Hello Unregistered ,
Originally Posted by mr.sneezy OK, yes I see that. Is there any drawback to averaging the difference between the numbers rather than the total of the numbers ? It sounds like you are after a relative measurement and not concerned withnthe actual so averaging the difference should be fine. Are you thinking the Difference values will be small enough to use more samples in the average? Should be on target then.
Dave Always wear safety glasses while programming.
Forum Rules
