Sony IR Remote
Page 1 of 2 12 LastLast
Results 1 to 40 of 41
Thread: Sony IR Remote
    Feb 2010
    Albuquerque
    Default Sony IR Remote
    I am trying to get the PIC to read the command portion of the sony protocol. I checked on the oscilloscope that the signals were correct. I also was able to determine that the PIC was reading the first pulse of the incoming signal but I can not figure out how to get it to return the 7 digit command out the serial pin.
    pulse  var Word
    x      var byte
    signal var word
    ANSEL = %00000000
    Start:
        Pulsin PORTC.3, 0, pulse
        if (pulse < 220) or (pulse > 260) then start
    signal = 0
    x = 1
    Loop:
        pulsin PORTC.3, 0, pulse
        if (pulse > 90) then ADD_X
        READ_IR:
        x = x * 2
        if (x = 255) then start
        serout PORTC.2, 2, [#signal]
        goto loop
    ADD_X:
        signal = signal + x
        goto read_ir
    Bruce had a great example here. http://www.picbasic.co.uk/forum/showthread.php?t=12555
    It is made for a 18F2431 chip.
    Last edited by ScaleRobotics; - 20th July 2010 at 16:53. Reason: wrong chip number
    Feb 2010
    Albuquerque
    Default Confused
    I am only 17 and I have partially self taught myself PICBasicPro. Since I have not taken any engineering courses and I am still in high school I do not understand much. I checked out the example from this http://www.picbasic.co.uk/forum/showthread.php?t=12555. I have never used the CCP module before so I am a little lost. I need this code for a 12f683. I highlighted the parts in red that I do not understand. I need to transmit the the data to a 1 wire serial lcd using serout command not the debug but I dont know how to do that. Please help.
    ' Connections;
    ' IR detector output to PORTA.2 CAP1 input
    ' PORTB.0 ------/\/\/\/----|>|----GND LED on RB0 (for press/release indicator)
    ' PORTC.6 --MAX232---PC serial port RX (to print results)
    DEFINE NO_CLRWDT 1    ' it's disabled in config
    DEFINE LOADER_USED 1
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0    ' 1 = inverted, 0 = true
    NumPulses CON 26       ' total signal states to learn (26 for Sony)
    T1     VAR WORD[NumPulses]
    INDEX  VAR BYTE
    KeyNum VAR BYTE
    SYMBOL Capture = PIR3.1
        CLEAR
        ANSEL0 = 0           ' all digital
        TRISA.2 = 1          ' cap1 input pin (Capture input)
        INTCON = 0           ' interrupts off
        TMR1H = 0            ' clear high byte of TMR5 count
        TMR1L = 0            ' clear low byte
        T1CON = %00000001    ' prescale=1:1, int clock, TMR5=on
        CAP1CON = %01001000  ' auto time base reset, capture on every state change
        Capture = 0
        FOR KeyNum = 0 TO 14   ' learn 15 total button codes
          CAP1CON = %01001000  '      HIGH 0               ' indicate start (user press button)
          Capture = 0          ' clear capture flag before starting
          ' Wait for 1st capture on state-change. Note: We don't care what the 1st capture
          ' value is since it's the beginning high-to-low edge (for IR), and of no significance.
          ' We only want the length of each high & low signal after the falling edge.
          WHILE Capture = 0 : WEND
          Capture = 0
          FOR INDEX = 0 TO NumPulses-1 ' captures IR signal in 1uS increments
            WHILE Capture = 0 : WEND   ' wait for capture event
            Capture = 0                ' clear int flag after each capture
            T1[INDEX] = ((CAP1BUFH<<8) + CAP1BUFL) ' store capture values
          Next INDEX
          CAP1CON = 0 ' disable capture immediately after to avoid unwanted captures
          Capture = 0
                      ' if user holds transmitter button down too long.
          LOW 0       ' indicates user should release transmitter button
          PAUSE 1000
          ' print button codes
          FOR INDEX = 0 TO NumPulses-1 STEP 2
            DEBUG "low = ", DEC T1[INDEX],"uS",13,10   ' print low signal period
            DEBUG "high = ",DEC T1[INDEX+1],"uS",13,10 ' print high signal period
          NEXT INDEX
          DEBUG 10,13
        NEXT KeyNum
    Finished:  ' indicate finished
        TOGGLE 0
        PAUSE 200
        GOTO Finished
    Confused:
    That code is specific to the 18F2431, with features not found in the 16F683.
    Take a look at the code here http://www.rentron.com/PicBasic/IR_Chips.htm by the same author for a better understanding of decoding IR remote signals.
    Feb 2010
    Albuquerque
    Default Still Not Right
    That is one way to do it but I need a simple way to read the Sony protocol. I liked the way this code works because it doesnt require any hardware peripherals. Please help me figure out why this isnt working.
    pulse  var Word
    x      var byte
    signal var word
    ANSEL = %00000000
    Start:
    signal = 0
    x = 1
    Loop:
        READ_IR:
        x = x * 2
        goto loop
    ADD_X:
        signal = signal + x
        goto read_ir
    For one thing, I would take the SEROUT out of your loop: SEROUT takes a fair amount of time, and you will lose any IR pulses after the first while servicing the SEROUT.Save pulses to an array as you capture them, then SEROUT when done with capture.
