More than 8 Custom Chars on LCD?
Results 1 to 10 of 10
    Feb 2010
    USA, New England
    Default More than 8 Custom Chars on LCD?
    I'm using a standard garden-variety 2x16 LCD and a PIC18F2550. What I'd like to do is make a larger number font by putting the top half of the digit on the first line and the bottom half on the second line. Obviously, it would take a total of 20 special characters to to make all ten digits; the CGRAM only allows eight custom characters. I thought (incorrectly, as it turns out) I could re-use characters but instead it refreshes previous instances.
    Here's my testing code:
    ' PIC18F2550
    'Pin Assignments
    ' Pin	Name	           Use/Connection
    '  1  MCLR			Master Clear/Reset.  Pull High through 4.7k
    '  2  RA0/AN0		LCD RS
    '  3  RA1/AN1		LCD R/W
    '  4  RA2/AN2		LCD Enable
    '  5  RA3/AN3		n/c
    '  6  RA4/T0CKI		n/c
    '  7  RB5/AN4		n/c
    '  8  Vss			Ground
    '  9  OSC1			20 MHz resonator
    ' 10  OSC2			20 MHz resonator
    ' 11  RC0/T1CKI		To 32 kHz crystal
    ' 12  RC1/CCP2		To 32 kHz crystal
    ' 13  RC2/CCP1		n/c
    ' 14  Vusb			To USB (internal USB 3.3V voltage regulator)
    ' 15  RC4/D-		To USB (USB differential minus line)
    ' 16  RC5/D+		To USB (USB differential plus line)
    ' 17  RC6/TX		To MAX232
    ' 18  RC7/RX		To MAX232
    ' 19  Vss			Ground
    ' 20  Vdd			Voltage in (5V from USB)
    ' 21  RB0/INT		LCD DB0
    ' 22  RB1			LCD DB1
    ' 23  RB2			LCD DB2
    ' 24  RB3			LCD DB3
    ' 25  RB4			LCD DB4
    ' 26  RB5			LCD DB5
    ' 27  RB6			LCD DB6
    ' 28  RB7			LCD DB7
    ' Compiler directives:
    Define  OSC 20
    DEFINE LOADER_USED 1 'Bootloader Used
    'Set receive register to receiver enabled
    DEFINE HSER_RCSTA 90h
    'Set transmit register to transmitter enabled, high speed BRGH
    DEFINE HSER_TXSTA 24h
    'Set baud rate
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 3000
    DEFINE LCD_DATAUS 200
    ADCON1 = 15
    CMCON = 7
    TRISB = %00000000
    TRISA.0 = $0
    TRISA.1 = $0
    TRISA.2 = $0
    low PORTA.1
    'high PORTA.2
    LCDOUT $FE,1
    MAIN_LOOP:
    	'Big "1"
    	LCDOUT  $FE,$40,$00,$00,$04,$0C,$04,$04,$04,$04		' Cust Char #0, big "1" top half
    	LCDOUT  $FE,$48,$04,$04,$04,$04,$04,$0E,$00,$00		' Cust Char #1, big "1" bottom half
    	LCDOUT $FE,$80,0									' Put it as 1st line, 1st char
    	LCDOUT $FE,$C0,1 									' Put it as 2nd line, 1st char
    	'Big "2"
    	LCDOUT  $FE,$50,$00,$00,$0E,$11,$01,$01,$01,$02		' Cust Char #2, big "2" top half
    	LCDOUT  $FE,$58,$04,$08,$08,$10,$10,$1F,$00,$00		' Cust Char #3, big "2" bottom half
    	LCDOUT  $FE,$81,2									' Put it as 1st line, 2nd char
    	LCDOUT  $FE,$C1,3									' Put it as 2nd line, 2nd char
    	'Big "3"
    	LCDOUT  $FE,$60,$00,$00,$0E,$11,$01,$01,$01,$06		' Cust Char #4, big "3" top half
    	LCDOUT  $FE,$68,$01,$01,$01,$01,$11,$0E,$00,$00		' Cust Char #5, big "3" bottom half
    	LCDOUT  $FE,$82,4									' Put it as 1st line, 3rd char
    	LCDOUT  $FE,$C2,5									' Put it as 2nd line, 3rd char
    	'Big "4"
    	LCDOUT  $FE,$70,$00,$00,$06,$06,$0A,$0A,$12,$12		' Cust Char #6, big "4" top half
