Electric Noise PIC problem
Results 1 to 12 of 12
    Default Electric Noise PIC problem
    Three attachments, first is the schematic and the second is data from a logger box. The schematic is a simplified version. The data is sampled at 100hz, logger limited. The last attachment is a data sheet for an OPTO-MOS on the board
    I have a box that is triggered by wide open throttle. At wide open throttle a timer starts and turns on outputs based on user set times. I am having a problem, I think with the wide open throttle getting noise and making the PIC think it lost the wide open throttle signal and resetting the timers.
    The wide open throttle signal (16v) goes through a OPTO-MOS relay. The relay pulls down a pin on the PIC. The output when activated turns on another OPTO-MOS relay that turns on a P-Type mosfet. I have a DC/DC isolated power supply on the board and every input and output is optically isolated.
    There are four traces on the data.pdf. The green wire is the output of the OPTO-MOS connected to the wide open throttle . When the OPTO-MOS receives 16v, the green trace goes low. This activates the timing sequence. The first output is programmed to trigger at wide open throttle and the second output activates at 1.2 seconds. So the yellow trace is the output of the OPTO-MOS triggering the MOSFET. The red trace is the output of the first MOSFET. The blue trace is the output of the second MOSFET. You can see the blue line going high at 1.2 seconds.
    Keep in mind this data is being logged at only 100 hz. The data looks great until around 2.3 seconds. The red and blue trace go low. The red trace then goes high again and then flickers off twice before staying high. The entire time the 16v input is high. The last flicker is at 3.46 seconds and the second stage goes high at 4.66, right at the correct amount of delay from first stage activation.
    This system works great on a test bench. I do have an ignition system on my test bench to simulate the engine running. However with cylinder pressure from the engine, there is more noise in a race car.
    I know the PIC isn't resetting. There is about ten seconds after power up for the device to be ready to activate based on Wide Open Throttle.
    Somehow the PIC is losing the Wide Open Throttle signal and restarting the timers.
    Any suggestions?
    Tobias , Where is the pullup reststor for the WOT input to the pic? The component you are using is indeed an opto but the output acts the same as an open collector transistor to ground. That is not a good design as the fets when shut off do not set a state to the pic input pin. Also have you checked the actual switch that sets the WOT state during the maximum engine output? Maybe the "vibration" is falsely triggering the pic.. Also, What is the purpose of R22?
    Default New Schematic
    Thanks for the reply. I was away from my PC for a few days. The first schematic was the new version of the board being built. I changed input pins just for the hell of it to see if I could isolate the problem. I screwed up and made the first example schematic a cross between the new and older problem version.
    The problem board schematic is attached. I had the WOT going into PortB.0 and On/Off on B1.
    I just don't understand what in the hell is going on. When On/Off is pulled low, it activates the code and there is start up routine of about ten seconds. When WOT is pulled low it starts the timers. The two circuits are pretty much identical (WOT and On/Off) Yet the WOT looks like it is losing a signal and restarting the timer routine.
    R22 and R25 (on the problem board/second attachment) are pull downs to help eliminate false triggering. I populated another board, the problem child one today and shipped it out to be tested on a car this weekend. I removed R22 and replaced it with a 10uf cap. I tested it out on the scope using a 16v input cycling at even 50 hz and it keep the WOT pin pulled low. So this weekends test should help me figure it out.
    Bombay, India
    Has the behaviour got anything to do with RB0/INT being used as an interrupt in your program? Maybe you can poll RB0 to confirm if this is what is causing the malfunction.
    Good question, originally I was using it as an interrupt but then I changed it over to a Do While Loop that executes the timer function while WOT is Low. I thought maybe I wasn't doing something right on the interrupt side so I went to the Do WHile
    Nov 2008
    Many many years ago I did the development for a GoKart (the racing kind) datalogger and instrument system, based on a HC11 In the R&D phase we spent more time in EMI suppression than in any other part of the design. We tried dozen of supression thechniques before we had a device that would run for more than half a lap once mounted on a Kart... Spark ignition environments are just EMI hell !
