If you are trying to tie together USB_ASM_Service and the routine I gave in this thread, it won't work as is.
CDC uses a different endpoint than HID.
Well, I managed to make it all work... possibly partially but so far so good!
I can send and receive 32 bytes packets. However as you said I may have not modofied everything which makes TX_Ready and RX_Ready non functional. However they are tied to USB registers and should not be dependent to endpoints if my understanding of the datasheet was correct...
I'm pasting here part of the main code that I used:
Code:INCLUDE "cdc_desc.bas" INCLUDE "EEPROM_detect.pbp" '******************************************************* 'Init the interrupt handling system '******************************************************* INCLUDE "DT_INTS-18.bas" ; Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler USB_INT, _DoUSBSERVICE, PBP, yes INT_Handler TMR1_INT, _TempCheck, PBP, Yes INT_Handler INT0_INT, _USBAttached, PBP, Yes endm INT_CREATE ; Creates the Low Priority interrupt processor ENDASM INCLUDE "USB_ASM_Service.pbp"
Well ok, but what does makes it incorrect?Last edited by Darrel Taylor; - 10th October 2010 at 16:56. Reason: Incorrect Mod
Ok, there's indeed something that relates to endpoint. I understand that you use two bytes located within the USB RAM space to get the TX and RX reports.
Now I'm clueless about what this refers to... tried to look at the hid_desc.pbp/asm code and compare it with cdc_desc.pbp/asm, and also to look on the net for RAM endpoint allocation at these two address but no luck so farBD1STATOUT = _USBMEMORYADDRESS + 8 ; 408h or 208h
BD1STATIN = _USBMEMORYADDRESS + 0Ch ; 40Ch or 20Ch
Follow up on the monologue, and after a day of digging through literature, I now have a slightly deeper understanding of the USB protocol. The more helpful was Microchip datasheet, within the USB section related to BDT RAM.
200h is start of USB RAM for PIC18F1xK50, 400h for 18Fx550/x455/x450.
I moved the allocations to Endpoint 3 for CDC usage:
Bit 7 of BDxSTAT states which device (SIE or CPU) owns the right to write or read into the dual ported USB RAM space, so this is what is used for the TX and RX ready flag.RXOWNED VAR BD3STATOUT.7 ; Out report Owned (OUT is PC to PIC)
TXOWNED VAR BD3STATIN.7 ; IN report Owned (IN is PIC to PC)
BD3STATOUT = _USBMEMORYADDRESS + 18h ; 418h or 218h
BD3STATIN = _USBMEMORYADDRESS + 1Ch ; 41Ch or 21Ch
For some reason the compiler doesn't like the 3 in "BD3STATOUT and BD3STATIN" (Bad data type error). CONFIGURED_STATE should not differs between HID or CDC as it is not endpoint dependent.
Ah thanks! that was just above, an easy fix.
RX_Ready seems to work! but TX_Ready is always true... maybe because the time when the OUT endpoint is owned by the SIE is so short that I can't see it? However if I do a loop that sends data as soon as the SIE is ready I have huge data loss.
Right now I have to add a 200ms delay between each 32Bytes packets I send in order to avoid data transmission loss. It is rather slow... reading a 24LC512 at this speed would take a bit less than 4h.
Am I missing something here?
