I use DT_INTERRUPT whenever I need to use interrupts. Having no knowledge of ASM, I find it much easier. I have always used it for 12F635. Recently I have tried to use DT_INT on 16F690 & 16F676 for one of my projects, but I failed to get results. I made sure I have right settings in DT_INT file and Re-Enter file.
1) FOR 16F690 I used
wsave       var byte    $70 ; in DT_INTS-14 file
& none of the Temp (T1,T2,T3,T4) variables where commented out.
Few lines from the code are the following which are not working to begin with:
Include "modedefs.bas"
INCLUDE "DT_INTS-14.bas"
INCLUDE "ReEnterPBP.bas"
@ __Config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BOR_ON & _CP_ON & _CPD_ON & _IESO_OFF & _FCMEN_ON
PAUSE 50
ANSEL=0
ANSELH=0
CM1CON0 = 0
CM2CON0 = 0
OPTION_REG=128
PORTB=0
PORTC = 0
PORTA = 0
TRISA = %001000
TRISC = 0
TRISB =0
 		      INT_Handler   TMR1_INT,  	  _CHECK,   PBP,  yes
T1CON=$E1
@ INT_ENABLE 	TMR1_INT
while 1
FOR W1=1 TO 10
TOGGLE PIN13
PAUSE 100
NEXT W1
FOR W1=1 TO 5
TOGGLE PIN13
PAUSE 1000
NEXT W1
wend
CHECK:
TOGGLE PIN11
@ INT_RETURN
PIC (690) does not responds to anything. When I use 676 then Pin11 on the PIC blinks couple of times and then stops and just glows continuesly along with pin13. Seems to me that wether DT_INTS are for selected PICs only or is there something I need to add/delete from the code to make it work on 676 & 690.
Has anyone else had issues with DT_INT for these PICs. I am looking forward to try them on 16F877A. Are there any known reliability issues with 877A?
