16F88 + 2 Analog inputs
Results 1 to 9 of 9
    Exclamation 16F88 + 2 Analog inputs
    Hi all,
    I'm having some issues reading 2 analog voltages with Pic 16F88.
    I have successfully make it work with only AN0, but when using 2 or more ports just doesn't want to work. Something is missing and i cant see it.
    The hardware is simple:
    Pic has only 3 connections ( output to RS232 and 2 analog inputs ). I have a 330K resistor from VDD to AN0 and a 47K resistor from VDD to AN1.
    Measuring voltage on these 2 pins i have AN0 = 1.19V and AN1=4.82V
    If my math is correct i should have readings like AN0= 244 and AN1=986 ( 10Bits calculation ).
    Instead i have AN0= 1011 and AN1=1014 ( most of the times both reading are the same ).
    Here's the code:
    [code]
    'DEFINEs
    @ DEVICE PIC16F88, INTRC_OSC_NOCLKOUT
    @ DEVICE PIC16F88, MCLR_OFF
    @ DEVICE PIC16F88, PROTECT_OFF
    DEFINE OSC 8
    @ DEVICE PIC16F88, CPD_OFF
    @ DEVICE PIC16F88, LVP_OFF
    @ DEVICE PIC16F88, BOD_OFF
    @ DEVICE PIC16F88, PWRT_OFF
    @ DEVICE PIC16F88, WDT_OFF
    @ DEVICE PIC16F88, CCPMX_OFF
    @ DEVICE PIC16F88, FCMEN_OFF
    @ DEVICE PIC16F88, IESO_OFF
    @ DEVICE PIC16F88, DEBUG_OFF
    OSCTUNE=0
    OSCCON = %01111110
    INTCON = 0
    PIE1 = 0
    PIE2 = 0
    CMCON = %00001111 'comparators off
    CVRCON = 0
    CCP1CON = 0
    'ADC
    DEFINE ADC_BITS 10 ' Set number of bits in result ( 8 or 10 bits )
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    'ADC parameters
    ADCON0 = %11000000 ' clock source
    ANSEL =%00000011 ' Porta.1 and .2 used by ADC
    ADCON1 =%10000011 ' Right justify
    INCLUDE "modedefs.bas"
    DEFINE DEBUG_REG PORTA
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 1
    ' variables
    loop VAR WORD
    som VAR WORD
    luz VAR WORD
    vals VAR WORD
    vall VAR WORD
    A VAR word
    B VAR word
    PORTA=0
    PORTB=0
    TRISA=%10110111
    TRISB=%11000100
    'PINS
    Si var PORTA.0 'input1
    Li var PORTA.1 'input2
    a2 var PORTA.2 'nc
    com var PORTA.3 'RS232
    A4 var PORTA.4 'nc
    MCLR var PORTA.5 'MCLR
    A6 var PORTA.6 'nc
    A7 var PORTA.7 'nc
    B0 var PORTB.0 'nc
    b1 var PORTB.1 'nc
    But var PORTB.2 'Button
    B3 var PORTB.3 'nc
    b4 var PORTB.4 'nc
    Led var PORTB.5 'Led
    PGC var PORTB.6 'PGC
    PGD var PORTB.7 'PGD
    clear
    INIT:
    high led
    pause 50
    debug "Starting...",13,10
    debug $0D, $0A
    PAUSE 50
    for loop=0 to 7
    toggle led
    next
    pause 1500
    start:
    gosub s1
    gosub s2
    gosub out
    goto start
    S2:
    ADCON0 = %11001000
    luz=0
    vall=0
    for loop=0 to 15
    adcin PORTA.1,vall
    pause 80
    luz=luz+vall
    next
    luz=luz/16
    S1:
    ADCON0 = %11000000
    som=0
    vals=0
    for loop=0 to 15
    adcin PORTA.0,vals
    pause 80
    som=som+vals
    next
    som=som/16
    out:
    debug 13,10
    debug "AN0 = ",dec som,13,10
    debug 13,10
    debug "AN1 = ",dec luz,13,10
    debug 13,10
    debug 13,10
    debug 13,10
    [\code]
    Any help would be appreciated
    Sep 2007
    USA, CA
    adcin PORTA.1,vall
    This is a syntax error that compiles.
    You need to use the analog CHANNEL number, NOT the port PIN number.
    The hex value of PORTA is $05. Setting the bit to .0, .1, or .3 might set it to 0 or 1, but no matter what Port pin you use, you will never get a port number greater than 1 if you are using a bit value.
    The hex value of analog channel 0 (AN0) is 0, and that's what you need to be using. It may have helped to read the HELP file:
    ADCIN 0, B0 ' Read channel 0 to B0
    So the hex values are valid to compile, but when they are placed into the ANSEL register, you don't get the results you were expecting.
    Bottom line: Use the channel number, which is the "x" value of the ANx number on the pin diagrams. This is pretty simple had you looked at the HELP file.
    Have fun!
    Hi tenaja,
    Actually i use always the name given in the pinout definition:
    My code has changed alot after some experiments and some reading.
    Unfortunately changing to ADCin 0 or ADCin Si does not change the readings.
    Still not working
    Using an alias to a port + pin is fine for some operations, but what tenaja told you is 100% correct. You cannot use anything except ADCIN 0,VAR - or ADCIN 1,VAR, etc.
    The 0,1,2,3,4, etc immediately after the ADCIN command is a constant. Not an alias to a PORT + PIN. This should be fairly clear by simply reading the manual, and looking at the example provided - or searching this forum for ADCIN examples.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2007
    USA, CA
    You are still using the incorrect syntax. You need to use numbers 0 through 6 (since your pic has 7 channels), or symbols representing those numbers, not PORT numbers. If it works with a Portx, then it's just coincidence and this bad practice will come back to bite you. You could easily be reading some pin other than the one you want. READ THE MANUAL.
    Second, I just read about your resistor connections:
    This is the reason you are getting high values instead of low values. Either you misrepresented your circuit, or you do not understand resistor networks.
    For starters, the datasheet says you need 10k max to ground--see section 12.1 of the datasheet--it's in BOLD in the first paragraph! You don't mention any R's to ground, and the values you do mention are way out of spec. If that's he case & you don't have a resistor going to ground, then you should theoretically have VDD volts at both a/d ports--and that explains your readings near 1024. If you do have an R to ground in a similar high K range, you could easily be getting an unreliable value due to the high impedance.
    Toss in those extra two resistors, fix your channel numbers, and you are good to go.
    Hi Tenaja and Bruce
    Thanks for your support.
    About the pin calling its noted
    But Tenaja was also right about the input impedance.
    The circuit was missing the pulldown resistors.
    I checked the datasheet and it's confusing for me that in bold it states the max impedance for analog sources is 2.5K and at the bottom square states the max impedance for analog sources is 10K. Which should we follow ?
    Sep 2007
    USA, CA
    Page 117 it states 10k in two places; text and notes. Page 190 says 2.5 with a NOTE, that says 10k is allowable with an increased acquisition time. That basically means extra time to charge the sampling cap. If you plug your numbers into equation 12-1 on pg. 117 you will get the appropriate time required. IIRC, the fastest it can go is around 30-35kHz, so with a 10k R, you'll have to slow it down to be reliable.
    However, if you don't need 10bit accuracy, it probably doesn't matter.
