How to display many informations on 6 digits?
Results 1 to 11 of 11
    Apr 2010
    Default How to display many informations on 6 digits?
    Hello.
    You are right.
    But, how write a code?
    thanks
    Something like this:
    Counter VAR WORD
    Read1307:
      'code for reading time and date here....
    Counter = Counter + 1
    If Counter > 2000 then Counter = 0
    If Counter < 1000 Then GOSUB DisplayTime
    If Counter > 1000 Then GOSUB Display Date
    Goto Read1307
    DisplayTime:
      'code for time here
    DisplayDate:
      'code for date here
    Now have a go at it, if it doesn't work post your code and we'll have a look at it again.
    Dec 2008
    Ploiesti, ROMANIA
    Or something like this :
    citeste_RTC:
      I2CREAD SDA,SCL,$d1,$00,[STR DB0\8] ' Read 8 bytes from DS1307
    ore     = (db0[2] & $F )+((db0[2]>>4)*10) 'formula de conversie Hex to Dec pentru ore,hour
    minute  = (db0[1] & $F )+((db0[1]>>4)*10) 'formula de conversie Hex to Dec pentru minute,minutes
    Secunde = (db0[0] & $F )+((db0[0]>>4)*10) 'formula de conversie Hex to Dec pentru secunde,seconds
    if secunde = 15 or secunde = 30 or secunde = 45 then
        gosub afisare_data
        gosub afisare_ceas
    Zi      = (db0[4] & $F )+((db0[4]>>4)*10) 'formula de conversie Hex to Dec pentru zile,days
    Luna    = (db0[5] & $F )+((db0[5]>>4)*10) 'formula de conversie Hex to Dec pentru luni,months
    An      = (db0[6] & $F )+((db0[6]>>4)*10) 'formula de conversie Hex to Dec pentru ani,years
    anod1=0
    anod2=0
    Anod3=0
    Anod4=0
    anod5=0
    anod6=0
    goto citeste_rtc
    afisare_ceas:         'display clock
    Digit=secunde dig 1
    gosub convert
    PortC=pattern
    Anod5=1
    pause 1
    anod5=0
    digit=secunde dig 0
    gosub convert
    PortC=pattern
    Anod6=1
    pause 1
    anod6=0
    Digit=minute dig 1
    gosub convert
    PortC=pattern
    Anod3=1
    pause 1
    anod3=0
    Digit=Minute dig 0
    gosub convert
    PortC=pattern
    Anod4=1
    pause 1
    anod4=0
    digit=ore dig 1
    gosub convert
    PortC=pattern
    Anod1=1
    pause 1
    anod1=0
    digit=ore dig 0
    gosub convert
    PortC=pattern
    Anod2=1
    pause 1
    anod2=0
    afisare_data:    'afisare date
    Digit=zi dig 1
    gosub convert
    PortC=pattern
    Anod5=1
    pause 1
    anod5=0
    digit=zi dig 0
    gosub convert
    PortC=pattern
    Anod6=1
    pause 1
    anod6=0
    Digit=luna dig 1
    gosub convert
    PortC=pattern
    Anod3=1
    pause 1
    anod3=0
    Digit=luna dig 0
    gosub convert
    PortC=pattern
    Anod4=1
    pause 1
    anod4=0
    digit=an dig 1
    gosub convert
    PortC=pattern
    Anod1=1
    pause 1
    anod1=0
    digit=an dig 0
    gosub convert
    PortC=pattern
    Anod2=1
    pause 1
    anod2=0
    ;goto citeste_RTC
    convert:
    lookup digit, [$3F,$06,$5B,$4F,$66,$6D,$7D,$07,$7F,$6F],pattern
    pattern=pattern^$FF
    Apr 2010
    Default how to display many informations on 6 ditits?
    Hello. Sorry I did not reply, but I had some work. I managed to do something, and I put the code below. Thank you for your advice.
