16/32 bits PIC support in PBP?
Results 1 to 11 of 11
    Actually, i've just discovered the PIC18F97J60, it seems to have enough IO/ports etc...
    I'm also impressed that it has a direct memory bus...
    Having to use everything at 3.3V is going to be annoying... but i'll make it work...
    I also have the 'fun' of re-visiting the TCP/IP stack and OSI layers from a none microsoft, none Linux point of view... Completely from scratch, none of the crap that comes 'pre-installed'...
    Although, what the hell is a TQFP? I know QFP, it's like PLCC with pins on all 4 sides (according to my PCB software)... TQFP????
    comwarrior, Thin Quad Flat Pac....
    Aug 2003
    I doubt PBP will ever support anything in the 16/32 bit devices for the reasons posted above.
    You can't write for them directly in assembler with MPLAB,
    so how could a high level language that compiles to assembler be of any use?
    I can't see a version of PBP ever existing that compiles BASIC to C code for these devices,
    it would just be plain silly because they are both fairly high level languages, and C is far superior.
    The apparent lack of awareness of exactly what is being missed out on is rather unfortunate.
    On the other hand I think there will always be reasons to upgrade PBP to later versions.
    The way it compiles your basic code to asm can always be improved upon,
    and new features can always be added for the chips it does support.
    I don't see much of a long term future for PBP with the way Microchip is going though.
    Having just started with a dsPic, I can recommend Micrchip's C-30 compiler.
    When the free trial expires, all you lose are the code optimisation features that reduce
    the program memory consumed by your program, etc.
    Not too bad for a free product that would otherwise cost close to $500.
    Talking no 16 and 32 bits assemblers ... joking' I hope ...
    Hi, Art,
    I won't be so sure ...
    What are MPLAB ASM30 and ASM 32 , for you ???
    Have a look to the relevant chapters in MPLAB HELP ...
    one example for ASM32:
    #include
    </PRE>
    </PRE>
    # main routine
    </PRE>
    </PRE>
    .text
    </PRE>
    .set noreorder
    </PRE>
    .ent main
    </PRE>
    </PRE>
    # Do something here
    </PRE>
    nop
    </PRE>
    # Infinite loop
    </PRE>
    1:
    </PRE>
    b 1b
    </PRE>
    nop
    </PRE>
    .end main
    </PRE>
    .globl main
    </PRE>
    Aug 2003
    Ah, well I stand corrected.
    Maybe I just made that assumption because I see no transitional asm file on the way from C code to hex file
    when I compile a C-30 project. A member here recently prompted me to check.
    The question is do the asm30 and asm32 products cost money that would have to be spent
    in addition to the PBP compiler that supported them (if it ever did exist) ?
    May 2007
    The question is do the asm30 and asm32 products cost money that would have to be spent in addition to the PBP compiler that supported them (if it ever did exist) ?
    I am not aware of MC ever charging for the use MPASM so my guess is that the same would apply to MPASM30 and MPASM32. The products are copyrighted by MC but since they are useable only with the copyright owners products, I don't think that there is an issue here. It is the same with other manufacturers AFAIK.
