Finding the change and direction of a signed word value (sensor output) ?
Results 1 to 8 of 8
    Lightbulb Supposing you build a barometer or altimeter ... using MS5534 or Hope HP03 ...
    Hi, Martin
    Assuming pressure will be read as i.e 1013.3 mb ( displayed number < 65536) ...
    the difference between two measures will be < 32768 ... ( or you will feel really really really bad !!! )
    sooo ...
    the MSB of the difference will be 0 for positive difference and 1 for neg difference... add to that PBP offers the direct print of the value and sign : " SDEC Difference "
    Nov 2008
    sooo ...
    The sensor is a Bosch BMP085. The actual raw un-compensated pressure value at about 260m (where I live) is -24200 in SDEC. I'm not sure what the range of values is going to be yet, I need to work that out yet (from sea level to say 1000m).
    I'll try out the SDEC Difference to see what it does too.
