thanks mister_e fore your concern
The only thing i tried to do is get a 38.5Khz to drive a IRled array, wanted a duty at max 50% tough gona overdrive them a little.
With the trusth in your tips, i stripped down my setup to a minimum and start testing. (hard decision)
Did found two broken 628 and some bad cable connection. One did just put out 1V on ccp1 when a scoped it.
Yes i got to work, but figured out that your suggestion of CCPR1L = 128 equals a duty very high. Tested with 63 and get a 50/50. After two late night a have learn me a lesson to keep testboard small and tidy. When expanding, make circuit board and solder down your stuff. Afterwords use board again. It's very time costing to have right code and wrong in hardware setup.
Thanks to you I have new way of thinking
