TX module heating up ????
Results 1 to 13 of 13
    The same circuit I already drew-up for you works on both ends. Your RF receiver data output pin would connect to the base of the PNP transistor labeled USART, and the PIC USART RX input pin would connect to the PNP collector/resistor node labeled RF TX.
    The logic on the PIC USART RX input pin should idle high. With the RF receiver output idling LOW, that's exactly what you'll have on the PIC USART RX input with this same PNP inverter circuit.
    It's just basic electronics...
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2009
    London
    I am sorry , I am on a very steep learning curve here. Just want to confirm that if there is any resistance needed between base and USART or direct connection is fine? Thanks
    You can get by without the base resistor. If you will be flipping power on/off a lot, and want to make sure the transistor stays off until it's turned on, you can use an inverter circuit like this one http://www.rentron.com/IRTORF_TX.gif
    The 10K pull-up holds the base at logic 1 keeping the transistor off while the PIC powers up. If it's battery operated a small FET would be a better choice than a transistor.
    I drew another quick schematic for you. Either receiver inverter will work, but the NPN circuit would be best.
    -Bruce
    tech at rentron.com
