Reassigning I/O within the program ?
Results 1 to 18 of 18
    Quote Originally Posted by tenaja View Post
    How in the world wout that READ a pin?
    With most PBP statements, you only have 3 options for the PIN's.
    It's usually described like this in the manual ...
    Pin may be a constant, 0-15, or a variable that contains a number 0-15 (e.g. B0) or a pin name (e.g. PORTA.0).
    But portb.0[myPIN] is an Array operation.
    The only one of the 3 options that fits an array result is "or a variable that contains a number 0-15".
    In order to know which PIN to use, it has to READ the variable, or in this case do the array operation (reading a PIN).
    Since it's a BIT array, it will only see a 1 or a 0.
    hth,
    Sep 2007
    USA, CA
    hth,
    Either we are miscommunicating, or they have changed the way bit arrays work, or you must be misunderstanding bit arrays. I have been using this method for 8 years:
    PORTB.0[PinToChange] = NewPinState
    The value for PinToChange can be any number 0 to7, and this allows you to use it on ANY PORT. The value for NewPinState must be 0 or 1.
    PORTA.0[4] = NewPinState
    PORTB.0[4] = NewPinState
    Will set PortA.4 AND PortB.4 to the NewPinState
    Obviously miscommunicating.
    In post #6 you originally said
    myPIN = 2 ...set this in your IF statements
    low portb.0[myPIN] ...allows you to use any port you like, and changing PICs is easy.
    In my reply I stated that portb.0[myPIN] = 1 will work, but it can't be used as a PIN in PBP statements like SERIN/OUT, PULSIN/OUT, RCTIME, HIGH/LOW, etc.
    LOW is a PBP statement with a PIN parameter.
    Sep 2007
    USA, CA
    Oops, well, I meant them to match.
    The second was pasted from a working file. I don't know why the syntax wouldn't work for a LOW, though.
    The point is, though, that there are ways to do it without the IFs. On the other hand, PBP is dreadfully inefficient, so it might be better to use the IFs anyway.
    ... I don't know why the syntax wouldn't work for a LOW, though.
    That's what I was trying to explain in post#9.
    If there's something in that post you don't understand, I'll try to go a little deeper.
    I completely disgree.
    There are many ways to be inefficient with PBP, but PBP itself is not the bottleneck.
    LOW sets the TRIS and an array can not be TRISed.
    For what it is worth I also disagree. That almost sounds like the poster that says "I know my code is good so it has to be something else". 99% of the time the problem is the person on the keyboard. If you understand PBP and the understand the chip you are using PBP is very efficient.
    Sep 2007
    USA, CA
    Ah, yes, I'd forgotten about the tris part.
    Regarding your (plural) responses here, then we will respectfully disagree. For there to be "efficient" code, there must be something "inefficient" to compare it to. If you were to compare it to asm, then PBP is horrendous--as most compilers are, if the asm author knows his head from a hole in the ground. So that point is moot. However, if you compare it to a similar compiler, say, Proton, then PBP still only gets a "B" grade, which in my opinion is inefficient. In almost every instance I have compared, PBP is a minimum of 10% less efficient than Proton. In some instances, I've saved noticeably more.
    The task in this simple topic here shows it:
    PBP:
    PinToChange        Var Byte
    NewPinState        Var bit
    pintochange = 4
    newpinstate = 1
    pintochange = 2
    newpinstate = 0
    low PORTB.0
    end     '74 words used
    Proton:
    NewPinState        Var Bit
    pintochange = 4
    newpinstate = 1
    LoadBit PORTB, PinToChange, NewPinState
    pintochange = 2
    newpinstate = 0
    Low PORTB.0
    End     '67 words used
    Just on this simplest of examples, PBP takes up more than 10% extra code space.
    On top of that, I can actually EASILY see the generated asm code, and see where inefficiencies take place:
    PROTON#CODE#START
            ORG 0
            GOTO PROTON#MAIN#START
    A@BIT
            MOVWF 13
            ANDLW 248
            MOVWF 12
            RRF 12,F
            RRF 12,F
            RRF 12,W
            ADDWF 4,F
            CALL C@BT
            MOVWF 13
            ANDWF 0,W
            GOTO I@NT
    C2@FB
            MOVF 13,W
            SKPC
            CLRW
            XORWF 0,W
            ANDWF 13,W
            XORWF 0,F
            GOTO I@NT
    C@BT
            MOVLW (C@TBL >> 8)
            MOVWF 10
            MOVF 13,W
            ANDLW 7
            ADDWF 2,F
    C@TBL
            RETLW 1
            RETLW 2
            RETLW 4
            RETLW 8
            RETLW 16
            RETLW 32
            RETLW 64
            RETLW 128
    I@NT
            BCF 3,7
    I@NT2
            BCF 3,5
            BCF 3,6
    PROTON#MAIN#START
    F2_SOF EQU $ ; TEST.PRP
    F2_EOF EQU $ ; TEST.PRP
    F1_SOF EQU $ ; TEST.BAS
    F1_000012 EQU $ ; IN [TEST.BAS] PINTOCHANGE        VAR BYTE
    F1_000013 EQU $ ; IN [TEST.BAS] NEWPINSTATE        VAR BIT
    F1_000015 EQU $ ; IN [TEST.BAS] PINTOCHANGE = 4
            MOVLW 4
            MOVWF PINTOCHANGE
    F1_000016 EQU $ ; IN [TEST.BAS] NEWPINSTATE = 1
            BSF _B#VR1,0
    F1_000017 EQU $ ; IN [TEST.BAS] LOADBIT PORTB, PINTOCHANGE, NEWPINSTATE
            MOVLW PORTB
            MOVWF FSR
            MOVF PINTOCHANGE,W
            ADDLW 0
            CALL A@BIT
            BCF STATUS,0
            BTFSC _B#VR1,0
            BSF STATUS,0
            CALL C2@FB
    F1_000019 EQU $ ; IN [TEST.BAS] PINTOCHANGE = 2
            MOVLW 2
            MOVWF PINTOCHANGE
    F1_000020 EQU $ ; IN [TEST.BAS] NEWPINSTATE = 0
            BCF _B#VR1,0
    F1_000021 EQU $ ; IN [TEST.BAS] LOADBIT PORTB, PINTOCHANGE, NEWPINSTATE
            MOVLW PORTB
            MOVWF FSR
            MOVF PINTOCHANGE,W
            ADDLW 0
            CALL A@BIT
            BCF STATUS,0
            BTFSC _B#VR1,0
            BSF STATUS,0
            CALL C2@FB
    F1_000023 EQU $ ; IN [TEST.BAS] LOW PORTB.0
            BSF STATUS,5
    RAM_BANK = 1
            BCF TRISB,0
            BCF STATUS,5
    RAM_BANK = 0
            BCF PORTB,0
    F1_000024 EQU $ ; IN [TEST.BAS] END
    PB@LB2
            SLEEP
            GOTO PB@LB2
    F1_EOF EQU $ ; TEST.BAS
    PB@LB3
            GOTO PB@LB3
    If I find a bottleneck that I need to speed up, I can count the words right there. If I want, I can recode it in basic, or copy/paste the asm and edit with my own optimizations.
    See, my comments were directly related to the efficiency of the COMPILER. They had nothing to do with your coding or your abilities.