    Also, the tolerance on this:
    might be a little tight to capture the 240msec AGC pulse at the start. See below.
    From the link I gave you:
    Decode:                             '// Shift right to remove bit RA.0
       H_Add = (PORTA >> 1) & %00011111 '// AND with %00011111 to mask upper 3-bits
                                        '// RA.1 to RA.5 = 5-bit hardware address
    Decode2:
       PULSIN PORTA.7,0,PULSE_IN        '// Read-in start pulse
       IF (PULSE_IN < 200) OR (PULSE_IN = 0) THEN '// Less than Start pulse, then keep looking
        Loops = 0                       '// Reset Loops on idle or key release
        IF LM = 1 THEN Decode           '// If mode = latching, don't change outputs.
        PORTB = 0                       '// Mode = momentary. Key = released or idle
        GOTO Decode                     '// so clear outputs & return.
    Verify:                              '// Read, Decode, then verify data
       FOR Index = 0 TO 12               '// Setup to read-in 13 pulses
        PULSIN PORTA.7,0,IR_PULSE[Index] '// Read 13 low-going pulses on RA.7
       NEXT Index                        '// Loop x times
       DBYTE = $FF                       '// Start with all 1's and find each 0
       FOR Index = 0 TO 7                '// Get 8 "data" bits
        IF IR_PULSE[Index] < 100 THEN DBYTE.0[Index]=0 '// Less than 1mS = 0
       NEXT Index
       ABYTE = $FF           '// Start with all 1's and find each 0 in pattern
       X=0                   '// Initialize address bit index pointer to bit 0
       FOR Index = 8 TO 12   '// Get 5 address bits from IR_PULSE bits 8-12
        IF IR_PULSE[Index] < 100 THEN ABYTE.0[X]=0
        X = X + 1            '// Increment address bit index pointer
       NEXT Index
       ABYTE = ABYTE & %00011111 '// Mask out upper 3-bits. Result = 5-bit address.
    is a good start. ABYTE and DBYTE together give you the 12 bit decoded command.
    SWITZERLAND (french speaking)
    Default PULSIN resolution
    Quote Originally Posted by gmglickman View Post
    @ 4MHz, PULSIN has 10µs resolution.
    If you need to capture 240msec, then you would have:
     if (pulse < 22) or (pulse > 26) then start
    I did something similar and left PULSIN by side - I use TMR1 instead. Have a look to the "code" section here http://home.citycable.ch/flotulopex/...I_Frames_e.htm
    HTH
    Roger
    Feb 2010
    Albuquerque
    Default Timing
    I dont think the timing is off becuase I used a portion of the first code to make shure the range of numbers was correct.
    start:
    high GPIO.2
    low GPIO.2
    goto start
    I think this was the code but I used 220 through 260 and the led would flash every time it detected the ACG pulse. So I dont think the values are incorrect. I just dont know how to excecute the program.
    I would really like to use this code below because I understand it, it's simple and I can do it all in software. If anyone can please tell me what is wrong with this code please let me know.
    pulse  var Word
    x      var byte
    signal var word
    ANSEL = %00000000
    Start:
    signal = 0
    x = 1
    Loop:
        READ_IR:
        x = x * 2
        goto loop
    ADD_X:
        signal = signal + x
        goto read_ir
    Wink Check it
    PULSIN & PULSOUT have the same resolution (10µs @ 4MHz). So, for a test, use PULSOUT.
    Try this small code and check with your oscillo if the pulse you read is really 240ms wide, you may be surprised.
    START:
    PULSOUT PORTC.3, 240
    GOTO START:
    Roger
    One Sony decoder chip comin up..
    This should be easy to understand & modify for your PIC type. And you can easily change it to display buttons like channel-up, down, volume-up, down, etc..
    IR_PULSE VAR BYTE(12) ' IR data received
    INDEX VAR BYTE        ' Index pointer
    DBYTE VAR BYTE        ' IR data received
       PULSIN PORTC.3,0,IR_PULSE         '// Read-in start pulse
       IF (IR_PULSE < 200) OR (IR_PULSE = 0) THEN Main
       FOR Index = 0 TO 11               '// Setup to read-in 12 pulses
        PULSIN PORTC.3,0,IR_PULSE[Index] '// Read 12 low-going pulses on RC.3
       DBYTE = $7F                       '// Start with all 1's and find each 0
       FOR Index = 0 TO 6                '// Get 7 "data" bits
       NEXT Index
       DBYTE = DBYTE + 1                 '// Button code #1 = 0, Button #2 = 1, so add 1
                                         '// for actual button pressed for display
       HSEROUT ["Button pressed was ",#DBYTE,13,10]
       GOTO Main
    This will print buttons #1 through #9. Buttons 0, channel, volume, etc will output the numeric values corresponding to buttons pressed.
