Hi Jellis00,
This was done on a 4550 and compiled with PBP v2.47. Look in LABXUSB.INC for config fuse settings. I had these commented because I used Microchips USB boot-loader. You can get rid of the DEFINE RESET_ORG 800h since you're not using the USB loader. Note there are a few routines in the PBP code that were just experimental also.
The 18F4450.INC was in there because someone requested it way back when I first put this together, and I compiled the Microchip USB loader for an 18F4450 for them.
Just use the 18F4550.INC file you have, and set config fuses to the same as in the LABXUSB.INC file.
The Readme.txt file has instructions for the vbskfr2.DEP and other related files. This is a VB skin program that gives the form the look it has.
It's a lot of reading, but it's all there. If you're using PBP 2.6 look for the changes Darrel mentioned, and make sure you use whatever include files are with 2.6.