    	LCDOUT  $FE,$78,$12,$1F,$02,$02,$02,$02,$00,$00		' Cust Char #7, big "4" bottom half
    	LCDOUT  $FE,$83,6									' Put it as 1st line, 4th char
    	LCDOUT  $FE,$C3,7									' Put it as 2nd line, 4th char
    	pause 2000
    	'Big "5"
    	LCDOUT  $FE,$40,$00,$00,$1F,$10,$10,$10,$1E,$01		' Cust Char #0, big "5" top half
    	LCDOUT  $FE,$48,$00,$01,$01,$01,$11,$0E,$00,$00		' Cust Char #1, big "5" bottom half
    	LCDOUT  $FE,$84,0									' Put it as 1st line, 5th char
    	LCDOUT  $FE,$C4,1									' Put it as 2nd line, 5th char
    	'Big "6"
    	LCDOUT  $FE,$50,$00,$00,$06,$08,$08,$10,$1E,$11		' Cust Char #2, big "6" top half
    	LCDOUT  $FE,$58,$11,$11,$11,$11,$11,$0E,$00,$00		' Cust Char #3, big "6" bottom half
    	LCDOUT  $FE,$85,2									' Put it as 1st line, 6th char
    	LCDOUT  $FE,$C5,3									' Put it as 2nd line, 6th char
    	'Big "7"
    	LCDOUT  $FE,$60,$00,$00,$1F,$01,$01,$01,$01,$01		' Cust Char #4, big "7" top half
    	LCDOUT  $FE,$68,$02,$04,$04,$08,$08,$08,$00,$00		' Cust Char #5, big "7" bottom half
    	LCDOUT  $FE,$86,4									' Put it as 1st line, 7th char
    	LCDOUT  $FE,$C6,5									' Put it as 2nd line, 7th char
    	'Big "8"
    	LCDOUT  $FE,$70,$00,$00,$0E,$11,$11,$11,$11,$0E		' Cust Char #6, big "8" top half
    	LCDOUT  $FE,$78,$11,$11,$11,$11,$11,$0E,$00,$00		' Cust Char #7, big "8" bottom half
    	LCDOUT  $FE,$87,6									' Put it as 1st line, 8th char
    	LCDOUT  $FE,$C7,7									' Put it as 2nd line, 8th char
    	pause 2000
    goto MAIN_LOOP
    What I *thought* it should do is show "1234" in big numerals, pause, then show "12345678".
    Instead it shows "1234" then goes back and forth between "56785678" and "12341234".
    Is there a way to accomplish the goal of forcing the LCD to show the digits 0-9 with double height?
    Thanks for reading...8^)
    Paul
    Default Hope this helps
    Here is a link to Scott Edwards site: http://www.seetron.com/pdf/lcd_an1.pdf
    The code listed below was adapted by Darrel T. I think from the link I posted. I am sure you will find it somewhere in this forum but I neglected to add the URL to the code when I saved it.
    '*  Name    : BigNums.BAS                                       *
    '*  Author  : Scott Edwards, adapted by Darrel Taylor           *
    '*  Notice  : Copyright (c)                                     *
    '*  Date    : 2/20/07                                           *
    ;Initialize your hardware first
    'BIGNUMS.BS2 (Display four 1" digits on 4x20 display)
    ' Connect the serial input of a Backpack-equipped 4x20 display to
    ' BS2 pin P0 and run this program. The program will define a set
    ' of symbols that allow it to display 4-line-tall numerals on the
    ' LCD. To incorporate this capability into your own programs, just
    ' substitute your code for the demo loop. When you want to display
    ' a value (0-9999) in big numerals, write it to dispVal, then
    ' gosub bigLCD.
    I       con 254 ' Instruction prefix.
    ClrLCD  con 1 ' Clear-LCD instruction.
    N96N    con $4054 ' 9600 baud, inverted, no parity.
    cgRAM   con 64 ' Address 0 of CG RAM.
