I'm trying to rid the world of 16F chips, but try this
http://www.picbasic.co.uk/forum/show...ght=n-bit_math
Charles Linquist
What is x20?
what is f0?
what is x?
A little more detail and it is possible that a different solution exists.
The last time I did something similar, I had a pulses per mile count. After that the mile count would increase by 1. To handle numbers as big as 99999999 you can do it in code like I did
Pseudo code begins
Now, displaying this is easy.Code:miles[4] var byte ' lsb to msb on input pulse, pulses=pulses+1 if pulses >= Pulsespermile pulses = 0 ' start counting again till we reach pulses per mile miles[0] = miles[0]+1 if miles[0] > 99 then miles[0] =0 miles[1] = miles[1]+1 if miles[1] > 99 then miles[1] = 0 miles[2] = miles[2]+1 if miles[2] > 99 then miles[2] = 0 miles[3] = miles[3]+1 if miles[3] > 99 then miles[3] = 0 ' roll over to all zero endif endif endif endif endif
Code:Num = miles[0] dig 1 ' first digit to display digitpos = 0 gosub displaynum ' show the number Num = miles[0] dig 0 ' 2nd digit to display digitpos = 1 gosub displaynum ' show the number Num = miles[1] dig 1 ' 3rd digit to display digitpos = 2 gosub displaynum ' show the number Num = miles[1] dig 0 ' 4th digit to display digitpos = 3 gosub displaynum ' show the number and so on
In some cases,(like high-volume applications), the 16F series makes sense. But too often I see people that work hours (or tens of hours) longer to get something to work because they started out with an inadequate chip on a one-off project.
Charles Linquist
According to here PIC16F88 the lowest cost device is $2.20 - if you go here PIC18 Product Family and do a sort on ascending price, you will find about 45 PIC18's that cost less than a PIC16F88. That said, I use several competitive 32-bit devices that are about half that price.
Not sure, but maybe you can just change 1-line.
Depends on what f0 and x are.Code:'---[INT - interrupt handler]--------------------------------------------------- ToggleLED1: cnt = cnt +1 cntb = cnt * 20 ; could be * 1000 meter = DIV32 f0 If meter = x Then meter = 0 km = km + 1 cnt = 0 Endif @ INT_RETURN
If you are looking for costs ... forget all this old 16F... or 18F...-devices.
Take new cheap dsPic33 or ...J... or ...K... -devices.
The new devices are very cheap, the old stuff is expensive !!!!
Not an economic solution but great fun is the 'floating point co-processor' from Micromega. Costs about $20. the free IDE make developing the code a doddle.
Regards Bill Legge
