External resonator help
Results 1 to 9 of 9
    Are you setting the fuses in the .inc or code space?
    In he MPASM directory under program files you will find more .inc files for your chip. Near the bottom of the file all of the options will be listed.
    Dec 2008
    I am trying to set it up in the code space
    I am new to settings other than defaults. I know that i need it to be in HS mode but everything that I have tried will not compile without errors.
