Capturing Text File in Hyperterminal
Results 1 to 5 of 5
    Feb 2005
    Indiana
    Default Capturing Text File in Hyperterminal
    I'm using Hyperterminal to receive and display data using:
    Hserout ["Value=",DEC adval,10,13] which works fine, I get the A/D value "adval" and I get the linefeed and carriage return using the 10,13 operators.
    When I select the "Capture" to text file function from within Hyperterminal,
    and stop and open the file to view, I have received the data in the following format Value=1501 Value=1501 etc. There are two blank/black(squares) characters between the repeating text and data display, no line feed or carrage return as I would expect. Any thoughts?
    John
    JRudd
    John,
    What are you using to view the text file?
    Some programs expect to see the carriage return first.
    (13,10) instead of (10,13).
    Darrel
    Feb 2005
    Indiana
    Darrel,
    Thanks, I used 10,13 because that is the sequence I amusing to run a 16x2 LCD and displaying the same data that I wanted to capture in a text file using Hyperterminal. The next thing I want to do is run a VB program to display a/d input values.
    I'll try 13,10 this evening.
    John
    JRudd
    Italy
    Try with a serial modem.
    TYPE:
    ati3
    (+ press enter key)
    The modem will send you back its model number and sw version.
    Example:
    ati3
    SupraExpress 56e Memory s1.00-052099b
    OK
    In the captured file at the end of the lines you will see 0D 0A.
    Luciano
    If you have VB6 & SoftWire, you an make your own terminal program & A/D logging applicaion.
    Here's one with a strip chart, analog meter & a few more bells & whistles with the VB & PBP source code http://www.rentron.com/PicBasic/AD_Log.htm
    If you don't have SoftWire you can download if free of charge here http://www.softwire.com/swdownload/softwiredownload.htm
    -Bruce
    tech at rentron.com
  1. load .hex file in PIC with hyperterminal
    By irenuska23 in forum General
    Last Post: - 1st September 2009, 10:52
  2. The ultimate include file
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 26th January 2007, 20:35
  3. Help with sending text file from pic
    By isaac in forum Serial
    Last Post: - 15th August 2006, 21:01
  4. Capturing Information on the hyperterminal
    By moramlik in forum General
    Last Post: - 17th August 2005, 12:52
  5. Writing serial data to text file
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2005, 23:09
