MicroCode Studio and PBPL (longs) ?
Results 1 to 10 of 10
    Miami, Florida USA
    Quote Originally Posted by mr.sneezy View Post
    Any advanced MCS users out there know if MCS editor will use the PBPL.EXE automatically if you use Longs in your 18FXXXX code ?
    I can't see a setting in MCS to force it too.
    Martin
    Martin,
    I am not an advanced MCS user , but I can answer this one. MCS will not use PBPL automatically. You have to set this option in the MCS asembler and compiler options. I have been using this option lately on a 18F4550 without any problems.
    I am not in front of my computer right now, so I can not tell you exactly how to set it. But, the option to set PBPL is in the MCS menu options. If you don't find it, I can post some screenshots later.
    I am slowly finishing a new FineLineIDE which does a quick look through of code to make
    sure the correct compiler (PBPW or PBPL) and assembler (PM or MPASM) is selected.
    Also if a "FL comment directive" such as 'FL PIC18F2520 is found the IDE will auto select
    the correct PIC for compilation.
    Norm
    Nov 2008
    Very nice Norm. Perhaps MCS could do the same in a new version...
    Hey Robert and all, thanks for the info. I'm sure I'll find the check box now that I know it's definitely there.
    Miami, Florida USA
    Martin,
    In response to your PM message, yes for the 18F series you need to enable MPASM. Take a look at the attached pics. To get there go to View and Compile and Program Options...
    I am not sure what the INHX8M and the other options are for, but I have them set in the default setting. Pressing the help button will not help much in clarifying what these options are for. Anyhow, the way you see it in the pictures is the default setting and it works.
Size:  23.2 KBName:  PBP-1.JPG
    Nov 2008
    Oh dear. My MCS option window does not show that box....
    I turned off MPASM in the next window, then back on again, nope no PBPL box.
    My SW version About info shows me using V3.0.0.0 which seems the latest version.
    Could my copy be messed up ?
    PS. I said elsewhere that I must have kicked a black cat recently.... Make that two black cats.
