Not sure if this will work but it compiles with PBP.
square brackets in the serout command are used in place of ()
This is the TX code. Should be able to do the same with the RX..
Code:INCLUDE "modedefs.bas" B0 var BYTE B1 VAR BYTE trisb = 134 trisa = 133 portb = 6 porta = 5 low 1 input 0 input 2 start: pot 0,50,B0 pot 2,50,B1 B0 = B0 * 5 B1 = B1 * 5 y: if B0 < 100 then yf if B0 > 150 then yb x: if B1 < 100 then xr if B1 > 150 then xl serout 1,n9600,[5] goto start yf: serout 1,n9600,[2] goto start yb: serout 1,n9600,[1] goto start xl: serout 1,n9600,[3] goto start xr: serout 1,n9600,[4] goto start end
