High resolution timer problem
Results 1 to 9 of 9
    Question High resolution timer problem
    Hello,
    I am trying to use Robert Wozniak's high resolution timer on a 18F4680. I am using MPASM due to
    DT's interrupts. I have the latest everything so I should be good to go. I am getting more errors than I can copy and paste. It says "Fatal error (21), and
    numerous "bad data type" errors.
    Does this software require PBPL? Or should it work with regular PBP? Any insight would be appreciated.
    Nick
    Yes, WOZZY wrote that for PBPL.
    I think he was using it to make displaying the numbers easier.
    But since it uses N-Bit_Math, you can do the same thing without PBPL or even on 16F's.
    The Timers doing most of the work. You just need to catch the overflows and do the math.
    And there's a routine to display large numbers without PBPL now (using N-Bit_Math).
    http://www.picbasic.co.uk/forum/show...9430#post89430
    Question
    Hello Darrel,
    Here is the code I am working with. With all the includes, and PBP....still getting errors.
    '*********************[ High-Resolution Timer ]********************
    '**  Author  : Robert Wozniak,   Robert.Wozniak -at- gmail.com   **
    '**  Notice  : This code may be freely used and distributed      **
    '**            for use in non-commercial applications            **
    '**  Version : 6.10 : Feb 06, 2010                               **
    '**  Date    : JAN 14, 2010                                      **
    '**  Versions:                                                   **
    '**   6.0 : All 64 bit MATH, 99 min limit                        **
    '**   5.0 : Working Timer and Speed Calculator with 64 bit math  **
    '**   Hardware Tested: PIC18F4680 @20MHz                         **
    '**   4x16 Parallel LCD Module                                   **
    '**   PBP 2.60 / MPLAB IDE 8.40.000                              **
    '**   Compiled with: [-n -ampasmwin] Build Options               **
    '**   32 BIT LONG SIGNED INTEGER                                 **
    '** Thanks to Darrel & Bruce at MEL PB Forums for Code examples  **
    '**           Alexander for N-Bit Math...Excellent ASM code      **
    '**  MAX OVRFLO=457763, COUNTS=44041 for 99min:59.9999998sec     **
    '**  MIN OVRFLO=0, COUNTS=261 for 9999.999MPH                    **
    PRECISION CON 8 SYSTEM  	    ; Set 8 bytes = 64-bit Precision for N-Bit_Math.pbp
    INCLUDE "N-BIT_Math.pbp"		; Include Alexander Avtanski's Multibyte Arithmetic
    								; Assembly Library Wrapped for PBP by Darrel Taylor [Version:1.3 Beta (JAN 07,2010)]
    								; Version:1.3 Beta (1/7/2010)
    INCLUDE "DT_INTS-18.bas"		; Include Darrel Taylor's Base Interrupt System for PIC18F [Version:3.3 (MAR 24, 2008)]
    INCLUDE "ReEnterPBP-18.bas"		; Include Darrel Taylor's PBP interrupts for PIC18F [Version:1.4 (MAR 24, 2008)]
    DEFINE OSC 20
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 57600   	' 38400 BAUD N-8-1, PORT C6
    DEFINE DEBUG_MODE 1 		' 1 = inverted, 0 = true
    DEFINE LCD_DREG PORTA       ' Set LCD Data port
    DEFINE LCD_DBIT 0           ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTA      ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4          ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB       ' Set LCD Enable port
    DEFINE LCD_EBIT 3           ' Set LCD Enable bit
    DEFINE LCD_BITS 4           ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4          ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us (2000)
    DEFINE LCD_DATAUS 50        ' Set data delay time in us (50)
    TRISA=%00000000           	' SET to Output
    TRISC.2=1          			' SET to Input
    ADCON0=%11000000
    ADCON1=%00000111
    T1CON.7=1					' Set Timer1 to 16 bit mode
    LED     		VAR PORTD.1  			' Alias PORTD.0 to LED
