any of the buttons (timer calc, timer helper, usart calc) i get a runtime error 713; missing msstdfmt.dll that needs to be installed. rather than troll the web searching for a "trojaned" file, i chose a different calc.
    thanks
    NAG CON WIFE!
    WIFE VAR MOOD
    FYI, I run PICMultiCalc on Win7-64bit without any problems, no compatibility mode set or anything.
    Me too. And I can not find msstdfmt.dll on my machine??
    Dec 2009
    Kalamazoo
    im using 32 bit windows 7. maybe thats the prob..
    NAG CON WIFE!
    WIFE VAR MOOD
    I also have win7 32 bit and no problems there either.
    Maybe you have a bad copy of multicalc?
    When I get back to the shop later to day I will upload the copy I have.
    DDDvvv,
    You can go here to get the version of MultiCalc that I have. Not sure if there is more than on version... This one works on win7, both 32 and 64 bit machines.
    http://mackrackit.cambs.net/files/
    Just saw your article on driving a stepper in hardware mode, missed that thread.
    Cool project!!! Now something else to play with that I do not have time for...
    Thanks!!!
