PIC 16f877A LCD problem!
Results 1 to 10 of 10
    May 2010
    Default PIC 16f877A LCD problem!
    Hello Guys,
    I have interfaced LCD with my PIC 16f877a. I want to initially display words on my lcd but the problem is only garbage value is being displayed. Please tell me the solution. I have given the code which i used to program the MCU.
    Regards.
    CLEAR
    DEFINE LCD_DREG PORTD
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    DEFINE LCD_RWREG PORTE
    DEFINE LCD_RWBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 1
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    PAUSE 500
    LOW PORTE.2
    TRISD = %00000000
    TRISE = %00000000
    ADCON1=%00000111
    LOOP:
    LCDOUT $FE, 1
    PAUSE 250
    LCDOUT "HELLO"
    LCDOUT $FE,$C0
    LCDOUT "WORLD"
    PAUSE 250
    GOTO LOOP
    Mentor, Ohio
    Smile
    Hello uaf5000,
    Well at first glance you are missing the line "DEFINE LCD DBIT 0". You also have a line that says you are only using 1 line when the statement "LCDOUT $FE,$C0" is the command to display the following on the second line of the LCD. Make these changes and see how it goes.
    Your code can also read--"LCDOUT $FE,1,"Hello"
    "LCDOUT $FE,$C0,"World"
    I think this also may have been messing things up for you.
    HTH,
    BobK
    May 2010
    Still same garbage values =(. I made the changes you told. But in those garbage values letter 'D' is appearing which wasn't before. What shall i do now? =(
    PORTE is analog on this chip, so you will need to turn that off.
    May 2010
    I've used the command ADCON1=%00000111. Didnt this command make port E digital?
