USBSERVICE + serout2 problem
Results 1 to 40 of 52
    Dec 2007
    Paris
    Simple enough, and worked great!
    May I ask what drives the USBSERVICE interrupt?
    Also I would like to use DT_INTS-18.bas in the program as well but I don't understand how to use the interrupt hook handler, and could not find any example of it.
    Take your time, there's no hurry, I can now spend some time to play with USB data transmission
    Thanks a lot for the great help.
    Dec 2007
    Paris
    Or... is there a way to turn DT_HID260 into a DT_CDC260? is there something I could use in the cdc_desc.bas file (contained in the USB demo folder) to do such thing or is it more complicated than transferring a series of values?
    The USB module itself generates many different interrupts.
    That is not possible with USB_ASM_Service.pbp.
    All interrupts used with the "Hook" can only be ASM (assembly language) type interrupts.
    No, but I could write a DT_CDC program. If I ever get my computers and internet access at home.
    Dec 2007
    Paris
    Ok, that was my understanding of the interrupt hook handler. Hmmm that will make things more difficult. A DT_CDC would be extremely helpful in my case, but that is a lot to ask...
    I will think about it, currently I have two different application, both that need to use the CDC profile (HID could work, but that would make programming more difficult on the computer side... also it is nice to use a terminal to drive the device without any dedicated software).
    One application needs Timer1 to do precise timing sampling, the second needs your multiple software PWM routine to drive 3 LEDs.
    aberco,
    Here's a little ditty that should get you going with servicing CDC and DT-INTS-18.
    Hope it helps.
    DEFINE OSC 48
    INCLUDE "cdc_desc.bas"
    ;--- Setup Interrupts ------------------------------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    INT_LIST  macro     ; IntSource,          Label,  Type, ResetFlag?
            INT_Handler     USB_INT,  _DoUSBSERVICE,   ASM,  yes
            INT_Handler     INT_INT,    _Handle_INT,   PBP,  yes
        INT_CREATE             ; Creates the Low Priority interrupt processor
        INT_ENABLE  USB_INT
        INT_ENABLE  INT_INT
    ;----[Initialise USB and Interrupts]----------------------------------------
        PAUSE 100                    ; Allow VUSB to stabilize
        USBINIT                      ; initialize the USB driver
        USBSERVICE                   ; service it once
        UIE = $7F                    ; enable USB interrupts
        UEIE = $9F                   ; enable USB Error interrupts
    ;----[Main program loop]----------------------------------------------------
        ; some code here
    GOTO Main
    ;----[Interrupt handler -- Service USB]-------------------------------------
    DoUSBSERVICE:
          USBSERVICE                   ; Run the SERVICE routines
    @ INT_RETURN
    ;----[Interrupt handler -- INT]
    Handle_INT:
     ; something here
    @ INT_RETURN
    Dec 2007
    Paris
    Thanks Darrel, I will play with this in a couple of days, it looks like this would do the trick.
    What I really like in your DT_HID260 is that all USB dependent declaration are clearly listed within the program. I feel it is better and self-contained than digging cdc_desc.bas to modify the values, but maybe it works just the same at the end. I am now planning to use a bootloader as well, so I will have to check if two independent USB setup can be used one after the other without creating conflict.
    Dec 2007
    Paris
    Well I must say that I'm still banging my head against USB CDC... I've tried this, the led does blink for 1 1/2 cycles and everything hangs and the pic does not enumerate.
    Now, is it because USB is serviced before the device is attached?
    I changed the interrupt from "ASM" to "PBP" (USBSERVICE is a PBP instruction).
    'Config fuses for PIC18LF14K50
    CONFIG CPUDIV=NOCLKDIV ; CPU runing at full speed
    CONFIG USBDIV=OFF ; Low speed USB clock diviser disabled, not used here
    CONFIG FOSC=HS ; Use of High Speed crystal oscillator
    CONFIG PLLEN=ON ; Enable PLL multiplier, 12Mhz oscilator x 4
    CONFIG PCLKEN=ON ; Primary clock source is enabled
    CONFIG FCMEN=OFF ; Failsafe clock off
    CONFIG IESO=OFF ; Oscillator switchover mode disabled
    CONFIG WDTEN=ON ; Watchdog timer on
    CONFIG WDTPS=512 ; Watchdog divider is 512
    CONFIG MCLRE=OFF ; Disable MCLR pin, enable RC3
    CONFIG STVREN=ON ; Stack full/underflow will cause reset
    CONFIG LVP=OFF ; Low voltage programming disabled
    CONFIG BBSIZ=OFF ; 512kW block boot size
    CONFIG XINST=OFF ; Extended instruction mode disabled
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    'Init for PIC18LF14K50
    'Set ADC pins to digital operation
    ADCON0 = %00000000 'turn ADC OFF
    CM1CON0 = %00000000 'disabling comparator module 1
    CM2CON0 = %00000000 'disabling comparator module 2
    'Define pin function
    TRISA = %00000000 'PortA all digital output
    TRISB = %00000000 'PortB all digital output
    TRISC = %00000000 'PortC all digital output
    ANSEL = %00000000 'Disable analog input all pins
    ANSELH = %00000000 'Disable analog input all pins
    RedLED VAR PORTC.3
            INT_Handler     USB_INT,  _DoUSBSERVICE,   PBP,  yes
        INT_ENABLE  USB_INT
    HIGH RedLED
    PAUSE 200
    LOW REDLED
    PAUSE 200
    GOTO MAIN
    DoUSBSERVICE:
    @ INT_RETURN
