How to reed data from 18F4550 EEPROM into EXCEL via PC USB interface?
Results 1 to 24 of 24
    Quote Originally Posted by jellis00 View Post
    Thanks, Chuck for ideas. Are you referring to Parralax or Windmill?
    I was referring to Parralax has this is a freeware not sure about the windmill software.
    I've used the Parralax many of times and it really easy to use.
    Mar 2009
    Colorado
    Default Will it work with USB interface?
    Quote Originally Posted by chuck View Post
    Thanks, Chuck. As I have said before, however, I must use it on a USB intereface for this particular application. Have you (or anyone else that might answer) ever been able to get Parralax to work with a USB interface between the PC and the PIC?? If I can verify that is doable I am going to give it a try.
    From what I hear, USB-to-serial adapters work fine with PLX DAQ, BUT you have to make sure Windows assigns a lower com number (1 to 4) to the virtual serial port.
    Anand
    Sorry I have not tired the USB way, But I just used an RS232 chap and uploaded it via USB-to-serial cable and this works spot on. This was becasue the laptop does not a a serial port on it.
    I have treid to do a search for usb into excel but never found anything, I shall carry and look and have ago at doing my own has USB is the way forwardm I susspose it easy to so once you have mastered it.
    USB is not my forte (yet!), but from what little I understand (Bruce, Darrel or any of the other Gurus can confirm or rubbish this), if you use CDC descriptors on the pic side it would be equivalent to using a RS232-to-serial. Then, you dont need to worry about inputing data from USB into Excel; just assign a low com port to the virtual connection and Excel wouldnt even know the data is coming over USB, not the serial port.
    Anand
    Anand
    I am not a guru but you are correct.
