I have built a simple Ultrasonic distance measurement with a user defined zero setting
and user interface is like a traffic light so Red = Red, Green = Green and Yellow = Green+Red.
I am however scratching my head as I am trying to add a functionality.
As it is presently, I always have One or two LEDs ON but I would like to have all OFF if after 1 minute I detect no change or a change of less than 2 or 3 units.
Note: I calculate the distance by units as I don't really care if a unit is 1 inch, 1 foot or 1 cm but my testing shows that one unit is approx half an inch.
This is my complete code so if anyone can guide me that would be great.
@ __config _XT_OSC & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
Clear
TRISA       = $07
TRISB       = $05
CMCON       = $06
INTCON      = $10
OPTION_REG  = $C0
UserSetting    VAR WORD
Counter        VAR BYTE
SampleValue    VAR WORD
DataA          VAR WORD
RawData        VAR WORD [16]
Upd            VAR BIT
READ 0,WORD UserSetting 	; get user setting
IF UserSetting = 65535 then UserSetting = 0
Counter = 0
SampleValue = 0
Upd = 0
TMR1H = $B1:TMR1L = $E7		; adjust timer1 to 50Hz @ 4MHz Prescale = 1
; -----------------Power on self test sound ---------------------
sound PORTB.1,[90,5,100,5,105,5,90,5,100,5,105,5,90,5,100,5,105,5,90,5,100,5,105,5]
PORTB.5 = 1 : PAUSE 1000           ; Red ON
PORTB.4 = 1 : PAUSE 1000           ; Red and Green ON
PORTB.5 = 0 : PAUSE 1000           ; Green ON
PORTB.4 = 0                        ; all OFF
;---------By Darrel Taylor---------------------------------------
INCLUDE "DT_INTS-14.bas"    ; Base Interrupt System
INCLUDE "ReEnterPBP.bas"    ; Include if using PBP interrupts
        INT_Handler   INT_INT,  _SignalFound,   PBP,  yes
        INT_Handler   TMR1_INT,  _SignalTimeOut,   PBP,  yes
    INT_CREATE              ; Creates the interrupt processor
@   INT_ENABLE  TMR1_INT	; Enable Timer1 Interrupts
@   INT_ENABLE  INT_INT    	; Enable RB0 Interrupts
T1CON.0 = 1                 ; Start timer1
GOTO Main
	IF Upd = 1 THEN GOSUB UpdReading
	IF PORTB.2 = 1 then GOSUB UpdUserSetting
GOTO Main
UpdUserSetting:
@   INT_DISABLE  TMR1_INT	    ; Enable Timer1 Interrupts
@   INT_DISABLE  INT_INT    	; Enable RB0 Interrupts
    pause 10
	WRITE 0,WORD SampleValue    ; Set this distance as Zero distance
    sound PORTB.1,[123,10]      ; Beep
    UserSetting = SampleValue
Debounce:   if PORTB.2 = 1 then  debounce
UpdReading:
	T1CON.0 = 0			     	; Stop timer1
    ; Not in sight so keep the green light on
    IF SampleValue-UserSetting < 50000 AND SampleValue-UserSetting >= 15 then
        PORTB.5 = 1
        PORTB.4 = 0
    ; Getting close so kep green + red light on
    ELSEIF SampleValue-UserSetting < 15 AND SampleValue-UserSetting > 1 then
        PORTB.5 = 1
        PORTB.4 = 1
    ; got there so make the light red
    ELSEIF SampleValue-UserSetting = 1 then
        PORTB.5 = 0
        PORTB.4 = 1
    ; too far, make the red light blink
    ELSEIF SampleValue-UserSetting > 50000 THEN
        PORTB.5 = 0
        toggle PORTB.4
	Upd = 0
'---[INT - interrupt handler]------Signal found at RB0, take a reading
SignalFound:
    T1CON.0 = 0 	                  	 	; Stop timer, Don't send burst during calculations
	RawData(Counter) = TMR1H * 256 + TMR1L	; Add 15 readings to RaData()
	Counter = Counter + 1
	if Counter => 14 then
;------[Sort a list of 15 readings]---By Melanie-----------------------
SortArray:
		Counter = 0
SortLoop:
		If RawData(Counter + 1) < RawData(Counter) then
			DataA = RawData(Counter)
			RawData(Counter) = RawData(Counter + 1)
			RawData(Counter + 1) = DataA
			If Counter > 0 then Counter = Counter - 2
		If Counter < 15 then goto SortLoop
		Upd = 1							; Set flag to read sample
		SampleValue = RawData(7)/100	; Select the middle guy
		For Counter = 0 to 14			; -------------------------------
			RawData(Counter) = 0		; I probably don't need this part
		Next							; -------------------------------
		Counter = 0                    	; Reset counter
@   INT_DISABLE  INT_INT    			; Do not take another reading on RB0 untill
										;    the next burst is sent
@ INT_RETURN
'---[TMR1 - interrupt handler]------TMR1 Overflow, send burst
SignalTimeOut:
	HPWM 1,127,40000			; Send burst DC 50%, 40KHz
    PAUSEUS 200             	; length of burst.
    CCP1CON = 0             	; Stop sending HPWM
    PAUSEUS 500            		; Wait until Tx vibrations stops
@   INT_ENABLE  INT_INT    		; enable RB0 interrupt
@ INT_RETURN
