TTY - Teletype Terminal
Results 1 to 27 of 27
    Foxx373's Avatar
    Foxx373 Guest
    Default TTY - Teletype Terminal
    I am new to PicBASIC, and im not too sure how to work this out right now, but i would liek to make a TTY Terminal. TTY is used by deaf people to place calls through a relay operator. TTY Terminals work by using the BAUDOT protocol. There is a set of tones that has to be decoded and turned into characters on an LCD display. Im sure i can figure out how to generate the tones, and place them on an LCD display, but how can i decode Multi-Frequency tones? Any ideas?
    2-3 way... COUNT and PULSEIN. will return you some value to play with for low frequency. Or using interrupts to count exaclty the period of each frequency with internal TIMER/Counter.
    Foxx373's Avatar
    Foxx373 Guest
    Since TTY deals with soundwaves, i was thnking about using the on board Analog-Digital Converter. I just have no idea how to do that. im sure if i use the COUNT or PULSEIN command, i will have to take the sound coming from the headset, make it a digital signal with a simple op amp, or transistor based logic converter, then pass it to the designated input. Does this sound right?
    How do I use interrupts? Liek i said, im really new to PicBASIC, but not to programming.
    without any external of frequency to voltage converter you'll not be able to do it. A/D converter return a valu that correspond to the voltage at a specific input.
    depending of the signal amplitude, a simple capacitor with 2 resistor as voltage divider can do the job too. 10 cents solution
    OR if you want to feel very very safe, using a OP-AMP or Voltage comparator to make the signal as sqaure as a real TTL- CMOS can also be used... i'll prefer that one to avoid some probale odd interrupt causes.
    depending of your PIC look into your datasheet under INTCON register... If you want some code example using interrupt... there's a load of those in the forum. Do a search with interrupt will gives you a bit less result than SEROUT. BUT, i did one example for lamp-dimming. Using interrupt to synchronise on AC power line.
    Click Here
    Dec 2003
    Wichita KS
    Hello Foxx,
    Fox>>I am new to PicBASIC, and im not too sure how to work this out right now, but i would liek to make a TTY Terminal. TTY is used by deaf people to place calls through a relay operator. TTY Terminals work by using the BAUDOT protocol. There is a set of tones that has to be decoded and turned into characters on an LCD display. Im sure i can figure out how to generate the tones, and place them on an LCD display, but how can i decode Multi-Frequency tones? Any ideas?<<
    Ah ha!...My area of field <g>. I was making these in the 1990's with Philips 752's. Then went through a bad divorce. Then 3 years later, ended up becoming deaf myself!
    A couple of things to remember.. TDD does not use Standard RITTY code. It also does not use standard 8/7 bit data exchange.
    I can't remember the exact "tones" it uses. You can use a chip to decode each of the tones (which I did) or possibly use your PIC with PULSE in and timeout. Or maybe use a interupt and measure the time between the pulses.
    If I remember correctly it is a 3 to 1 ration on tones.
    I used a Lookup Table for decoding of the bits.
    You will have a problem for decoding between the two tones. lets say we have the tones "descriminated".
    Using two bytes, you can "shift" the 5 charactoristics into the bytes.
    Dots var byte
    Dash var byte
    Loop:
    Dots =0;
    Dash=0;
    if Tone=true
    if(Tone=low)
    Dots[0]=1
    if(Tone=High)
    Dash[0]=1
    Dots<<1
    Dash<<1
    With this, you have the exact layout of the mark and stop of the 5 bits...representing the letters/numbers. How you look it up in the table is
    up to you...If you need help in this, maybe I can dig up some of my notes from 15 years ago, or give you some ideas to go on.
    One other thought...Most TDD operators can do standard ASCII from your computer. I use my computer modem at work to TDD to certain people.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Foxx373's Avatar
    Foxx373 Guest
    Thats some very helpful info! Thanks a million. I didnt realize there were TTY Tone Decoder chips. Do you have any info on those? I think it would just be easier for me to use the tone decoder chip and process the data through the PIC, instead of making the PIC do all the work. Trying to "Descriminate" the audio levels are gonna be a bit unreliable. I am aware that a computer can be used to dial-in to the Relay Service, but a phone line isnt always available, and all that can be found is a payphone headset.
    Also, any ideas on what i can do about a small keyboard? Ive seen really cheap palm keyboards for 15 bux, think that can be used on a PIC? I would like this thing to be as small as possible, so no full AT keyboards... hummm... unless i build the terminal INTO the keyboard...
    Italy
    Maybe you can use these for debugging purpose.
    CallTTY 1.10
    (See software and schematics)
    http://www.dxsoft.com/en/products/calltty/
    The tool TTY Angel:
    Manual:
    http://www.ciscounitytools.com/HelpFiles/TTYAngel.htm
    Download:
    http://www.ciscounitytools.com/App_TTYAngel.htm
    ActiveX Controls.
    (See Online doc and Trial copy download).
    http://www.tapiex.com/ToneEncoder.htm
    http://www.tapiex.com/PhoneToneDecoder.htm
    Best regards,
    Luciano
    Italy
    More info.
