Help PLEASE - Stuck on a project! 16F877A
Results 1 to 17 of 17
    Quote Originally Posted by Megahertz View Post
    Is it possible that using DT_INT could be the problem?
    No, but using them the wrong way sure will.
    Sitting in the interrupt handler sending serial data and pausing in a loop will stop anything else from happening in the main loop.
    By the time you exit the handler, the timer has overflowed again, and it'll jump right back to the handler again for more loops pauses and DEBUG output.
    Interrupts are meant to handle things immediately and fast.
    Not to trigger a long series of statements that take longer than the period between interrupts.
    Get in, do what you need to respond to the interrupt, then GET OUT.
    Let the main loop handle any pauses and debugs.
    99.9% of the time, there should never be a PAUSE in an interrupt handler.
    And you should use the USART for serial data, not DEBUG/IN.
    Nov 2009
    London
    Thanks for the answer. I can see some light now at the end of the tunnel.
    Few questions I have, please try to answer them:
    1) My MCroom code sits at DEBUGIN statement at all times. And I have learnt that after the interrupt is handeled, program resumes from from the last statement which it was executing, which in my case is DEBUGIN. So how can I send
    if z>0 THEN
         for x=1 to 30
           DEBUG "MT3",z,"C"
           Low Tx : Pause 10
         next x
         Low BUZ : z=0
    this signal if I do not put it in interrupts.
    2) I have used one calculator I found here in forum only to see what is the duration of interrupts. It comes to every 524mSec for TMR1 @ 16bit @ 1:8 prescaler. Based on that the MCRoom code only uses 300mSec for debug statement and that too only once. OK, I agree if I put pause statements in the ISR code, timer will runout again. but pause is only used once when the DEBUG is used in MCRoom code ISR, why it kind of hangs permanently after that?
    Because MC1 code is repeating that signal continuesly after certain interval. I cannot understand why the MCroom is unable to catch the LED OFF code later
    I hope I have explained my point, and apologies if confusion is still lingering. Please ask me for any clarification if needed.
    P.S: I don't have any knowledge about USART, I am a product design student actually and try to learn programming because I find it very interesting. I will learn about USART soon and apply it to these codes. I hope I can make this code work using DEBUG for now.
    Using the USART in PBP is not much different than using DEBUG or SERIN2, same syntax.
    Look to the PBP manual under HSERIN for starters and at the bottom of this page is an example to play with.
    http://www.melabs.com/resources/samples-pbp-general.htm
    The hardest thing with the USART at the beginning is setting it up.
    For that this is a handy tool
    PicMultiCalc
    http://www.picbasic.co.uk/forum/atta...achmentid=2957
    Nov 2009
    London
    Hi Mackrackit, thanks for the answer.
    Can you please explain briefly what excatly is USART (HSERIN) and how is it different to SERIN, If I attach the TX pin to my RF receiver and use HSERIN, will it still work as normal, does data comes differently when HSEROUT/HSERIN is used.
    I also want to ask that when using the debug statement, because of the noise at the RF receiver, even if there is a timeout, 99% of the time it does not work. When used with USART command, can this problem be sorted?
    The main difference is SERIN2 is all software(bit banging) while USART is done in the on chip hardware.
    SERIN2 has the advantage of being able to be used on just about any pin and can be setup for Inverted or True mode.
    USART has the advantage of running in the background and can be used as an interrupt trigger.
    Sometimes considered a disadvantage the USART is True mode only so depending on the application an inverter chip might be needed (MAX232 type).
    Data with both types can be a standard 8N1.
    To be honest I have not really looked at your code but I will guess some sort os simple checksum would solve the noise problem. I will take a look at it later.
    Reliable RF can be used with bit banged serial, Bruce has a nice example in the Code Example section.
    Possible pointers...
    Finally had a chance to look at your code and I am wondering exactly what your are trying to accomplish with the interrupts and you are receiving a string into var P but I do not see where P is used.
    A couple of things that might help you.
    Like Darrel said about interrupts, get in and out as fast as you can.
    That being said I think I would use the interrupt to receive data. This can be accomplished using DT's instants if you use the USART. I have only used DT's intants for this a time or tow and they worked great, thanks Darrel! There are examples on how to set it all up on his web site.
    The only thing you would be doing inside the interrupt is receive data. The data will be processed else where. Using USART and interrupts you should not miss any data.
    Now for the RF.
    If you are using radio modules like the ones found at rentron.com then they need to be "trained" to receive data. This is done by sending a bunch of 0s and 1s. There is some controversy about this but sending $A5 first seems to work well. Also send a SYNK byte, this will take place of your MT3. You will wait for the SYNK.
    TRAIN = $A5
    SYNK = $7E
    HSEROUT [TRAIN,SYNK,"your data will be here"]
    In the receiver side, the interrupt will be triggered when the USART "hears" something. If the SYNK is not received then exit the interrupt. If SYNK is good save the data then exit the interrupt.
    That might be enough to make it work but you may also want to add a simple checksum.
    A quick and dirty way is to take the value you are sending, 41, and multiply by 3 before you send. That value would be saved into a VAR CH_SUM, = 123. Send 41 and CH_SUM.
    When you receive save 41 to your code VAR and save CH_SUM also. Before you act on the data divide CH_SUM by 3 and check to see if it equals "code". If not you have had a bad transmission.
    There are several ways to do this, the above is just one to give you some ideas.
    Hope my babbling did not confuse the issue.
    [/code]
    Nov 2009
    London
    Thanks Dave, I am very thankful to many members here, because I have learnt a lot from this forum and now the checksum method, which you have explained very simply.
    I have taken the advises above and changed the code and freed the MCRoom's ISR.
    During my earlier attempts, I tried to make the code work by sending an 1 string byte, but it didnt worked so I changed it, but left the receiving string variable as it is.
    It is not working currently, but it seems I am near as ISR is not handling much complicated stuff like pause or DEBUG.
    The code at machine now (MCH1.txt), keeps sending signals and waits for the answer from the MCroom.
    The MCroom should switch the LED ON and buzzer ON when mch reports a problem. I have tried to put everything in a loop, but it is not working.
    Is it ok to put things in loop like I have done?
    I am attaching the codes I have amended.