    I				VAR	BYTE
    J				VAR	BYTE
    OVRFLO  		VAR LONG 				' Timer1 Overflow total
    COUNTS  		VAR WORD 				' Timer1 Counts after falling edge capture
    PRESET			VAR	BYTE
    OVFLS32			VAR	LONG
    COUNTS32	   	VAR LONG
    TSEC32	   		VAR LONG
    OVFLS64     	VAR BYTE[PRECISION]
    OVFLS64M     	VAR BYTE[PRECISION]
    COUNTS64     	VAR BYTE[PRECISION]
    TSEC64	     	VAR BYTE[PRECISION]
    BITS16			VAR	LONG
    BITS1664	    VAR BYTE[PRECISION]
    TMIN64			VAR BYTE[PRECISION]
    TSECINT64	    VAR BYTE[PRECISION]
    TSECDEC64	    VAR BYTE[PRECISION]
    CONVSEC			VAR	LONG
    CONVSEC64	    VAR BYTE[PRECISION]
    AA32			VAR	LONG
    AA64	  		VAR BYTE[PRECISION]
    BB32			VAR	LONG
    BB64			VAR BYTE[PRECISION]
    CC32			VAR	LONG
    CC64	  		VAR BYTE[PRECISION]
    TMIN	   		VAR LONG
    TSEC	   		VAR LONG
    TSECINT	   		VAR LONG
    TSECDEC	   		VAR LONG
    DISTINCH	   	VAR LONG
    DISTFT			VAR LONG
    DISTFT64		VAR	BYTE[PRECISION]
    DISTFT64M		VAR	BYTE[PRECISION]
    FPS32			VAR LONG
    FPS64     		VAR BYTE[PRECISION]
    FPSINT			VAR LONG
    FPSINT64     		VAR BYTE[PRECISION]
    FPSDEC			VAR LONG
    FPSDEC64     	VAR BYTE[PRECISION]
    MPH64			VAR BYTE[PRECISION]
    MPHINT64		VAR BYTE[PRECISION]
    MPHDEC64		VAR BYTE[PRECISION]
    MPH32			VAR	LONG
    MPHINT			VAR	LONG
    MPHDEC			VAR LONG
    ' ****** Setup Variables with Initial Parameters and 64-BIT Constants
    I = 0
    J = 1
    PRESET = 3							'  ********** PER OVERFLOW LOOP TICS CORRECTION **********
    BITS16 = 65536 * 2					'  ********** COUNTS MAX * 200 NS PER TIC**********
    @  MOVE?LP  _BITS16, _BITS1664
    DISTINCH = 6000  					' ********** 6.000 inches  (MAX = 65.535 in) **********
    DISTFT = ((DISTINCH*10000)/12)
    @  MOVE?LP  _DISTFT, _DISTFT64      '  ********** CONVERT TO FEET **********
    AA32 = 1000000						'  ********** BUMP UP RESOLUTION
    @  MOVE?LP  _AA32, _AA64
    @  MATH_MUL  _DISTFT64, _AA64, _DISTFT64M	'  ********** BUMP UP DISTANCE DIGITS
    CONVSEC = 600000000
    @  MOVE?LP  _CONVSEC, _CONVSEC64            '  ********** BUMP UP TIME DIGITS
    Pause 500
    LCDOUT $FE,1
    LCDOUT $FE,$80,"HIGH-RESOLUTION "
    LCDOUT $FE,$C0,"     TIMER      "
    LCDOUT $FE,$90,"  Version 6.10  "
    LCDOUT $FE,$D0," Robert Wozniak "
    DEBUG 10,13,10,13,10,13
    DEBUG "HIGH-RESOLUTION ",10,13
    DEBUG "     TIMER      ",10,13
    DEBUG "  Version 6.10  ",10,13
    DEBUG " Robert Wozniak ",10,13,10,13,10,13
    For I = 1 to 5
    HIGH LED        ' Turn ON LED connected to PORTD.1
    Pause 50
    LOW LED
    PAUSE 50		' Turn OFF LED connected to PORTD.1
    NEXT I
    I = 0
    ;----[High Priority Interrupts (DT_INTS_18)]----------------------------------------
    INT_LIST  macro    ; IntSource,   Label,   Type, ResetFlag?
    	INT_Handler   CCP1_INT,  _Capture,  PBP,  yes
    	INT_Handler   TMR1_INT,  _Timer1,   PBP,  yes
        INT_CREATE               ; Creates the High Priority interrupt processor
    CCP1CON = %00000101  		' Capture mode, capture on rising edge
    T1CON = 0            		' TMR1 prescale=1, clock=Fosc/4, TMR1=off (200nS per count @20MHz)
    @    INT_ENABLE  CCP1_INT    ; enable Capture interrupts
    IF T1CON.0 <> 0 And I = 0 THEN
    	LCDOUT $FE,1
    	LCDOUT $FE,$C0,"   MEASURING"
    	I = 1
    	GOTO LCDEND
    IF T1CON.0 <> 0 THEN LCDEND
    IF T1CON.0 = 0 AND J = 0 THEN
    '********** CONVERT COUNTS, OVERFLOWS to SECONDS **********
    @  MOVE?LP  _OVRFLO, _OVFLS64
    @  MATH_MUL  _OVFLS64, _BITS1664, _OVFLS64M
       COUNTS32 = (COUNTS-10)*2						' 10 TICS START CORRECTION,  200 nS PER COUNT
    @  MOVE?LP  _COUNTS32, _COUNTS64
    @  MATH_ADD  _OVFLS64M, _COUNTS64, _TSEC64
    ' ********** CONVERT SECONDS TO MINUTES **********
    @  MATH_DIV  _TSEC64, _CONVSEC64, _TMIN64
    @  MOVE?PL  _TMIN64, _TMIN
    ' ********** GET INTEGER SECONDS **********