    Best regards,
    Luciano
    Telecommunications devices for the deaf:
    http://www.tutorgig.com/ed/Telecommu...e_for_the_Deaf
    Original TDD devices were called TTYs, derived from teletype, and was
    invented by deaf-physicist Robert Weitbrecht in 1964. Communications
    was through frequency key shifting and single tone, allowing only
    one-way (simplex) communication at once. During the mid- 1970s, portable
    TTYs were developed and was also the time period when the term "TDD" began
    being used, largely by those outside the deaf community. The deaf
    community, interestingly, does not usually use the
    term "TDD", but instead prefer "TTY".
    The original standard used by TDDs is the Baudot code implemented
    asynchronously at either 45.5 or 50 baud, 1 start bit, 5 data bits,
    and 1.5 stop bits. The TDD/TTY standard is generally incompatible
    with standard Hayes-compatible modems. In 1994 the ITU approved
    the V.18 standard, an ASCII full- or half-duplex modulation method
    which has been widely adopted. Computers can, with appropriate software
    and modem, emulate a V.18 TDD. Some voice modems, coupled with
    appropriate software, can now be converted to TDD modems by using a
    software-based decoder for TDD tones.
    TTY FAQ:
    http://www.deafweb.org/tty_faq.htm
    The V.18 standard
    The V.18 standard gives specifications for the
    implementation of text telephones, more commonly
    called TDDs (Telecommunications Devices for the Deaf).
    http://www.dinf.ne.jp/doc/english/Us...96/page169.htm
    http://tap.gallaudet.edu/v18.htm
    ITU Recommendation V.18 specifies interworking with
    the following TTY protocols:
    Baudot @ 45.45 baud (U.S. TTYs).
    Baudot @ 50 baud (used in England, Australia, and some other
    countries; also known as "international" Baudot).
    V.21/text telephone version (used in Sweden, Norway, and Finland).
    DTMF (used in Denmark, Holland, and some other countries).
    EDT ("European Deaf Telephone," used in Germany, Austria,
    Switzerland, and several other countries).
    TWO DSP SOCKET MODEM with V.18 Standard
    (Ask which TTY protocols are supported in their implementation of V.18).
    MODULATIONS of the DSP SOCKET MODEM:
    V.90 (server and client), V.34bis, V.34, V.33, V.32bis, V.32,
    V.29, V.22bis, V.22, V22fast (HYPERCOM compatible), V.23,
    V.21, V.18, Bell 212A, Bell 103
    DSP SOCKET MODEM - SERIAL
    http://www.telindusproducts.com/Tap/...ocketmodem.pdf
    DSP SOCKET MODEM - PARALLEL
    http://www.telindusproducts.com/Tap/...emparallel.pdf
    Radio Teletype (RTTY)
    I am not an expert but RTTY and TTY/TDD are close.
    Maybe you can use ideas from Amateur Radio RTTY circuits.
    (If you use only the Baudot code at speed 45.45 for your project).
    Both TDD and RTTY use five level Baudot/Murray code.
    Baudot table:
    http://burks.brighton.ac.uk/burks/foldoc/76/10.htm
    The first difference I can see:
    In TTY/TDD the “mark” tic is defined as 1400 Hz and
    the “space” tic is defined as 1800 Hz.
    See: "The Protocol Today"
    In RTTY the mark frequency is 2125Hz and the space is 2275Hz.
    RTTY is commonly transmitted at speeds of 45.5 bits per second.
    RTTY is either transmitted in Baudot or ASCII code.
    http://www.roity.com/rc/rtty.html
    TDD devices:
    Non-Printing TTYs:
    http://www.phone-tty.com/PRODUCTS/OLD_PAGES/TTYs.htm
    PocketComm the POCKET TTY:
    http://www.krowntty.com/html/products/pocketcomm.html
    Italy
    Tone Generator and Tone Decoder Integrated Circuits.
    The XR2206 and XR2211 are a versatile pair when it comes to modem building.
    Their advantage is that they may be set to what ever Mark and Space tones
    you like, creating the tone shift desired.
    Example of aplication:
    http://www.klm-tech.com/technicothica/xr.html
    Manufacturer:
    Exar Corporation,
    Fremont California,
    U.S.A.
    http://www.exar.com
    Where to buy:
    http://www.jameco.com
    XR2211 IC = Jameco #: 34999 USD 1.79
    XR2206 IC = Jameco #: 34972 USD 3.59
    Best regards,
    Luciano
  1. Key_in from terminal
    Last Post: - 25th May 2009, 17:15
  2. Hyper Terminal Setting for TTL putput
    By ClayE in forum Serial
    Last Post: - 7th June 2008, 07:50
  3. Tapping data from a Unix VT220 terminal
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2006, 05:47
  4. what is hyper terminal?
    By moud_man in forum mel PIC BASIC Pro
    Last Post: - 27th September 2005, 20:33
  5. USB Terminal
    By Normnet in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 12:51
