aberco,
Here's a little ditty that should get you going with servicing CDC and DT-INTS-18.
Hope it helps.
DEFINE OSC 48
INCLUDE "cdc_desc.bas"
;--- Setup Interrupts ------------------------------------------------------
INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
INT_LIST  macro     ; IntSource,          Label,  Type, ResetFlag?
        INT_Handler     USB_INT,  _DoUSBSERVICE,   ASM,  yes
        INT_Handler     INT_INT,    _Handle_INT,   PBP,  yes
    INT_CREATE             ; Creates the Low Priority interrupt processor
    INT_ENABLE  USB_INT
    INT_ENABLE  INT_INT
;----[Initialise USB and Interrupts]----------------------------------------
    PAUSE 100                    ; Allow VUSB to stabilize
    USBINIT                      ; initialize the USB driver
    USBSERVICE                   ; service it once
    UIE = $7F                    ; enable USB interrupts
    UEIE = $9F                   ; enable USB Error interrupts
;----[Main program loop]----------------------------------------------------
    ; some code here
GOTO Main
;----[Interrupt handler -- Service USB]-------------------------------------
DoUSBSERVICE:
      USBSERVICE                   ; Run the SERVICE routines
@ INT_RETURN
;----[Interrupt handler -- INT]
Handle_INT:
 ; something here
@ INT_RETURN
