do you still have your code ?!?
@Mister_e,
I give you here the code. It is changed a lot of time but it is the last one which I used and by this program button is working a little bit for instance after 1-2 minutes it is making on and again 2-3 minutes later it making off also.
OPTION_REG.7=1
@ DEVICE pic16F628
@ DEVICE pic16F628, WDT_ON
@ DEVICE pic16F628, PWRT_ON
@ DEVICE pic16F628, PROTECT_OFF
@ DEVICE pic16F628, MCLR_OFF
@ DEVICE pic16F628, INTRC_OSC_NOCLKOUT
'---------------------------Variab..------------------------------
AL VAR BYTE
TOPLAM var byte
KOMBI VAR BYTE
GIRIS VAR PORTB.0
ROLE VAR PORTA.1
TUS var PORTA.6
LED VAR PORTB.3
YANDI VAR byte
SONDU VAR Byte
I VAR BYTE
'-----------------------------MAIN ---------------------------
CMCON=7
CLEAR:TRISA=%01100000
TRISB=%00000011
PAUSE 500:AL=88:sondu=0:KOMBI=0:LOW LED
START:
BUTTON TUS,0,200,5,I,1,BAK
SerIn2 GIRIS,1646,10,ATLA,[WAIT ("ER"),AL]
ATLA:
IF AL=88 THEN
IF SONDU=1 THEN ARA 'if already off then ara
GOSUB SON 'gosub off
GOTO START
IF AL=66 THEN
IF YANDI=1 THEN ARA 'if already on then ara
GOSUB YAN 'gosub on
GOTO START
pause 1
ARA: GOTO START
'--------------------if button is pushed -------------------------
BAK: IF KOMBI=1 THEN 'if already on then gosub offf
GOSUB SON
AL=88
GOTO START
GOSUB YAN 'it is already off then gosub on
AL=66
GOTO START
YAN: '------------------on section-------------------
KOMBI=1
YANDI=1:SONDU=0
HIGH ROLE
HIGH LED
pause 1
SON: '-----------------off section---------------------
LOW LED:KOMBI=0
SONDU=1:YANDI=0
LOW ROLE
pause 1
some things can cause this. Let's look this snip
You exit several time from a IF THEN and/or a nested IF THEN ELSE with a goto... not a good practice. You probably overflow the stack pointer.Code:IF AL=88 THEN IF SONDU=1 THEN ARA 'if already off then ara GOSUB SON 'gosub off GOTO START ENDIF
as i read SONDU will be 0 or 1 so
about the BUTTON statement... i'm not a fan of this statement. i'll prefer do 2-3 lines myself.Code:ReturnToStart var Bit Start: ReturnToStart = 0 IF AL=88 THEN IF SONDU=0 THEN GOSUB SON 'gosub off endif ReturnToStart = 1 ENDIF if ReturnToStart then GotoStart
Let's say i want to monitor a pushButon on PORTA.1
Code:TRISA.1=1 PushButton VAR PORTA.1 start: If PushButton then ' Pushbutton active While PushButton ' wait untill it's release Wend Pause 50 ' debounce time Gosub XYZ endif
Dear Steve,
Thank you for the tricks. You right I checked the program again and I saw that there are a lot of cunfusions. It was working but as you have said the reason can be the stack due to that cınfusions.Anyhow, I changed the program to make one loop only. I taken out all the zig-zags in the program. I did not yet tried. I was busy. I will try it within two days and let you know the result.
It would be good idea if I can check the program with one debugger. It is a pity that I have not mcs plus. By the way I would see where the program was going without touching the button command.
Thanks again
ERO
Steve,
Yesterday evening, I tested all the possibilities again after I made a new program which is only one loop. It was checking the button first after it was passing to SERIN2 command and passing to control what was arrived by SERIN2. Anyhow I have to tell you that the serin or serin2 command does not work with any button control. I tested all the timeout figures starting from 2 ms up to 2000 ms. I am sure there is a bug in the compiler.
I tested again the HSERIN command by making some changing on the pcb and I saw that it is working very well. Today I will change all the PCB and the program for working with HSERIN command.
I wanted to give you again the result of my work which can be intersting for other people.
Thanks again for your helps.
Ero