    I know you don't care about the device codes like TV, VCR, etc, but it's easier to keep in-synch if you read these in anyway.
    -Bruce
    tech at rentron.com
    Dec 2008
    Ploiesti, ROMANIA
    Wow, Mr.Bruce, amazing job !!! I wonder if it's possible to create code (like this) for using with RC-10 infrared remote from Blaupunkt. I read something about remote with buttons here : http://dren.dk/lacetti-blaupunkt.html, but it' s more interesting to build one infrared remote. In the car that will make the difference ... I read all topics on this forum about IR, and Yours web pages too, but my level of knowledges it's (verry) low...so, if it's possible, every help it's wellcome.
    Something like this might work. I thought I read the signals were repeated every 10ms, but now I can't find that, so I could be wrong about that.
    LED=1
    delay var word
    i var byte
    vol_up:
        delay = 2600
        gosub ir_out
    ir_out:
        for i = 1 to 10 'sends out command 10 times
            led=0
            pauseus delay
            led=1
            pauseus delay
            led=0
            pauseus 660
            led=1
            pause 10    'wait 10ms before repeating
        next i
    Dec 2008
    Ploiesti, ROMANIA
    Thank You for repply ! Since I have on my car Radio-SD card Blaupunkt and I have the sensor (TSOP 34838) too, I intend to try to build one remote (using 12F675 ?!) ; Your code it's a good point to start !
    Dec 2008
    Ploiesti, ROMANIA
    Hope don't disturb if I continue here with "code" for RC10 remote...If necessary please move in separate topic. Thanks.
    It's my (pseudo)code...Any advice it's wellcome !
    ' First variant for RC 10 Blaupunkt remote
    ;           PIC12F675:                    +--U--+
    ;                                    +5V  [     ]  GND
    ;                         key 5 |---/--- >[     ]< ---/---| key 1
    ;                         key 4 |---/--- >[     ]< ---/---| key 2
    ;       pull-up!          key 3 |---/--- >[     ]>--[4K7]-- NPN Transistor, IR LED
    @ DEVICE PIC12F675, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, bod_off
    DEFINE OSC  4
    CMCON=7
    OPTION_REG  = %00000111
    TRISIO  = %00111110
    WPU=%00110111
    ANSEL=0
    but1 var gpio.1
    but2 var gpio.2
    but3 var gpio.3
    but4 var gpio.4
    but5 var gpio.5
    LED  var gpio.0
    GIE  var intcon.7 ' global interrupt enable 1=on ; 0=off
    gpie var intcon.3 'port change interrupt enable 1=0n ; 0=off
    gpif var intcon.0 'port change interrupt flag bit
    GIE=0
    GPIE=1
    IOC.1=1   ' int-on-change for GPIO.1 enabled
    IOC.2=1   ' int-on-change for GPIO.2 enabled
    IOC.3=1   ' int-on-change for GPIO.3 enabled
    IOC.4=1   ' int-on-change for GPIO.4 enabled
    IOC.5=1   ' int-on-change for GPIO.5 enabled
    LED=1
    delay var word
    i var byte
     @ sleep
    if but1=1 then  vol_up
    if but2=1 then  vol_down
    if but3=1 then  btn_up
    if but4=1 then  btn_down
    if but5=1 then  mute
    vol_up:
        delay = 2600
        gosub ir_out
    vol_down:
        delay = 3200
        gosub ir_out
    btn_up:
        delay = 3800
        gosub ir_out
    btn_down:
        delay = 4400
        gosub ir_out
    mute:
        delay = 5000
        gosub ir_out
    GPIF=0  'Clear port change interrupt flag
    Goto Main
    ir_out:
            led=0
            pauseus delay
            led=1
            pauseus delay
            led=0
            pauseus 660
            led=1
        next i
    END         ' of program
    Dec 2008
    Ploiesti, ROMANIA
    Default I think I made some mistakes...
    ...because with the code posted up, ISIS show me this results for "vol_up" like in picture attached ; it's something wrong ?! Thanks for your attention & cooperation !
    Dec 2008
    Ploiesti, ROMANIA
    Default ...me again...
    ...with some modification ; the results are now OK (in simulation, hope in real-world too !).
    TRISIO  = %00111110
    ANSEL=0
    OPTION_REG.7=0
    IOCB=%00111110
    ...and (of course !) ...
    if but1=0 then  vol_up
    if but2=0 then  vol_down
    if but3=0 then  btn_up
    if but4=0 then  btn_down
    if but5=0 then  mute
    ...and at last...
    vol_up:
        delay = 970 '(970 us low + 970 us high + 660 us low = 2600 us pulse total time)
        gosub ir_out
    The results are like in picture; hope testing "in vivo" tomorrow...
    Oct 2007
    The Netherlands
    You should modulate your signal on a carrier of about 38 kHz. You can generate this with assembly or use a pic12f683 and use the internal pwm generator. Then you can modulate this signal by switching the trisio pin.
