transceiver 433 MHz
Results 1 to 12 of 12
    france
    Default transceiver 433 MHz
    Hello
    I want a sample program in pbp, I want to send
    15 bytes by the bias of an RF module 433 MHz and receive
    On another module.
    thank you
    Have you searched the forum for examples? There a plenty out there.
    Can you send and receive the data with wires?
    france
    Default rf
    Hello
    I will test this way?
    touche VAR BYTE
    name0 var byte
    name1 var byte
    name2 var byte
    name3 var byte
    i var byte
    ID Var Byte
    envoi:
    SEROUT2 PORTA.3,T9600,["SYN",ID,name0,name1,name2,name3]
    GOTO debut
    reception:
    Serin2 PORTA.3,T9600,[wait("#SYN"),ID,name0,name1,name2,name3]
    GOTO debut
    Maybe without the "#" symbol on he SERIN command.
    france
    Default rf
    Hello
    Thank you for your help, do you have a sample program.
    I want to transmit and receive 24 bytes.
    thank you
    If your data are always 24, then use an array, load the date at the array elements and then send the array.
    I 'd use Hserout if my controller has hardware USART.
    Hserout [STR array\24]
    or
    SerOut2 port,mode,[STR array\24]
    france
    Default rf
    Hello
    Thank you for your help, what do you think of this program?
    Compteur Var Byte '
    TX_Donnee Var Byte[24] ' Donnee emission
    RC_ID Var Byte ' emission IDentificateur
    RX_Donnee Var Byte[24] ' Donnee reception
    Loop: ' emission
    For Compteur = 0 to 23 ' donnee
    TX_Donnee = Compteur ' Transfert de Compteur vers TX_Donnee
    Serout2 PortA.0,B2400,["#OK",RC_ID,TX_Donnee] ' envoie l'ID suivie des donnnees
    Pause 100 '
    Next
    Goto Loop
    Loop1: ' reception
    Serin2 PortA.1,B4800,[wait ("#OK"),RC_ID,RX_Donnee] ' attend reception l'ID
    if ID=32 THEN
    Goto Loop1 ' boucle
    Sorry but no!
    You lack basic knowledge of the lanquage syntax.
    I am sorry to say that, but you must read the PBP manual and test the commands before doing this.
    Just to help you going, arrays are accessed by their element position, e.g. TX_Donnee = Compteur is wrong and should be TX_Donnee[Compteur] = Compteur.
    You might want to verify your send/receive data rates as well.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    france
    Default rf
    Hello
    Thank you for your help, I'll try this way?
    j var byte
    datac Var Byte '
    Loop: ' emission
    ID=32 ' l'ID
    For J = 0 to 23 '
    TX_Donnee[J] = datac ' Transfert de datac vers TX_Donnee
    Serout2 PortA.0,B2400,["#OK",ID,TX_Donnee] ' envoie l'ID suivie des donnees
    Pause 100 '
    Next J
    Goto Loop
    Loop1: ' reception
    Serin2 PortA.1,B4800,[wait ("#OK"),ID,RX_Donnee] ' attend reception l'ID suivie des donnees
    if ID=32 THEN
    For j = 0 to 23 '
    datac[J] = RX_Donnee ' Transfert de datac vers TX_Donnee
    next j
    Goto Loop1 ' boucle
    No, you receive loop is wrong in the logic.
    Try this for the receive part:
    j=0
    While j<24' reception
        if ID=32 THEN
            j=j+1
    Wend					                        ' boucle
    france
    Default rf
    hello
    thank you for your help
