Jumper to enter setup
Results 1 to 12 of 12
    Mar 2010
    Default Jumper to enter setup
    Hi Guys,
    Quick question, im using a jumper on a circuit where one side is connected to GPIO.3 and the other via a 1K resistor to +ve, is correct or should I be puling it down to ground rather? (Hope not cause I had boards printed, :-)
    Does anyone have any code examples of how to read if the jumper is on and also when its taken off?
    Thinking something like:
    Jumper var GPIO.4
    if jumper then
    XXXX
    YYYY
    to check if its on and:
    if not jumper then
    ZZZ
    however not sure if this would work or not (marginal sucess in the early testing).
    rob
    You need to either pull the pin high with the resistor (or use internal pull-up,if available) and then short it GND with the jumper OR pull it low with the resistor and short it high with the jumper. The way you have it now leaves the pin floating when the jumper is not in place which makes it highly unreliable.
    As for the code, your first version should be fine but I'm not sure if NOT is a valid operator in PBP.
    If Jumper THEN
    If Jumper = 1 THEN
    If Jumper = 0 THEN
    If ~Jumper THEN   '<---I think this is valid for "not"  ...
    Sep 2005
    Campbell, CA
    If I understand your circuit correctly, you have a resistor to Vcc that you can either connect or not connect to a pin through a jumper - correct? This would mean that if the jumper was in place, it would pull the pin to Vcc, and if the jumper was not installed, the pin would be disconnected.
    If this is the case, you will have trouble reading the state, since an unconnected input pin's voltage state is indeterminate (NOT low). You would be better off connecting the pin directly to GND or Vcc through the resistor, and then use the jumper to connect it to the opposite supply. If you are connected to port B, you could enable weak pull-ups and connect the pin
    directly to GND through the jumper.
    If your circuit is wired as I think it is, you may have to use a technique that I call a "slam-read": That is, make the pin an output and drive it low. Change it immediately to an input and wait one processor cycle (using the
    line "@ nop") then read it. If their is nothing connected to the pin, it will be low on that read (stray capacitiance will keep it low for awhile after the WRITE). If it has a resistor connected and pulling it up, it will be high on that read (since now the resistor will have charged up the stray pin capacitance).
    Charles Linquist
    Mar 2010
    Sorry, attached is the picture. the black circle is the area showing the 2 sets of jumpers connected to GPIO 4 and 5, the red circle is the 0402 SMD 1K resistor. I am using a 12f675/9 as the PIC and I belive they have internal pull-up but im not sure if it would be usefull to pull them up twice?
    Wink
    Hi, Bobbo
    Nice R/C Switch ...
    Your Pic Input always should be connected to one of the supply rails ( via the resistor )
    When I use a jumper ... it's use just is to connect the pin to the other rail ...
    "pin grounded if jumper" is my favourite, but diect logics also usable.
    Never the pin must be floating ( even using the Pullups !!! ) ...
    example of use here:
    http://www.rcgroups.com/forums/showt...light=azlights
    It's also possible to check if jumper connected to VDD , VSS or left apart ( 3 possible states ) ... but, this is a bit tricky ... for the moment.
    Mar 2010
    Damm, so what you are sayins is that im out of luck either way? Spose the only way to do it is to bridge the jumper permanenetly and hardcode the ranges for these boards?
    Wink
    Quote Originally Posted by Bobbo_ZA View Post
    Would be easier you to tell what you want to do with those " jumpers " ... a jumper is someting easily removable ... so, there's something I do not understand here ...
    soft example:
    Jumper is active LOW
    ' check if programming jumper not forgotten ...
     delay = 0
     BUTTON Prog,0,255,0,delay,1,mesurav
    oubli:       ' infinite loop ... jumper MUST be placed ...
     error = 1 ' Blink the led !!!
     PAUSE 50
     error = 0
     PAUSE 50
     GOTO oubli
    ' Measure programming pulses
    Mesurav: 'Measure Forward Max pulse
     Show = 1 ' programming led ON
     Entree = 0
     GOSUB Mes
    Mar 2010
    soft example:
     delay = 0
     PAUSE 50
     error = 0
     PAUSE 50
     GOTO oubli
     Entree = 0
     GOSUB Mes
    Sorry, basically, all the jumper is doing is on boot it the Pic check if it is "on" and then goes into a setup mode to sense the Transmitter stick location.
    What I have done this evening is resolder another board and manged to bridge accross on another PIN (one I had designed onto the same PCB for LED lighting) and got it to work. Its not "pretty" but now functional. I would still like to find a way to use the pins that are now unconnected untill the jumper is installed and then pulled up to +ve.
    Worst case, is there any harm of leaving the pins floating if I am not using them for input or output? would mean I can use these PCBs for now and then fix the design in the next batch I have printed (sounds commercial, :-), not for sale but making some onboard glow / LED light drivers for some mates at the flying field.