    I once did it this way:
    It sends a Sony DVD play command every five seconds (as an example)
    @ device  pic12F683, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, protect_off, bod_off
    INCLUDE "MODEDEFS.BAS"
    DEFINE PULSIN_MAX 5000
    GPIO      =       %00100000
    TRISIO    =       %00001100
    CCP1CON   =       %00001100  ' Mode select = PWM
    T2CON     =       %00000100  ' Timer2 ON + 1:1 prescale (last two bits)
    CCPR1L	  =       %00001101  ' pwm duty 50%
    PR2       =       %00011001  ' Set PWM frequency to +/- 40kHz, set to 26 for 38kHz or 28 for 36kHz
    ANSEL     =       %00000000
    CMCON0    =       %00000111
    led       var     GPIO.5
    counter   VAR     BYTE
    counter2  VAR     BYTE
    command   VAR     WORD		                            'IR command to send
    temp      VAR     WORD
    bitcount  VAR     WORD
    bitselector var   word
    rewind    CON     $79A	                                'sony DVD codes for testing
    play      CON     $59A
    postdata  con     $36
    clear
    loop:
       command =  play
       gosub sendIR
       pause 5000
    goto loop
    sendIR:								' send IR code
        for counter = 1 to 5            ' five times
            TRISIO.2 = 0
            PauseUs 2450	            ' Lead_in pulse
        	TRISIO.2 = 1
        	pauseus 450                 ' (space)
            bitcount = 11               ' send first 11 bits
            temp = command
            GoSub transmit
            bitcount = 8                ' send remaining 8 bits
            temp = postdata
            GoSub transmit
            TRISIO.2 = 0
            PauseUs 650	                ' ptrail (pulse)
            TRISIO.2 = 1
            Pauseus 13080
        next counter
    transmit:
    	bitselector = 1 << (bitcount - 1)
            For counter2 = 1 TO bitcount	        'number of bits
    		TRISIO.2 = 0				'make output (pin active, led on)
    		PauseUs 540			        'first part of bit, pulse
                    IF (temp & bitselector) = 0 Then 'if bit is 0
    			PauseUs 580			'send second part of bit ,pulse
    		EndIF
    		TRISIO.2 = 1				'make input (pin inactive, led off)
    		PauseUs 560                              'space (no pulse)
                    temp = temp << 1			'shift one bit
    	Next counter2
    Feb 2010
    Albuquerque
    Smile Got it working
    I finally got the code working but it is very ineffecient. I am only 17 and I came up with the code with only a little help so give me some credit. Its not the best but if any of you have other ways to compress the code and make it more effecient please reply. Thanks
    ANSEL = %00000000
    IR_PULSE    var word(11)
    SIGNAL      var word
    START_PULSE var word
    INDEX       var byte
    X           var byte
        Pulsin PORTC.3, 0, start_pulse
        if (start_pulse < 220) or (start_pulse > 260) then main
        for index = 0 to 11
            pulsin PORTC.3, 0, ir_pulse(index)
        next index
    Convert:
    x = 1
    signal = 0
        for index = 0 to 11
            if (ir_pulse(index) > 90) then ADD_X
            READ_IR:
            x = x * 2
        next index
        serout PORTC.2, 2, [#signal, 9]
        clear
    ADD_X:
        signal = signal + x
        goto read_ir
    Dec 2008
    Ploiesti, ROMANIA
    Quote Originally Posted by eggman View Post
    I intend to build remote using 12F675 (I have a lot...and none of 12F683). How generating a carrier of 39 kHz with assembly ? I found something about 40 kHz pulse on Mr.Bruce site, but...
    Please, one clue ?!
    Pulse: '// Emits # of 39kHz bursts held in variable Cycles
    ASM ;// with auto delay between bursts
    bsf gpio, 0 ;// 1uS, LED=on [need 25uS total ???????
    goto $+1 ;// 3uS (2uS per goto $+1)
    goto $+1 ;// 5uS
    goto $+1 ;// 7uS
    goto $+1 ;// 9uS
    goto $+1 ;// 11uS
    ' goto $+1 ;// 13uS 'comment this for 39 kHz ???
    bcf gpio, 0 ;// 14uS, LED=off
    goto $+1 ;// 16uS
    goto $+1 ;// 18uS
    goto $+1 ;// 20uS
    goto $+1 ;// 22uS
    decfsz _Cycles,F ;// 23uS
    goto _Pulse ;// 25us
    PAUSEUS 500 '// 500uS delay between each data bit
    RETURN '// Return to Main
    ...and next ?
    Dec 2008
    Ploiesti, ROMANIA
    Unhappy ?!?
    I try to simulate this remote using 12F683 (because of PWM) :
    GPIO      =       %00000010
    TRISIO    =       %00000010
    ANSEL     =       %00000000
    CMCON0    =       %00000111
    led   var GPIO.5
    but1 	var GPIO.1
    LED=0
    delay		var word
    i 		var byte
    timeX       var byte
    vol_up:
    	while but1=0
    		gosub ir_out
    		gosub debounce
    	wend
    PAUSE 50
    Goto Main
    ir_out:
            led=1
            pauseus delay
            led=0
            pauseus delay
            led=1
            pauseus 660
            led=0
    Debounce :
    For timeX= 1 to 50
    Pause 5
    next timeX
    END         ' of program
    But the results are similarly ; I really don't understand what I do wrong ...
