My reference voltage is 12 volts
Come again.... 12V, that's way to high. Maximum voltage on the Vref pin is whatever the supply voltage for the chip is currently. If there's a "." missing in there and it shoudl read 1.2V then that won't work either as the low limit for Vref is 2.2V. See table 15-9 in the datasheet.
It also seems that for AN0 when I apply a voltage above VDD the pic limits the voltage to VDD
Yes, naturally because the inputs have protection diode from the input to both Vss and Vdd so they'll clamp the voltage to one diode-drop above or below Vdd and Vss respectively.
