Thanks Darrel, I will play with this in a couple of days, it looks like this would do the trick.
What I really like in your DT_HID260 is that all USB dependent declaration are clearly listed within the program. I feel it is better and self-contained than digging cdc_desc.bas to modify the values, but maybe it works just the same at the end. I am now planning to use a bootloader as well, so I will have to check if two independent USB setup can be used one after the other without creating conflict.