    Oct 2007
    The Netherlands
    Instead of led = 1 or led = 0 use this: TRISIO.2 = 0 or TRISIO.2 = 1
    You have to connect your IR led to GPIO.2, not GPIO.5
    Toggling TRISIO.2 will modulate your IR led
    Default Use GPIO.2 only
    You may use GPIO.2 (CCP1) only and set the duty-cycle (CCPR1L) to its value for the time you need to generate high pulses.
    Try a 25-30% duty-cycle value, 50% is too high and makes you loose efficiency.
    For a 38kHz carrier, PR2 is 25 which will give you a CCPR1L value of 8 (which is ±30% of "25").
    So, if your pattern would be something like 970µs high, 970µs low and 660µs high, it could look like this:
    set CCPR1L to 8
    pause for 970µs
    set CCPR1L to 0
    pause for 970µs
    set CCPR1L to 8
    pause for 660µs
    set CCPR1L to 0
    Roger
    Dec 2008
    Ploiesti, ROMANIA
    Ok, Thanks ! With 16F648A works (in ISIS ) great.
    But...
    I find in "Experimenting with the PicBasic Pro Compiler" by Les Johnson how to define subroutine "Pulse" ; so, I re-re-x-rewrite code for 12F675. I have some results but I don't understand how define the lenght of pulses. I put "?!" where I don't know if it's right.
    Any advices ?
    '           PIC12F675:                    +--U--+
    '                                    +5V  [     ]  GND
    '                         key 5 |---/--- >[     ]< ---/---| key 1
    '                         key 4 |---/--- >[     ]< ---/---| key 2
    '       pull-up!          key 3 |---/--- >[     ]>--[4K7]-- NPN Transistor, IR LED
    DEFINE OSC  4
    CMCON=7
    OPTION_REG.7=0
    TRISIO  = %00111011
    WPU=%00111011
    IOCB=%00111011
    ANSEL=0
    but1 var gpio.0
    but2 var gpio.1
    LED  var gpio.2
    but3 var gpio.3
    but4 var gpio.4
    but5 var gpio.5
    delay		var word
    BURST		var word
    i 		var byte
    timeX       var byte
    gpie var intcon.3 ' port change interrupt enable 1=0n ; 0=off
    gpif var intcon.0 ' port change interrupt flag bit
    GIE=0
    GPIE=1
     @ sleep
    IF but1=0 then 			; VOLUME UP
        DELAY=37                  ; 970 us/ 26 us each pulse = 37 ?!
        	GOSUB IR_REMOTE
    IF but2=0 then 			; VOLUME DOWN
        DELAY=1270
    	GOSUB IR_REMOTE
    IF but3=0 then 			; BUTTON UP
        DELAY=1570
    	GOSUB IR_REMOTE
    IF but4=0 then 			; BUTTON DOWN
        DELAY=1870
    	GOSUB IR_REMOTE
    IF but5=0 then 			; MUTE
        DELAY=2170
    	GOSUB IR_REMOTE
    PAUSE 50
    Goto Main
    ir_REMOTE:
    FOR BURST=1 TO DELAY
    GOSUB PULSE
    NEXT BURST
    pauseus (delay*26)         '    ?!
    FOR BURST=1 TO 25          ' 660/26 ?!
    GOSUB PULSE
    NEXT BURST
    Pulse:            ' 2+4+8+4+7+1=26 us
    HIGH LED		' Turn on LED (4 cycles)
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP			' each NOP takes 1 instruction cycle
    @ NOP			' assumig 4 MHz
    @ NOP
    @ NOP
    LOW LED           ' turn off the LED (4 cycles)
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    RETURN            ' return from the subroutine (1 cycle)
    END         ' of program
    Dec 2008
    Ploiesti, ROMANIA
    This is my last variant of code; works fine in ISIS, hope to my car too.
    '       Varianta cu ASM from www.rentron.com
    '              Thanks to Mr.Bruce !