    EEptr   var word ' Pointer into EEPROM.
    pat     var EEptr ' Alias for EEptr.
    dispVal var word ' Value to be displayed as big digits.
    temp    var byte ' Temporary byte variable.
    decade  var word
    nbl     var byte ' Index into number-pattern tables.
    digit   var byte ' Current digit to display
    line    var byte ' LCD line
    LCDOUT I,ClrLCD
    PAUSE 500
    ' ====This section may be omitted with newer (post July 96)
    ' ====4x20 Serial LCD modules. Cut from here...============== >>>
    bitPat0 DATA 0,0,0,1,3,7,15,31 ' Left-right up-ramp shape.
    bitPat1 DATA 0,0,0,16,24,28,30,31 ' Right-left " "
    bitPat2 DATA 31,15,7,3,1,0,0,0 ' Left-right down ramp.
    bitPat3 DATA 31,30,28,24,16,0,0,0 ' Right-left " "
    bitPat4 DATA 0,0,0,0,31,31,31,31 ' Lower block.
    bitPat5 DATA 31,31,31,31,0,0,0,0 ' Upper block.
    bitPat6 DATA 31,31,31,31,31,31,31,31 ' Full block.
    bitPat7 DATA 0,0,0,0,0,0,0,0 ' Full blank
    ' <<<...to here. ===============================================
    ;low 0 ' Make the serial output low
    ;pause 1000 ' Let the LCD wake up.
    ' ====4x20 Serial LCD modules. Cut from here...============= >>>
    ;serout 0,N96N,[I,cgRAM] ' Enter CG RAM.
    LCDOUT I,cgRAM
    for EEptr = 0 to 63 ' Write the bit patterns
        Read EEptr,temp ' to the LCD.
    ;    serout 0,N96N,[temp]
        lcdout temp
    next
    ;serout 0,N96N,[I,ClrLCD] ' Clear the LCD.
    LCDOUT I, ClrLCD
    pause 1
    ' Demo Loop: Show dispVal in Big Numerals, Increment, Loop
    again:
        gosub bigLCD
        dispVal = dispVal + 1
    goto again
    ' Subroutine Displaying Large Numbers
    bigLCD:
        for line = 0 to 3
            decade = 1000
            lookup line,[128,192,148,212],temp
    ;        serout 0,N96N,[I,temp]
            LCDOUT I, temp
            for digit = 3 to 0 step -1
                nbl = dispVal dig digit
                gosub getPattern
                if dispVal = 0 and digit = 0 then skip0
                if dispVal < decade then blankIt
                skip0:
    ;            serout 0,N96N,[pat.nib3,pat.nib2,pat.nib1,pat.nib0]
                LCDOUT pat.Highbyte>>4, pat.Highbyte&$0F, pat.LowByte>>4, pat.Lowbyte&$0F
                goto cont
                blankIt:
    ;            serout 0,N96N,["    "]
                lcdout "    "
                cont:
                if digit = 0 then skip1
    ;            serout 0,N96N,[32]
                LCDOUT 32
                skip1:
                decade = decade/10
            next
        next
    ' Subroutines Defining Big-Character Patterns
    getPattern:
    branch line,[first,second,third,fourth]
    ' 0 1 2 3 4 5 6 7 8 9
    first:
    lookup2 nbl,[$0551,$7067,$0551,$0551,$6776,$6555,$0557,$2556,$0551,$0551],pat
    second:
    lookup2 nbl,[$6776,$7767,$7743,$7743,$6776,$2441,$6041,$7703,$2443,$6776],pat
    third:
    lookup2 nbl,[$6776,$7767,$0577,$7751,$2556,$7776,$6776,$7767,$0551,$2536],pat
    fourth:
    lookup2 nbl,[$2443,$7464,$6444,$2443,$7776,$2443,$2443,$7767,$2443,$7443],pat
    I very sincerely hope it has not gotten corrupted sometime after I saved it. As always I offer all statements to be opinions and not necessarly facts.
