Reassigning I/O within the program ?
Results 1 to 18 of 18
    Sep 2007
    USA, CA
    Ah, yes, I'd forgotten about the tris part.
    For what it is worth I also disagree. That almost sounds like the poster that says "I know my code is good so it has to be something else". 99% of the time the problem is the person on the keyboard. If you understand PBP and the understand the chip you are using PBP is very efficient.
    Regarding your (plural) responses here, then we will respectfully disagree. For there to be "efficient" code, there must be something "inefficient" to compare it to. If you were to compare it to asm, then PBP is horrendous--as most compilers are, if the asm author knows his head from a hole in the ground. So that point is moot. However, if you compare it to a similar compiler, say, Proton, then PBP still only gets a "B" grade, which in my opinion is inefficient. In almost every instance I have compared, PBP is a minimum of 10% less efficient than Proton. In some instances, I've saved noticeably more.
    The task in this simple topic here shows it:
    PBP:
    PinToChange        Var Byte
    NewPinState        Var bit
    pintochange = 4
    newpinstate = 1
    PORTB.0[PinToChange] = NewPinState
    pintochange = 2
    newpinstate = 0
    low PORTB.0
    end     '74 words used
    Proton:
    NewPinState        Var Bit
    pintochange = 4
    newpinstate = 1
    LoadBit PORTB, PinToChange, NewPinState
    pintochange = 2
    newpinstate = 0
    Low PORTB.0
    End     '67 words used
    Just on this simplest of examples, PBP takes up more than 10% extra code space.
    On top of that, I can actually EASILY see the generated asm code, and see where inefficiencies take place:
    PROTON#CODE#START
            ORG 0
            GOTO PROTON#MAIN#START
    A@BIT
            MOVWF 13
            ANDLW 248
            MOVWF 12
            RRF 12,F
            RRF 12,F
            RRF 12,W
            ADDWF 4,F
            CALL C@BT
            MOVWF 13
            ANDWF 0,W
            GOTO I@NT
    C2@FB
            MOVF 13,W
            SKPC
            CLRW
            XORWF 0,W
            ANDWF 13,W
            XORWF 0,F
            GOTO I@NT
    C@BT
            MOVLW (C@TBL >> 8)
            MOVWF 10
            MOVF 13,W
            ANDLW 7
            ADDWF 2,F
    C@TBL
            RETLW 1
            RETLW 2
            RETLW 4
            RETLW 8
            RETLW 16
            RETLW 32
            RETLW 64
            RETLW 128
    I@NT
            BCF 3,7
    I@NT2
            BCF 3,5
            BCF 3,6
    PROTON#MAIN#START
    F2_SOF EQU $ ; TEST.PRP
    F2_EOF EQU $ ; TEST.PRP
    F1_SOF EQU $ ; TEST.BAS
    F1_000012 EQU $ ; IN [TEST.BAS] PINTOCHANGE        VAR BYTE
    F1_000013 EQU $ ; IN [TEST.BAS] NEWPINSTATE        VAR BIT
    F1_000015 EQU $ ; IN [TEST.BAS] PINTOCHANGE = 4
            MOVLW 4
            MOVWF PINTOCHANGE
    F1_000016 EQU $ ; IN [TEST.BAS] NEWPINSTATE = 1
            BSF _B#VR1,0
    F1_000017 EQU $ ; IN [TEST.BAS] LOADBIT PORTB, PINTOCHANGE, NEWPINSTATE
            MOVLW PORTB
            MOVWF FSR
            MOVF PINTOCHANGE,W
            ADDLW 0
            CALL A@BIT
            BCF STATUS,0
            BTFSC _B#VR1,0
            BSF STATUS,0
            CALL C2@FB
    F1_000019 EQU $ ; IN [TEST.BAS] PINTOCHANGE = 2
            MOVLW 2
            MOVWF PINTOCHANGE
    F1_000020 EQU $ ; IN [TEST.BAS] NEWPINSTATE = 0
            BCF _B#VR1,0
    F1_000021 EQU $ ; IN [TEST.BAS] LOADBIT PORTB, PINTOCHANGE, NEWPINSTATE
            MOVLW PORTB
            MOVWF FSR
            MOVF PINTOCHANGE,W
            ADDLW 0
            CALL A@BIT
            BCF STATUS,0
            BTFSC _B#VR1,0
            BSF STATUS,0
            CALL C2@FB
    F1_000023 EQU $ ; IN [TEST.BAS] LOW PORTB.0
            BSF STATUS,5
    RAM_BANK = 1
            BCF TRISB,0
            BCF STATUS,5
    RAM_BANK = 0
            BCF PORTB,0
    F1_000024 EQU $ ; IN [TEST.BAS] END
    PB@LB2
            SLEEP
            GOTO PB@LB2
    F1_EOF EQU $ ; TEST.BAS
    PB@LB3
            GOTO PB@LB3
    If I find a bottleneck that I need to speed up, I can count the words right there. If I want, I can recode it in basic, or copy/paste the asm and edit with my own optimizations.
    See, my comments were directly related to the efficiency of the COMPILER. They had nothing to do with your coding or your abilities.
    Then why do you even bother with PBP? Just stick with Proton.
    Quote Originally Posted by tenaja View Post
    For the beniefit of those of us that don't use PROTON....
    And since you only gave the ASM generated by PROTON...
    Could you please explain the difference.
    Relative to PINS and ARRAY's. And the ASM generated by PBP?
    Sep 2007
    USA, CA
    Quote Originally Posted by mackrackit
    For the most part, I do. But I have PBP, and it's very similar to PDS in syntax (based on BS2), so I hang out here to learn and share.
    ASM code for PBP?
    	MOVE?CB	0C0h, ADCON0
    	MOVE?CB	004h, _PinToChange
    	MOVE?CT	001h, _NewPinState
    	AIN?TTB	_NewPinState, _PORTB??0, _PinToChange
    	MOVE?CB	002h, _PinToChange
    	MOVE?CT	000h, _NewPinState
    	LOW?T	_PORTB??0
    	END?
    Hardly indicative of the amount of code space used...
    You actually have to use the LST file. I'll post it later...