    '                                    +5V  [     ]  GND
    @ DEVICE PIC12F675, intrc_osc, wdt_off, pwrt_on, mclr_off, bod_off
    DEFINE OSC  4
    CMCON=7
    OPTION_REG.7=0
    TRISIO  = %00111011
    WPU=%00111011
    IOCB=%00111011
    ANSEL=0
    but1 var gpio.0
    but2 var gpio.1
    LED  var gpio.2
    but3 var gpio.3
    but4 var gpio.4
    but5 var gpio.5
    zecime   CON  3      '// = ( 3 * 25uS) = 0.07 mS burst
    zero     CON 12      '// =( 12 * 25us) = 0.30 mS burst
    unu      CON 24      '// = (24 * 25uS) = 0.60 mS burst
    delay		var word
    i 		var byte
    cycles	var byte
    acycles     var byte
    GIE=0
    GPIE=1
     @ sleep
    acycles= unu + zero + zecime  		' ~ 970 uS
          delay=970
        	GOSUB IR_REMOTE
    acycles= unu + unu + zecime   		' ~ 1270 uS
    	delay= 1270
    	GOSUB IR_REMOTE
    acycles= unu + unu + zero + zecime 		' ~ 1570 uS
          delay = 1570
    	GOSUB IR_REMOTE
    acycles= unu + unu + unu + zecime  		' ~ 1870 uS
          delay = 1870
    	GOSUB IR_REMOTE
    acycles= unu + unu + unu + zero + zecime 	' ~ 2170 uS
          delay = 2170
    	GOSUB IR_REMOTE
    PAUSE 50
    Goto Main
    ir_REMOTE:
    cycles=acycles
    call Pulse
    pauseus  delay
    cycles=zero + zecime     			' ~ 670 uS
    call Pulse
    Pulse:                '// Emits # of 40kHz bursts held in variable Cycles
       bsf gpio, 2        ;// 1uS, LED=on [need 25uS total
       goto $+1           ;// 5uS
       goto $+1           ;// 7uS
       goto $+1           ;// 9uS
       goto $+1           ;// 11uS
       goto $+1           ;// 13uS
       bcf gpio, 2        ;// 14uS, LED=off
       goto $+1           ;// 16uS
       goto $+1           ;// 18uS
       goto $+1           ;// 20uS
       goto $+1           ;// 22uS
    If see obviously mistakes, please tell me. Thank You, all !
    Dec 2008
    Ploiesti, ROMANIA
    Default ...please help !
    " I have not failed. I've just found 10,000 ways that won't work". T.A.Edison
    Code :
    '                                    +5V  [     ]  GND
    DEFINE OSC  4
    CMCON=7
    OPTION_REG.7=0
    GPIO = %00000000        ' All outputs = 0 on boot
    TRISIO  = %00111011
    WPU=%00111011
    IOCB=%00111011
    ANSEL=0
    @ #DEFINE IRTX GPIO  ; Define port to use for IR LED drive
    @ #DEFINE PIN 2      ; Define port pin to use for IR LED
    but1 var gpio.0
    but2 var gpio.1
    but5 var gpio.5
    vplus   	CON  106      '// = ( 106 * 25uS) = 2650 uS burst
    vminus     	CON  130      '// = ( 130 * 25us) = 3250 uS burst
    vmute      	CON  202      '// = ( 202 * 25uS) = 5050 uS burst
    vpuls       CON   27      '// = (  27 * 25uS) =  675 uS burst
    delay		var word
    cycles	var byte
    acycles     var byte
    timeX       var byte
    GIE=0
    GPIE=1
     @ sleep
    acycles = vplus
          delay = 2580
    while but1=0
        	GOSUB IR_REMOTE
    wend
    acycles = vminus
    	delay = 3200
    while but2=0
        	GOSUB IR_REMOTE
    wend
    acycles = vmute
          delay = 5000
    while but5=0
        	GOSUB IR_REMOTE
    wend
    PAUSE 50
    Goto Main
    ir_REMOTE:
    cycles=acycles
    call Pulse
    pauseus  delay
    cycles=vpuls     			' ~ 670 uS
    call Pulse
    PAUSE 500
       bsf IRTX,PIN     ; 1uS, LED=on
       goto $+1         ; + 2uS = 3uS
       goto $+1         ; + 2uS = 5uS
       goto $+1         ; + 2uS = 7uS
       goto $+1         ; + 2uS = 9uS
       goto $+1         ; + 2uS = 11uS
       goto $+1         ; + 2uS = 13uS
       bcf IRTX,PIN     ; 1uS, LED=off
       decfsz _Cycles,f ; + 1uS = 10S
       goto _Pulse      ; + 2uS = 12uS
    Debounce :
    For timeX= 1 to 50
    Pause 5
    next timeX
    Of course, zero result ! Even ISIS say it's ok, my RC Blaupuntk don't react ! I have one original RC 10 remote (and receiver, of course) from one friend; works fine. But, if I try to transmit something with my schematic...zero result ! Any advice, please ?!?
    At this point, it might be a good idea to actually, visually compare the original signal with the one generated by your design. Capture the signals on your PC using the sound card, and open the captured file(s) with Goldwave / Audacity.
    You'd immediately see whether the problem is to do with timing / protocol / logic or amplitude.
    Anand
    Even better if you can afford the Logic from www.saleae.com to analyse digital signals. It saved me many times when trying to copy signals from similar cases.
    Dec 2008
    Ploiesti, ROMANIA
    Default Instead to party for my Birthday....
    I spend time with this "killer" code. Now I discover another strange phenomenon : anything I do, can't generate "train" of pulse.
    Instead generating for 4 times this sequence : high 2650 ,pause 2500, high 660, pause 100
    I have just ONE sequence for about 42.25 mS !!!
