Using MAX 7221 LED driver
Results 1 to 16 of 16
    JDM160's Avatar
    JDM160 Guest
    Red face Help please
    I am trying to use the code achuri posted to better understand how to interface the MaX 7219 with my PIC (18F2331).
    I am having a hard time compiling it because of errors, namely with the rowxVar statements. Obviously what was posted is not complete code, but I need help putting it to use for me.
    Ultimately what I'm trying to do is display a 3 digit number on a 3 digit LED display using the 18F2331. How exactly do I update or write the number to each digit? Any help would be greatly appreciated...
    Nov 2006
    Tulare CA
    Default 7219 Code
    The following is code that I wrote for the MAX 7219. This is only the sub that I call to initialize and test the display. This was written for a 16F877 but can be ported to just about anything. I am far from a programmer so if anyone out there can clean this up or make it better please let me know. I know this code works, as we have shipped many units running it. You must, of course, setup your ports and outputs. Hope this helps - if anyone finds this usefull I would love to hear from you! Feel free to cut and paste this but please pass on help to others - we all must stick together!
    LEData VAR PORTC.1
    CLK VAR PORTC.5
    Load VAR PORTC.0
    Max_init:
    ShiftOut LEData,clk,MSBFIRST,[%0000100111111111\16] ' Reg. 9 Decode
    PulsOut Load,10
    ShiftOut LEData,clk,MSBFIRST,[%0000101000001111\16] ' Reg. A Intensity
    PulsOut Load,10
    ShiftOut LEData,clk,MSBFIRST,[%0000101100000111\16] ' Reg. B Scan Limit
    PulsOut Load,10
    ShiftOut LEData,clk,MSBFIRST,[%0000110000000001\16] ' Reg. C Shutdown
    PulsOut Load,10
    ShiftOut LEData,clk,MSBFIRST,[%000011110000000\16] ' Reg. F Display Test
    PulsOut Load,10
    ' Blank the display
    digit = 8
    For x = 1 TO 8
    ShiftOut LEData,clk,MSBFIRST,[digit,$F]
    PulsOut Load,10
    digit = digit - 1
    Next
    ' Test the display by writting 8's to each digit and scrolling them across
    digit = 8
    For x = 1 TO 8
    ShiftOut LEData,clk,MSBFIRST,[digit,8]
    PulsOut Load,10
    Pause 500
    PulsOut Load,10
    digit = digit - 1
    Next
    ' Write H
    digit = 1
    ShiftOut LEData,clk,MSBFIRST,[digit,$C]
    PulsOut Load,10
    ' Write E
    digit = 2
    ShiftOut LEData,clk,MSBFIRST,[digit,$B]
    PulsOut Load,10
    ' Write L
    digit = 3
    ShiftOut LEData,clk,MSBFIRST,[digit,$D]
    PulsOut Load,10
    digit = 4
    ' Write L
    digit = 4
    PulsOut Load,10
    digit = 4
    ' Write 0
    digit = 5
    ShiftOut LEData,clk,MSBFIRST,[digit,0]
    PulsOut Load,10
    digit = 4
    Pause 250
    ' Blink it 5 times
    For x = 1 TO 4
    ShiftOut LEData,clk,MSBFIRST,[%0000110000000000\16] ' Reg. C Shutdown ON
    PulsOut Load,10
    Pause 150
    ShiftOut LEData,clk,MSBFIRST,[%0000110000000001\16] ' Reg. C Shutdown OFF
    PulsOut Load,10
    Pause 200
    Next
    Pause 1000
    Feb 2010
    Default does not work
    Unfortunaly none of these projects does not work.
    The program of using the PROTEUS to check.
    I want to do a project with a running line is from PIC 16f877 and driver MAX 7221.
    We also managed if someone let the finished project + program
    I apologize for my English, I am from Ukraine and use a translator Google.
    Feb 2010
    Nov 2006
    Tulare CA
    Default Max 7221
    What about the code does not work? We have shipped many units running this code??
    Have you actually compiled and ran it?
    Plasma Jocky
    Feb 2010
    У МЕНЯ НЕ работает код. что-то не так
    Feb 2010
    sorry.
    I did not have working code. something wrong
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Help with LED driver fade on/off
    By dfort in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 00:39
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. Alegro 6276 LED driver?
    By [email protected] in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2007, 00:25
  5. LCD will not start