    '*  Name    : Ceas cu DS1307.BAS                                *
    '*  Author  : [Mihai POPA]                                      *
    '*  Notice  : Copyright (c) 2010 [Mihai]                        *
    '*  Date    : 5/31/2010                                         *
    '*  Version : 1.3                                               *
    '*  Notes   : Procesor PIC16F690                                *
    OSCCON = %1100100 'Oscilator 4 MHz
    ANSEL = 0         'A/D dezactivat
    ANSELH = 0        'A/D dezactivat
    TrisA = %00000000 'Setare intrare/iesire
    TrisB = %00000000 'Setare intrare/iesire
    TrisC = %00000000 'Setare intrare/iesire
    DP   var PortC.7   'punct zecimal, secundar
    Anod1 var PortB.4  'Anod1
    Anod2 var PortB.5  'Anod2
    Anod3 var PortB.6  'Anod3
    Anod4 var PortB.7  'Anod4
    Anod5 var PortA.0  'Anod5
    Anod6 var PortA.1  'Anod6
    Secunde var byte
    Minute  var byte
    Ore     var byte
    Zi      var byte   'Afiseaza zile
    Luna    var byte   'Afiseaza luni
    An      var byte   'Afiseaza ani
    Grup1 var byte
    Grup2 var byte
    Grup3 var byte
    Counter1 var byte
    Counter2 var byte
    counter1=1              'contor pentru afisare ceas
    counter2=1              'contor pentru afisare data
    Perioada var byte      'Perioada de timp cat sta afisata o informatie
    perioada=200           'valoarea initiala a perioadei de afisare
    Digit   var byte
    Pattern var byte
    'Set_minute var PortA.0 'Buton de setat minute
    'Set_ore    var PortA.1 'Buton de setat ore
    SCL var PortA.4     'SCL pentru RTC
    SDA var PortA.5     'SDA pentru RTC
    DB0 var byte[8]     'cuvantul receprionat de la RTC
    'setare_RTC:         'Setare data initiala:
      pause 1
      I2CWRITE SDA,SCL,$d0,$00,[$59,$59,$19,$7,$14,$2,$10,$90] ' Write to DS1307
      pause 10
    citeste_RTC:
    '   lcdout $fe,1,"Time=",hex2 DB0[2],":",hex2 DB0[1],":",hex2 DB0[0]    'bit 0=sec, bit 1=min, bit 2=hrs
    '   lcdout $fe,$c0,"Date=",hex2 DB0[4],":",hex2 DB0[5],":",hex2 db0[6]  'bit 4=day, bit 5=month, bit 6=year
    anod1=0
    anod2=0
    Anod3=0
    Anod4=0
    anod5=0
    anod6=0
    rutina_afisare_ceas_si_data:
    counter1=counter1+1                     'initializare contor
      if counter1
        grup1=secunde                       'daca nu a atins perioada, atunci
        grup2=minute                        'afiseaza ceasul
        grup3=ore
              if counter1=perioada  then    'daca contor1 a atins valoarea perioadei,
              counter2=counter2+1           'incrementeaza contor2
                 if counter2
                 grup1=an                   'daca nu a atins perioada, atunci
                 grup2=luna                 'afiseaza data
                 grup3=zi
              if counter2=perioada then     'verifica daca contor2 a atins perioada
            counter2=1                      'daca contor2 a atins perioada, atunci reseteaza contor2=1
            counter1=1                      'si contor1=1
    Digit=grup1 dig 1
    gosub convert
    PortC=pattern
    Anod5=1
    pause 1
    anod5=0
    digit=grup1 dig 0
    gosub convert
    PortC=pattern
    Anod6=1
    pause 1
    anod6=0
    Digit=grup2 dig 1
    gosub convert
    PortC=pattern
    Anod3=1
    pause 1
    anod3=0
    Digit=grup2 dig 0
    gosub convert
    PortC=pattern
    Anod4=1
    pause 1
    anod4=0
    digit=grup3 dig 1
    gosub convert
    PortC=pattern
    Anod1=1
    pause 1
    anod1=0
    digit=grup3 dig 0
    gosub convert
    PortC=pattern
    Anod2=1
    pause 1
    anod2=0
    goto citeste_RTC
    convert:
    pattern=pattern^$FF
    </perioada></perioada>
