MicroCode Studio and PBPL (longs) ?
Results 1 to 10 of 10
    I am slowly finishing a new FineLineIDE which does a quick look through of code to make
    sure the correct compiler (PBPW or PBPL) and assembler (PM or MPASM) is selected.
    Also if a "FL comment directive" such as 'FL PIC18F2520 is found the IDE will auto select
    the correct PIC for compilation.
    Norm
    Nov 2008
    Very nice Norm. Perhaps MCS could do the same in a new version...
    Hey Robert and all, thanks for the info. I'm sure I'll find the check box now that I know it's definitely there.
    Miami, Florida USA
    Martin,
    In response to your PM message, yes for the 18F series you need to enable MPASM. Take a look at the attached pics. To get there go to View and Compile and Program Options...
    I am not sure what the INHX8M and the other options are for, but I have them set in the default setting. Pressing the help button will not help much in clarifying what these options are for. Anyhow, the way you see it in the pictures is the default setting and it works.
Size:  23.2 KBName:  PBP-1.JPG
    Nov 2008
    Oh dear. My MCS option window does not show that box....
    I turned off MPASM in the next window, then back on again, nope no PBPL box.
    My SW version About info shows me using V3.0.0.0 which seems the latest version.
    Could my copy be messed up ?
    PS. I said elsewhere that I must have kicked a black cat recently.... Make that two black cats.
