Jumper to enter setup
Results 1 to 12 of 12
Threaded View
  1. #7
    Wink
    Quote Originally Posted by Bobbo_ZA View Post
    Damm, so what you are sayins is that im out of luck either way? Spose the only way to do it is to bridge the jumper permanenetly and hardcode the ranges for these boards?
    Would be easier you to tell what you want to do with those " jumpers " ... a jumper is someting easily removable ... so, there's something I do not understand here ...
    soft example:
    Jumper is active LOW
    ' check if programming jumper not forgotten ...
     delay = 0
     BUTTON Prog,0,255,0,delay,1,mesurav
    oubli:       ' infinite loop ... jumper MUST be placed ...
     error = 1 ' Blink the led !!!
     PAUSE 50
     error = 0
     PAUSE 50
     GOTO oubli
    ' Measure programming pulses
    Mesurav: 'Measure Forward Max pulse
     Show = 1 ' programming led ON
     Entree = 0
     GOSUB Mes