    EDIT: Here is a version from mister_e
    '*  Name    : Big_Num.BAS                                      *
    '*  Author  :                                         *
    '*  Notice  : Copyright (c) 2007                      *
    '*  Date    : 1/3/07                                            *
    '*  Notes   :Mister_e's big numbers for 16F877a                 *
    Define OSC 4
    DEFINE LCD_DREG PORTD     ' LCD data port
    DEFINE LCD_DBIT 4         ' LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTD    ' LCD register select port
    DEFINE LCD_RSBIT 2        ' LCD register select bit
    DEFINE LCD_EREG PORTD     ' LCD enable port
    DEFINE LCD_EBIT 3         ' LCD enable bit
    DEFINE LCD_BITS 4         ' LCD bus size 4 or 8
    DEFINE LCD_LINES 4        ' Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
    DEFINE LCD_DATAUS 50      ' Data delay time in us
        Clr     CON 1
        Comm    con $FE
        EOL     con $FC
        Dx      con $14
        Line    var byte[4]
            line[0]=$80
            line[1]=$C0
            line[2]=$94
            line[3]=$D4
        Zero    data 5,0,0,4,EOL
                data $FF,Comm,Dx,Comm,Dx,$FF,EOL
                data 2,1,1,3,EOL
                data 5
        One     data Comm,Dx,5,$ff,EOL
                data Comm,Dx,Comm,Dx,$ff,EOL
                data 5;3
        Two     data 0,0,0,4,EOL
                data Comm,Dx,Comm,Dx,Comm,Dx,$ff,EOL
                data 5,0,0,0,EOL
                data $ff,1,1,1,EOL
                data 5
        Three   data 0,0,0,4,EOL
                data Comm,Dx,0,0,$ff,EOL
                data 1,1,1,3,EOL
                data 5
        Four    data $ff,Comm,Dx,Comm,Dx,$FF,EOL
                data $ff,Comm,Dx,Comm,Dx,$ff,EOL
                data 0,0,0,$ff,EOL
                data 5
        Five    data $FF,0,0,0,EOL
                data $ff,EOL
                data 0,0,0,4,EOL
                data 1,1,1,3,EOL
                data 5
        Six     data 5,0,0,EOL
                data $ff,EOL
                data $ff,0,0,4,EOL
                data 2,1,1,3,EOL
                data 5
        Seven   data 0,0,0,4,EOL
                data Comm,Dx,Comm,Dx,comm,dx,$ff,EOL
                data 5
        Eight   data 5,0,0,4,EOL
                data 2,1,1,3,EOL
                data 5,0,0,4,EOL
                data 2,1,1,3,EOL
                data 5
        Nine    data 5,0,0,4,EOL
                data 2,1,1,$ff,EOL
                data Comm,Dx, Comm,Dx,Comm,Dx,$ff,EOL
                data Comm,Dx,1,1,3,EOL
                data 5
        Punto   data EOL
                data EOL
                data EOL
                data 7,EOL
                data 2
        offset      var byte
        index       var byte
        Char        var byte
        ActualLine  var byte
        CounterA    var word
        CounterB    var byte
        Number      var byte
        Pattern     var word[11]
            pattern[0]=zero
            pattern[1]=one
            Pattern[2]=two
            pattern[3]=three
            pattern[4]=four
            Pattern[5]=Five
            Pattern[6]=Six
            Pattern[7]=Seven
            pattern[8]=eight
            pattern[9]=Nine
            pattern[10]=Punto
    DumpCustChar:
        index=0
        repeat
            lookup index,[Comm,64,31,31,31,31,0,0,0,0,_      ; Cust Char #0
                          Comm,72,0,0,0,0,31,31,31,31,_      ; Cust Char #1
                          Comm,80,31,31,31,15,7,3,1,0,_      ; Cust Char #2
                          Comm,88,31,31,31,30,28,24,16,0,_   ; Cust Char #3
                          Comm,96,0,16,24,28,30,31,31,31,_   ; Cust Char #4
                          Comm,104,0,1,3,7,15,31,31,31,_     ; Cust Char #5
                          Comm,112,31,31,31,31,31,31,31,31,_ ; Cust Char #6
                          Comm,120,0,0,0,14,31,31,31,14],char; Cust Char #7
            lcdout char
            index=index+1
            until index=80
        countera=0
        repeat
            offset=0
            lcdout comm,clr
            counterb=3
            repeat
                number=countera dig counterb
                gosub displaynumber
                counterb=counterb-1
                until counterb=255
            pause 10
            countera=countera+1
            until countera=10000
    DisplayNumber:
        actualline=0
        index=0
        lcdout comm,line[0]+offset
        Loop:
            read pattern[number]+index,char
            if char!=eol then
                if actualline<4 then
                    lcdout char
                        offset=offset+char
                        Goto GetOut
                    actualline=actualline+1
                    if actualline<4 then lcdout comm,line[actualline]+offset
            index=index+1
            goto loop
        GetOut:
    Again I failed to save the URL.
