Compress Music being played by the Sound command
Results 1 to 4 of 4
    May 2010
    Default Compress Music being played by the Sound command
    Songs for the sound command take up much space compared to the memory available in 16f628a microcontrollers. Is there a way to compress them?
    Post
    Quote Originally Posted by IAmTheAnswer View Post
    I do not see how to "compress" some more the Data for the SOUND Command ...
    I had an eye to the .asm generated by your program ( RRWine), [ Humour ON ] and it looks that command is not exactly optimized for long plays ... [Humour OFF]
    you Also could use the 16F648 ... which is a '628 with twice the Program memory space ...
    Using a music dedicated chip ( say ISD 4xxx ) appears to be a much better solution ...
    Also see here ... :
    http: //www.aplusinc.com.tw
    Aug 2003
    What does you code look like?
    I never tried to make music with a pic, but my first thought is to use a lookup table full
    of frequencies and time lengths, and pass those to a single SOUND command routine.
    Now if you wanted to go further, time length values could probably be divided down to fit
    into 4 bits, and then expanded by the SOUND routine, so you could fit more than a singe value
    into each byte in the time length lookup table.
    It's all really difficult without seeing how you are playing music.
    Art.
    Mar 2006
    China
    Default Look here
    http://www.picbasic.co.uk/forum/content.php?r=213
    or use a SD-card and play wav-files from it then you have plenty of space
