External resonator help
Results 1 to 9 of 9
    Miami, Florida USA
    Quote Originally Posted by rlmack35 View Post
    I'm trying to use a 25MHz osc but it runs like 4 times slower. (1 sec = 4 sec) . I know I need to set the config1h but not sure how to do this. I tried a few samples from what ppl posted but its not compiling. Here are the stats:
    18F2620 / 18F4620
    PBP Pro 2.50b
    rlmack35,
    What kind of tests are you making to determine that your chip runs four times slower? Remember that for Microchip PICs one instruction takes four cycles of the oscillator.
    Dec 2008
    simple test program
    TEST:
    HIGH PORTB.1
    PAUSE 1000
    LOW PORTB.1
    PAUSE 1000
    GOTO TEST
    The light should turn on and off in 1 sec intervals.
    Please post your complete code with the configs so we can see what you got.
    May 2010
    simple test program
    TEST:
    HIGH PORTB.1
    PAUSE 1000
    LOW PORTB.1
    PAUSE 1000
    GOTO TEST
    That works but personally I like to increase the time if you are doing a visual on/off led measurement, if you measure on/off cycles over a period of say one or two minutes you can average a more precise result. That is just me though.
    Dec 2008
    ok but that is not what i'm looking for. mine wasn't off by milliseconds it was off by seconds like 3 or 4 seconds on and 3 or 4 seconds off. but once i installed a 4MHz resonator in it worked just fine.
    Now back on track, can someone help/explain the config of chips to me? I dont mean what they do that much i understand. I mean how to get them into my program or setting them someplace else.
    See the link in post #2 of this thread.
