I got it figured out. I needed to get my port bits and ANDING to coorelate correctly. I did have the CMCON and ANSEL set correctly. I am using a rotary binary switch with the common pulled to 5V and the port inputs pulled low w/ 1K resistors. OK, here is the code if anyone wants to peek. I am sure there are better ways, I just needed to know how to read the port. Thanks and take it easy, Scott
Code:CMCON = %00000111 ANSEL = %00000000 TRISA = %00111110 TRISC = %00000000 temp var byte digit var byte A var byte C var byte PORTA = %00000000 PORTC = %00000000 pause 1000 start: temp = PORTA & %00110110 if temp = 34 then digit = 9 if temp = 32 then digit = 8 if temp = 22 then digit = 7 if temp = 20 then digit = 6 if temp = 18 then digit = 5 if temp = 16 then digit = 4 if temp = 6 then digit = 3 if temp = 4 then digit = 2 if temp = 2 then digit = 1 if temp = 0 then digit = 0 lookup digit,[0,0,1,1,1,1,1,0,1,1],a lookup digit,[63,6,27,15,38,45,61,7,63,39],c PORTA = a PORTC = C PAUSE 50 goto start End