       CC32 = 10000000
    @  MOVE?LP  _CC32, _CC64
    @  MATH_MUL  _TMIN64, _CONVSEC64, _AA64
    @  MATH_SUB  _TSEC64, _AA64, _BB64
    @  MATH_DIV  _BB64, _CC64, _TSECINT64
    @  MOVE?PL  _TSECINT64, _TSECINT
    ' ********** GET DECIMAL SECONDS **********
    @  MATH_MUL  _TSECINT64, _CC64, _AA64
    @  MATH_SUB  _BB64, _AA64,  _TSECDEC64
    @  MOVE?PL  _TSECDEC64, _TSECDEC
    ' ********** CALCULATE SPEED (FPS) **********
    @  MATH_DIV  _DISTFT64M, _TSEC64, _FPS64
    ' ********** GET INTEGER FPS **********
       CC32 = 1000000
    @  MATH_DIV  _FPS64, _CC64, _FPSINT64
    @  MOVE?PL  _FPSINT64, _FPSINT
    ' ********** GET DECIMAL FPS **********
    @  MATH_MUL  _FPSINT64, _CC64, _BB64
    @  MATH_SUB  _FPS64, _BB64,  _FPSDEC64
    @  MOVE?PL  _FPSDEC64, _FPSDEC
    ' ********** CONVERT FPS to MPH **********
       AA32 = 15
       BB32 = 22
    @  MOVE?LP  _BB32, _BB64
    @  MATH_MUL  _AA64, _FPS64, _CC64
    @  MATH_DIV  _CC64, _BB64, _MPH64
    ' ********** GET INTEGER MPH **********
       AA32 = 1000000
    @  MATH_DIV  _MPH64, _AA64, _MPHINT64
    @  MOVE?PL  _MPHINT64, _MPHINT
    ' ********** GET DECIMAL MPH **********
    @  MATH_MUL  _MPHINT64, _AA64, _BB64
    @  MATH_SUB  _MPH64, _BB64,  _MPHDEC64
    @  MOVE?PL  _MPHDEC64, _MPHDEC
    ' ********** DISPLAY RESULTS **********
    LCDOUT $FE,1
    LCDOUT $FE,$80," ",DEC2 TMIN,":",DEC2 TSECINT,".",DEC7 TSECDEC
    LCDOUT $FE,$90, DEC4 FPSINT,".",DEC6 FPSDEC," FPS"
    LCDOUT $FE,$D0, DEC4 MPHINT,".",DEC6 MPHDEC," MPH"
    DEBUG "OVRFLO: ",DEC10 OVRFLO,13,10
    DEBUG "COUNTS: ",DEC10 COUNTS,13,10,13,10
    DEBUG "TIME: ",DEC2 TMIN,":", DEC2 TSECINT,".",DEC7 TSECDEC,13,10
    DEBUG "SPEED: ",DEC4 FPSINT,".",DEC6 FPSDEC," FPS",13,10
    DEBUG "SPEED: ",DEC4 MPHINT,".",DEC6 MPHDEC," MPH",13,10,13,10
    J = 1
    GOTO LCDEND
    LCDEND:
    	PAUSE 25
        @    INT_ENABLE  CCP1_INT     ; Start new capture
    GOTO Main
    '---[CCP1 - interrupt handler]------------------------------------------
    Capture:
      IF CCP1CON = %00000101 THEN      ' If rising edge capture then
      	 HIGH LED					   ' Turn on LED to Indicate Measuring
         TMR1L = PRESET                ' Clear Timer1 counts with Preset (High)
         TMR1H = 0					   ' Clear Timer1 counts (LOW)
         T1CON.0 = 1                   ' Turn Timer1 on at rising edge capture
         OVRFLO = 0                 	' Zero Over flow counts
         COUNTS = 0                 	' Zero remainder
         CCP1CON = %00000100           ' Switch to falling edge capture
         PIR1.0 = 0                    ' Clear Timer1 overflow flag before enable
    	 I = 0 : J = 0
         @    INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
         GOTO OVER_CCP                 ' Done, exit
      IF CCP1CON = %00000100 THEN      ' If falling edge capture then
         T1CON.0 = 0                   ' Stop Timer1
         CCP1CON = %00000101           ' Switch back to rising edge capture
         @    INT_DISABLE  TMR1_INT    ; Disable Timer 1 Interrupts
         @    INT_DISABLE  CCP1_INT    ; Disable CCP1 Interrupts
         COUNTS.LowByte = TMR1L     	' Get remaining Timer1 counts on falling edge (Low Byte)
         COUNTS.HighByte = TMR1H    	' Get remaining Timer1 counts on falling edge (High Byte)
    	LOW LED							' Turn off LED
    OVER_CCP:
    @ INT_RETURN
    '---[TMR1 - interrupt handler]---------------------------------------------
    Timer1:
    OVRFLO = OVRFLO + 1
    @ INT_RETURN
    Yup, that's WOZZY's code. (for PBPL)
    Are you using PBPL now?
    If not, you are going to have to make a lot of changes.
    I have never used PBPL before. Can I simply point my Microcode studio to use PBPL instead of PBP?
    Nick
    Assuming you have PBP 2.50 or higher ...
    In MCS, go to View > Compile and Program Options > Compiler Tab.
    And check the "Use PBPL" checkbox.
