Artcile on IR distance measurement
Results 1 to 17 of 17
    For liquids you mayuse Ultrasonics too.
    Sonar would be a lot better option if you're trying to determine distance between the waters surface and sensor.
    A really cheap option is to attach a float to a shaft, and attach the other end of the shaft to a potentiometer. Water level can be determined by an A/D reading from the pot.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sure, Ioannis, Bruce, sonar would be great. But I'm apprehensive about the longevity of the sensor in the damp humid ambiance this application is likely to subject the sensor to.
    Actually, I'd started a thread some time back specifically to do with measuring the level of water in a container.
    A lot of great suggestions got thrown in. I'm afraid this thread is turning out to be an extension of that.
    I had a fair degree of success with a resistor ladder, with stainless steel screws at the nodes being exposed to water.
    Also toyed with the idea of a 'smart' sensor; a pic epoxied at one end of a tube with 10 inputs dipped in the tank, sending the data serially to the control unit, and operating on phantom power.
    However, if it can be improved any further, I'd love that. And hence the query on IR.
    Bruce, the float driven pot might not be very convenient as the depth of different installations varies. And the mechanical jugglery involved in customizing each installation is daunting.
    Till then, if anyone's interested in any specifics, just so that they dont re-invent the wheel, please feel free to ask.
    Anand
    Hi Anand,
    If this is for commercial application, they make sonar tank level sensors specifically designed to operate in wet environments. I mentioned this alternative since I've installed a ton of these in large water tanks for the state.
    The pot + float thing I built one day for my own water tank in my sprinkler system. The float switches I had been using cost around 30-bucks each, and seem to be designed to self-destruct after about 1 year in operation...
    My cobbled-together one has lasted 5+ years, and cost me around $3.
    I've never tried reflecting IR off the waters surface, but I might have to try it some day. If it does work, I'm curious if maybe some of the Sharp IR distance measuring modules would be something to look at?
    The only draw-backs I see with IR in this environment would be lens fogging or specular reflections from the water surface from ambient light.
    -Bruce
    tech at rentron.com
    Back to the IR, I use this sensor quite often and it works great. Pretty cheap too. The output isn't linear though if it matters to you.
    http://www.acroname.com/robotics/par...P2Y0A02YK.html
    Quote Originally Posted by Tobias View Post
    Yes, that does look promising, though I wish the range was at least a foot or two more.
    I could always use a lookup table. Or, I've noticed in a lot of exponential curves the reciprocal of a reading often fits on a straight line, ready to be used in an algorithm. (I'm no mathematician, so please forgive me if this sounds absurd). Will have to confirm it is so for this sensor in Excel.
    Anand Dhuru
    Bombay, India
    The Sharp IR distance sensors IIRC are meant for small distances less than a couple of feet. I had tried to work with one of these sensors and found the range to be severely limited. I found success with the PING from parallax and subsequently rolled my own PINGer using some locally available Ultrasonic sensors http://robokits.co.in/shop/index.php...roducts_id=100 I didn't get too great a range, but, straight line performance was better than 5 feet.
    Regarding the doubts about sensor reliability, you do get the sealed sensors that are meant for liquid measurement applications. The site which will give you a good handle is Maxbotix. This link shows a sensor meant for such http://www.maxbotix.com/MB7067__XL-MaxSonar-WRC1.html
    Bruce asked if this is a commercial product.
    If yes, do not try making your own sensor. In similar cases I used the MicroflexC US sensor. A great product with 4-20mA output. Powered from the 2 lines.
    http://www.hycontrol.com/level_measu...onic_level.php
    The other option ruce gave with the pot, wll not be very linear, though very cheap.
    A pressure sensor at the bottom of the tank in an extra fitting. 0.43 psi/foot.