    WHY ?!?
    zecime  CON 106    '// = ( 106 * 25uS) = 2650 uS burst
    delay     CON 104
    i 		var byte
    cycles	var byte
    acycles      var byte
        goto ir_send
    Goto Main
    ir_send:
         	cycles=zecime
            acycles=unu
     for i=1 to 4
            call Pulse
            pauseus  delay
            call Pulser
     next i
    Pauseus 100
    Goto main        ' or Return, have no result !
    Pulse:              ' Generate "Cycles" number of 40kHz pulses
       bsf gpio, 2     ; 1uS, LED=on
       bcf gpio, 2     ; 1uS, LED=off
       return           ; Add 2uS for return to caller
    Pulser:              ' Generate "Cycles" number of 40kHz pulses
       decfsz _Acycles,f ; + 1uS = 10S
       goto _Pulser      ; + 2uS = 12uS
    Thanks again for attention !
    Dec 2008
    Ploiesti, ROMANIA
    On first row: original Blaupunkt remote, volume up command.
    On second row : my remote, volume up command.
    Using same sensor (original Blaupunkt).
    Original-work; my-NO !!! I'm stuck, dissapointed, sad...
    Could you attach the 2 wav/mp3 files? I'll open them in a sound editor at my end; couldnt quite see the whole pulse train.
    If this forum doesnt permit audio attachments, you could mail them to me at ardhuru_at_gmail.com.
    Also, some remotes send the same frame twice; does your Blaupunkt need that?
    Anand.
    Dec 2008
    Ploiesti, ROMANIA
    Default Heeeeeelp, please ...:(....
    I try different variant of PBP code; no result.
    I find the example of Mr.Bruce :
      ' IR carrier generator routines. Freq.inc.
      Cycles VAR BYTE    ' Number of carrier cycles
      GOTO OverFreq  ' jump over pulse routines
    _Pulse40
       bcf IRTX,PIN     ; 1uS, LED=on
       goto _Pulse40    ; + 2uS = 12uS
       return           ; Return to caller
    ' Generate "Cycles" number of ~38.4kHz pulses
    _Pulse38
       nop              ; + 1uS = 10uS
       decfsz _Cycles,f ; + 1uS = 11S
       goto _Pulse38    ; + 2uS = 13uS
    OverFreq:
    so I write my program, for the hardware like in schematic ( for now I test just Volume Up) :
    @ DEVICE PIC12F675, intrc_osc, wdt_off, pwrt_off, mclr_off, bod_off
    DEFINE OSC  4
    DEFINE OSCCAL_1K 1          ' Set OSCCAL for 1k -HELPS tuning the crystal for more accurate timing
    @ #define IRTX GPIO  ; Define port to use for IR out
    @ #define PIN 1      ; Define port pin to use for IR out
    INCLUDE "Freq.inc" '
    but  var gpio.5
    GPIO.5=1
    TRISIO.5=1
    GPIO.1 = 1       ' IR LED off   -----|<|----/\/\/\----+5
    TRISIO.1 = 0     ' Output for IR signal
    WPU     = %00111101
      CMCON = 7        ' Comparators disabled
      ANSEL = 0        ' A/D disabled
    Loops VAR BYTE
    if but=0 then
            FOR Loops = 1 TO 10
              Cycles = 102      ' 102 * 26 = 2652 uS
              CALL Pulse38
              Pauseus 2580      ' accurate pause of 2580 uS ?!?
              Cycles = 25       ' 25 * 26 = 650 uS ; maybe must EXACTLY 660 uS - how ?!?
              CALL Pulse38
              pauseus 50000
              pauseus 50000
             Next loops
    GOTO Main
    but, OF COURSE ?!?, no results. Somebody, just one little help ? Please...
    Are you sure your IR LED lights? I mean of course you cannot see it. But with camera or your mobil phone maybe you can see if the LED is lighting.
    Do not trust this very much, since my SONY DSC-W17 does not see any IR at all! So test this first with a known IR transmitter to be sure.
    Dec 2008
    Ploiesti, ROMANIA
    I test the function of my schematic with two phones camera (Nokia & S-E) ; and with InfraX soft too. I capture the signal with TSOP 1738 on serial port, for "original" remote and for "PIC" remote...Works fine...but without results on my RC ! Thanks for support !
    I see a 55us diffrence in the two shots. May be this is the problem.
    Dec 2008
    Ploiesti, ROMANIA
    Default Yes, I know...
    ...and I say in previous post :
              CALL Pulse38
    Suggestions ? Thank You for attention !
    You may very well declare a 1234usec delay but this depends on the accuracy of the System Clock (Crystal resonator or what ever).
    So you may have to trim a little the value of the pauseus to get exactly the time you want.
    In general IR systems I eel are able to tolerate such skews...
    Dec 2008
    Ploiesti, ROMANIA
    Default YES ! Finally I have results !