    Bombay, India
    The answer is NO. Not more than 4 unique double height digits at a time. Optionally, use a graphic LCD.
    Aug 2003
    The double line high digits use a series of blocks that only consume the eight custom characters:
    http://www.doc.ic.ac.uk/~ih/doc/lcd/double.html
    so you can display as many digits as the display can show.
    You still couldn't make the font very detailed like you probably wanted to.
    Bombay, India
    Art, thanks for the link. I take back my words. I stand corrected.
    Feb 2010
    USA, New England
    Art,
    Thanks! That was *exactly* what I needed. Here's a (low-quality) picture of the result:
    Complete code:
    ' PIC18F2550
    'Pin Assignments
    '  2  RA0/AN0		LCD RS
    '  3  RA1/AN1		LCD R/W
    '  5  RA3/AN3		n/c
    '  6  RA4/T0CKI		n/c
    '  7  RB5/AN4		n/c
    '  8  Vss			Ground
    ' 13  RC2/CCP1		n/c
    ' 19  Vss			Ground
    ' 22  RB1			LCD DB1
    ' 23  RB2			LCD DB2
    ' 24  RB3			LCD DB3
    ' 25  RB4			LCD DB4
    ' 26  RB5			LCD DB5
    ' 27  RB6			LCD DB6
    ' 28  RB7			LCD DB7
    Define  OSC 20
    'Set baud rate
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    ADCON1 = 15
    CMCON = 7
    TRISB = %00000000
    TRISA.0 = $0
    TRISA.1 = $0
    TRISA.2 = $0
    nPos var byte
    low PORTA.1
    'high PORTA.2
    LCDOUT $FE,1
    'Set up the digits (http://www.darreltaylor.com/files/CustChar.htm)
    LCDOUT  $FE,$40,$01,$01,$01,$01,$01,$01,$01,$01  ' Cust Char #0
    'LCDOUT  $FE,$40,$02,$02,$02,$02,$02,$02,$02,$02  ' Cust Char #0
    LCDOUT  $FE,$48,$1F,$11,$11,$11,$11,$11,$11,$11  ' Cust Char #1
    LCDOUT  $FE,$50,$1F,$10,$10,$10,$10,$10,$10,$1F  ' Cust Char #2
    LCDOUT  $FE,$58,$01,$01,$01,$01,$01,$01,$01,$1F  ' Cust Char #3
    LCDOUT  $FE,$60,$1F,$11,$11,$11,$11,$11,$11,$1F  ' Cust Char #4
    LCDOUT  $FE,$68,$11,$11,$11,$11,$11,$11,$11,$1F  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$01,$01,$01,$01,$01,$01,$1F  ' Cust Char #6
    LCDOUT  $FE,$78,$1F,$01,$01,$01,$01,$01,$01,$01  ' Cust Char #7
    GOTO MAIN_LOOP
    Zero:
    	LCDOUT $FE,$80+nPos,1
    	LCDOUT $FE,$C0+nPos,5
    One:
    	LCDOUT $FE,$80+nPos,0
    	LCDOUT $FE,$C0+nPos,0
    Two:
    	LCDOUT $FE,$80+nPos,7
    	LCDOUT $FE,$C0+nPos,2
    Three:
    	LCDOUT $FE,$80+nPos,6
    	LCDOUT $FE,$C0+nPos,3
    Four:
    	LCDOUT $FE,$80+nPos,5
    Five:
    	LCDOUT $FE,$80+nPos,2
    Six:
    Seven:
    Eight:
    	LCDOUT $FE,$80+nPos,4
    Nine:
    MAIN_LOOP:
    	nPos = 0
    	GOSUB Zero
    	nPos = 1
    	GOSUB One
    	nPos = 2
    	GOSUB Two
    	nPos = 3
    	GOSUB Three
    	nPos = 4
    	GOSUB Four
    	nPos = 5
    	GOSUB Five
    	nPos = 6
    	GOSUB Six
    	nPos = 7
    	GOSUB Seven
    	nPos = 8
    	GOSUB Eight
    	nPos = 9
    	GOSUB Nine
    	PAUSE 2000
    GOTO MAIN_LOOP
    And thanks to everyone else for reading and commenting. You folks are the best...
