Solar Tracker Controller
Results 1 to 7 of 7
    Feb 2010
    Albuquerque
    Default Solar Tracker Controller
    I am working on a single axis solar tracker but I am having trouble adding hysteresis to my project. I am using a PIC16F688.
    ' * James Richards *
    ' * Solar Tracker  *
    ' * 5/21/10        *
    '----------Configuration----------
    INTCON = $80
    ANSEL  = %00010100
    ADCON1 = %00010000
    '----------Variables--------------
    ADCVAL1 var word
    ADCVAL2 var word
    RANGE   VAR WORD
    '----------Program----------------
    MAIN:
         ADCON0 = %10001001
         ADCON0.1 = 1
         NOTDONE1:
         pauseus 25
         if ADCON0.1 = 1 then notdone1
         ADCVAL1.highbyte = ADRESH
         ADCVAL1.lowbyte  = ADRESL
             ADCON0 = %10010001
             ADCON0.1 = 1
             NOTDONE2:
             pauseus 25
             if ADCON0.1 = 1 then notdone2
             ADCVAL2.highbyte = ADRESH
             ADCVAL2.lowbyte  = ADRESL
    GREATER:
    range = ADCVAL2 - adcval1
    if (RANGE > 10) then cw
    LESSER:
    range = ADCVAL1 - adcval2
    if (RANGE > 10) then ccw
    goto stay
    CCW:
    high PORTC.2
    low PORTC.3
    CW:
    low PORTC.2
    high PORTC.3
    STAY:
    low PORTC.2
    low PORTC.3
    You might try pulling a few samples then average them before acting. It will make up for the stray cloud.
    Sep 2007
    USA, CA
    Another way to add hysteresis is to require a return direction change to be greater than an advance direction. So, if your last move was to the left caused by a "1x" reading, and a cloud causes a desire to move right, require the reading to be "1.1x", so it's 10% more than the last.
    Feb 2010
    Albuquerque
    Default Reply
    I would also like to add a small adjustable potentiometer to adjust the hysteresis but I will add that in later. I want the tracker to adjust its position every minute but I do not want to use any extra energy overadjusting. I need it to move to a certain position but when it gets there I want it to stay within certain limits instead of doing small oscillations trying to find an exact spot.
    You could think telescope.
    Every minute so many steps on an encoder.
    The sun is pretty predictable
    Also, perhaps a larger than usual capacitor on the ADC pin would make it slower to react to minor, quick fluctuations.
    Anand
