Hserout, multitasking?
Results 1 to 5 of 5
    toalan's Avatar
    toalan Guest
    ahh that makes alot of sense.
    I assume you can directly or indirectly check to see if the buffer is full or not. Any idea which registers to check? I know read the datasheet, but if anyone happens to know it off the of their head then please do tell. Thanks again
    Alan To
    mmmm can't say you can do it elsewhere than in a interrupt handler routine... try TXSTA=0
    OR do a loop to send your data byte/byte, do a test after each HSEROUT that say to continue or stop HSEROUT.
    for SEndData = x to y
         Hserout [Myvar[SendData]]
         ' set your stop/continue flag here and after that
         If ContinueOrStop = Stop then SendData = y ' to get out of the loop
    next
    toalan's Avatar
    toalan Guest
    TY for the info
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 18:44
  2. hserin and sms controller
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 16:49
  3. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  4. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  5. Controlling an 240x128 LCD Touchpanel Display
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 00:36
