StickOS
Results 1 to 40 of 104
Thread: StickOS
    Sep 2007
    USA, CA
    I'll take two. More if they come out supercheap.
    Wow! You shouldn't have (but I love it!). Thanks again. I can't wait.
    I will try to look over the board with Diptrace tonight, but doubt I will be able to find anything.
    http://www.scalerobotics.com
    No problemo. I dorked-up the 1st one with the wrong 64-pin TQFP package type anyhow, so I had to change it. The PIC32 we're using is 10x10x1 with 0.5 lead pitch. That just made it even harder to route, but did give up a teeny bit more realestate.
    It needs to fit on a breadboard anyhow since it's not dev-board size, so I spent a few hours changing it around. A 2x8 female header for the analog pins should make it nicer than the 1x16.
    And I went by the datasheet VS the Sparkfun schematic for the VUSB connection (pin #35) to the cap. It's not crystal-clear what they're doing with this pin. It shows ---> with 3.3V just below it. Not sure if they didn't connect this pin or if they ran it to the other 3.3V connections with --->3.3V?
    It could be a LOT smaller with < 0805 components, but it wouldn't be anything I would even consider assembling by hand unless it was just 1 or 2 units. And the price per board would definitely go up, so I'm leaving it at this size.
    I'm going to get in touch with Rich on a clone connector. If I have room, I'll try to squeeze that in too. Then you could connect 2 boards & clone them, but that's a big maybe. If it turns out to be a hot item, I'll make it really small, and probably even ad the wireless, but I'll have someone else assemble them. I just want 1 to mess with to see how it works with the BASIC OS for starters.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I believe that having the board wireless ready (even if the involved parts are not populated) will be a big plus.
    I am also interested on USB host feature (if possible) which might solve the well known problem of depending on FTDI chips and modules as the only source of USB host capability for hobbyists. Grouping these pins and making them available to the user in a USB connector fashion arrangement or any other way will add value to the board at no expense.
    In any case, I just can’t wait to try this new device.
    Nick
    Walter,
    Use this latest version. It's been optimized for a better ground plane, and clearance.
    Nick,
    I may include wireless & USB host in a later version, but not this 1st prototype. But you're welcome to use the existing board file if you like to ad new options. I'm just short on time at present.
    -Bruce
    tech at rentron.com
    Hi Bruce. Very impressive job! Well done!
    To ease things for you, maybe just assemble the smd parts on your pick and place machine, then let us assemble the rest, through hole parts, like a kit.
    I believe this will save you a lot of time.
    Default Pin #35
    It wasn't clear at all to me. I located the source files of the CUI32. Here is a view of how they really have it connected... Following the datasheet sounds like a good idea.
    I looked over the obvious on your pcb, and I can't find any mistakes. Pin6 of the programming header doesn't go anywhere, but you probably knew that.
    Walter
    Thanks Walter. I'm guessing they have the internal Vreg disable, so I changed it.
    This is the final version unless someone notices something wrong. It has a lot of spacing changes, copper pour islands removed, and has passed DRC.
    I'm attaching the BOM, Gerber files, and the final CAD file so anyone can get quotes on boards & component prices if they like, or modify the original design as needed.
    I have a bunch of parts on-hand like resistors, caps, /MCLR diode, etc, and some female headers if people want to use them for the analog pins - so it will save everyone a few bucks. See the notes in the BOM for whatever I have a ton of in stock already.
    For a few parts I've included part #s for Mouser & DigiKey, but everyone's welcome to lookup cheaper parts if they can find them.
    Ioannis,
    Thanks, but my pick & place machine is a pair of SMD tweezers.. That's why I didn't want to go with any parts smaller than 0805 since I'll be placing them all by hand.
    As for the through-hole parts, I don't mind installing the 2 switches, but the headers I'm going to leave to everyone else to install themselves.
    Note: A few manufacturers from China have contacted me asking to quote on PCBs and full assembly of these, so I have attached pretty much all files they'll need to do so. You can contact me directly if you're interested.
    -Bruce
    tech at rentron.com
    Ooh, I see. I thought you had the magic machine...
    In that case why not send the parts and PCB to assemble it? It will save your valuable time. I suppose all we that ordered the StickOS can do this.
    You have done a lot of work on this project and thank you very much for this.
    As for the Chinese, what is their MOQ?
    Bruce,
    I agree with Ioannis. The reason I sent you my four chips is because I thought you had the magic machine. I can do the assembly with my tweezers.
    So if it is any help just bag the stuff for me and let me know what I owe you.