    After thousands of re-writing this code, I've got finally results :
    @ DEVICE PIC12F675, INTRC_OSC_NOCLKOUT, wdt_off, pwrt_off, mclr_off, bod_off
    @ #define PIN 1         ; Define port pin for IR out
     Puls_a         CON 112  ' 112 x 26uS = 2912 mS ( pulse with carrier ON)
    InterPulse  CON 2800 ' 2.80mS (delay between pulses with carrier OFF)
    Puls_b        CON 28   ' 28 x 26uS = 728 uS   ( pulse with carrier ON)
    X        VAR BYTE ' Data bit loop counter & bit index pointer
    Duration VAR BYTE ' Duration of button press
    Loops    VAR BYTE ' Loop count
    Cycles   VAR BYTE BANK0 SYSTEM' Number of carrier cycles to generate
    trisio=%11111101
    option_reg.7=0
    wpu	=%11111101
    but  var gpio.5
        GOTO Main       ' Jump over pulse routine to Main
    ASM                 ; Keep this routine in code page 1, and jump over to Main
       	BSF	IRTX,PIN		      ; 1 MAKE IR HIGH 35% Duty cycle = 9 uS
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	BCF	IRTX,PIN		      ; 1 MAKE IR LOW 17 uS
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	GOTO	$+1
    	DECFSZ	Cycles,F
    	GOTO	_Pulse	      ; 2    26 uS
       return           ' Return to caller
    Duration = 2    ' Send it twice
    IF BUT=0 THEN
    For Duration = 1 to 2
            Cycles = Synch         ' carrier on
            Call Puls_a             ' Send pulse
            PAUSEUS InterPulse    ' Pause (carrier off)
            Cycles = Logic0        ' carrier on
            Call Puls_b             ' Send pulse
    		Pauseus 50000
    		Pauseus 50000
    Next Duration
        GOTO Main                  ' Return for more
    This is command for Volume Up only ; instead 102 cycles * 26 uS = 2650 uS, I put 112 * 26 = 2912, etc. So, the lenght of one pulse is 23.5 uS ?! Maybe with this PIC... Anyway, it's good to see that working, after hard work... Thank You all for support; every advice it's further wellcome !
    It seems that the internal RC oscilator is not precise at least for the receiver you use.
    It cannot tolerate small differencies of the transmission pulse width.
    Either use a crystal oscillator or trim your delays so that they get precisely the value needed.
    Dec 2008
    Ploiesti, ROMANIA
    Using PIC 16F628A I build this remote-by-wire for my Blaupunkt Radio-SD Card. Work verry fine... even it's simple and can be improved.
    ; Simple Remote-by-wire for Blaupunkt ; use RC10 protocol
    @ DEVICE pic16F628A, XT_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
    DEFINE  OSC 4      ; USE 4 MHz crystal
    TRISA= %00000000
    TRISB= %00011111
    CMCON=7
    TO_BLAU VAR PORTA.0
    TO_BLAU = 1
    PULSA	VAR WORD
    PULSB	VAR WORD
    I	VAR BYTE
    DELAYS  CON 660
    MAIN :
    PAUSE 500
        	IF PORTB.0 = 0 THEN        'volume +
        	PULSA=2650
        	PULSB=2580
        	GOSUB PULSE
    	IF PORTB.1 = 0 THEN        'volume -
    	PULSA = 3250
    	PULSB = 3200
    	GOSUB PULSE
    	IF PORTB.2 = 0 THEN        'mute
        	PULSA = 5050
        	PULSB = 5000
    	GOSUB PULSE
        	IF PORTB.3 = 0 THEN        'SRC aka Source
    	PULSA = 6875
    	PULSB = 6850
        	GOSUB PULSE
        	IF PORTB.4 = 0 THEN        'Next aka Right
    	PULSA = 5660
    	PULSB = 5630
        	GOSUB PULSE
    GOTO MAIN
    ;SUBROUTINE
    PULSE:
    	FOR I = 1 TO 10
    		LOW TO_BLAU
    		PAUSEUS PULSA
    		HIGH TO_BLAU
    		PAUSEUS PULSB
    		LOW TO_BLAU
    		PAUSEUS DELAYS
    		HIGH TO_BLAU
    		PAUSEUS 50000
    		PAUSEUS 50000
    	NEXT I
    Default without carrier, poor efficiency
    Hi fratello,
    Quote Originally Posted by fratello
    Using PIC 16F628A I build this remote-by-wire for my Blaupunkt...
    Did you change your mind? No IR anymore?
    If I'm wrong and you still want to go for wireless, then you can improve a few points.
    You should modulate your signal on a carrier of about 38 kHz...
    Ignoring the use of a carrier frequency will make you very frustrated because of the very poor efficiency of your remote.
    You can simply use the PWM module and PORTB.3 to do this; nothing else is necessary (not even assembly). The trick using PWM is to switch ON (set a value) and OFF (set to zero) the duty-cycle for the time of the HIGH and LOW pulses
    OR have a look here if you want to make it another way (adding external components): http://www.rentron.com/Infrared_Communication.htm
    According to you schema, you need to "switch ON" permanently your circuit to be able to use it. What if you forget to switch it OFF during a few days? You may need to add a "soft-switch". A soft-switch will combine your buttons as command and power-switch; a simple search will help you.
    Roger
