Interupts - can two switches share the 'INT' Pin?
Results 1 to 7 of 7
    Here's one example with 13 switches using just 2 interrupt input pins.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2009
    Thanks guys - I have my two switches working sweet onto the one INT pin now (once I figured out that OPTION_REG.6 = 1 wasn't set that is !)
    http://www.darreltaylor.com/DT_INTS-14/hello.html
    On that above URL, I see Darrel is using a cap to debounce the switches - going that route is there any win over & above using a short pause in the interupt handling routine (200ms seems to be debouncing fine & it save me a couple of caps - I'm not a tightwad, but space is going to be limited on my pcb!)
