Finding the change and direction of a signed word value (sensor output) ?
Results 1 to 8 of 8
    The difference should be smaller than a WORD so if you do the average of a couple you should not need 32 bit math. If it does over flow the WORD then I think that would be telling you that the difference is larger enough to... make a difference
    Nov 2008
    OK, yes I see that.
    Is there any drawback to averaging the difference between the numbers rather than the total of the numbers ?
    Quote Originally Posted by mr.sneezy View Post
    OK, yes I see that.
    It sounds like you are after a relative measurement and not concerned withnthe actual so averaging the difference should be fine.
    Are you thinking the Difference values will be small enough to use more samples in the average? Should be on target then.
