18F4520 Configs
Results 1 to 9 of 9
Thread: 18F4520 Configs
    Thumbs up 18F4520 Configs
    Hi all,
    i've just read retepsnikrep' post about the 16F886 config and i have a similar question:
    Can anyone show me an example of the configs using MPASM for the 18F4520 ?
    I have tryed many different options but ended up with errors compiling.
    What are the parameters?
    In the meantime goto
    program files-microchip-mpasm suite
    there you will find an inc file for the chip. At the end of the file all of the config options are listed.
    Greetings mackrackit,
    I've looked in the folder you mentioned and the file is called P18F45K20.INC.
    I've looked inside the file and found the OSC ( _FOSC_HS_1H EQU H'F2' ; HS oscillator ) and MCLR ( _MCLRE_OFF_3H EQU H'7F' ; RE3 input pin enabled; MCLR disabled ) lines.
    However, i'm trying to place these into the code but i'm not being able to succeed.
    Tryed stuff like :
    @ __CONFIG _CONFIG1, _FOSC_HS_1H
    @ __CONFIG _CONFIG3H, _MCLRE_ON_3H
    but dont work
    Quote Originally Posted by ruijc View Post
    but dont work
    Hmm, not too much to go on here, but..
    Have you read the wiki here:
    http://www.picbasic.co.uk/forum/cont...o-your-Program ? Especially the end where it says don't forget.....
    Thanks scalerobotics,
    Got it working,
    just a quick question:
    The lines remarked in PBP's Inc file are default settings ? This means if i dont add the config lines in the code PBP will set these fuses by it self ( and by remarking them there will be no default settings ).
    Is this correct ?
    Is this correct ?
    Yes, you've got it. You can either edit it in PBP's inc files, and change it chip by chip. Or you can remark them out of PBP's inc files, and put them in your code for each project. They are the default settings. I usually copy them into my project, remark them out of PBP's inc file, and use them as a starting point.
    Glad you've got it working.
    Walter