    Best Regards,
    Paul
    Aug 2003
    Wow, it looks a lot nicer on the LCD than it did on the web page.
    Jun 2006
    And if we have a variable byte or word how to display?
    Feb 2010
    USA, New England
    Quote Originally Posted by savnik View Post
    Use the DIG function. The demo below counts up to 65534, showing each number for 25mS. It also blanks out any leading zeros.
    ' PIC18F2550
    'Pin Assignments
    '  2  RA0/AN0		LCD RS
    '  3  RA1/AN1		LCD R/W
    '  5  RA3/AN3		n/c
    '  6  RA4/T0CKI		n/c
    '  7  RB5/AN4		n/c
    '  8  Vss			Ground
    ' 13  RC2/CCP1		n/c
    ' 19  Vss			Ground
    ' 22  RB1			LCD DB1
    ' 23  RB2			LCD DB2
    ' 24  RB3			LCD DB3
    ' 25  RB4			LCD DB4
    ' 26  RB5			LCD DB5
    ' 27  RB6			LCD DB6
    ' 28  RB7			LCD DB7
    Define  OSC 20
    'Set baud rate
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1600'3000
    DEFINE LCD_DATAUS 50'200
    TRUE        	CON 1
    FALSE       	CON 0
    ADCON1 = 15
    CMCON = 7
    TRISB = %00000000
    TRISA.0 = $0
    TRISA.1 = $0
    TRISA.2 = $0
    nPos var byte
    wVal var WORD
    nDig var byte
    bDoneWithLeadingZeros var bit
    low PORTA.1
    'high PORTA.2
    LCDOUT $FE,1
    GOTO MAIN_LOOP
    Zero:
    One:
    Two:
    Three:
    Four:
    Five:
    Six:
    Seven:
    Eight:
    Nine:
    Blank:
    	LCDOUT $FE,$80+nPos," "
    	LCDOUT $FE,$C0+nPos," "
    PickDigit:
    	if nDig = 0 AND bDoneWithLeadingZeros = false then
    		gosub Blank
    'LCDOUT $FE,1
    		bDoneWithLeadingZeros = true
    		select case nDig
    		case 0
    			gosub Zero
    		case 1
    			gosub One
    		case 2
    			gosub Two
    		case 3
    			gosub Three
    		case 4
    			gosub Four
    		case 5
    			gosub Five
    		case 6
    			gosub Six
    		case 7
    			gosub Seven
    		case 8
    			gosub Eight
    		case 9
    			gosub Nine
    		end select
    MAIN_LOOP:
    	for wVal = 0 to $FFFE
    		bDoneWithLeadingZeros = FALSE
    		'Most significant digit
    		nPos = 0
    		nDig = wVal dig 4
    		Gosub PickDigit
    		nPos = 1
    		nDig = wVal dig 3
    		Gosub PickDigit
    		nPos = 2
    		nDig = wVal dig 2
    		Gosub PickDigit
    		nPos = 3
    		nDig = wVal dig 1
    		Gosub PickDigit
    		'Least significant digit
    		nPos = 4
    		nDig = wVal dig 0
    		Gosub PickDigit
    		pause 25
    	next wVal
    goto MAIN_LOOP
    Best Regards,
    Paul
    Jun 2006
    Thank you. I will try.
