Here is my code:
I have to try many times by disconnecting/reconnecting the USB cable so that my board come to Green LED (Ready). 95% of times there is an error message. I am unable to do anything smoothly using this board, I do not know if I am doing somethign wrong or the board is faulty.Code:Include "modedefs.bas" INCLUDE "DT_INTS-14.bas" ' Base Interrupt System INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts DEFINE NO_CLRWDT 1 DEFINE OSC 4 ' OSCCON defaults to 4MHz on reset @ __CONFIG _XT_OSC & _WDT_OFF & _PWRTE_ON & _CP_ALL & _BODEN_ON & _CPD_ON PAUSE 100 LED VAR PORTB.6 F1 var Bit F2 var Bit F3 var Bit S1 var bit S2 var bit S3 var bit i var byte DEFINE DEBUG_REG PORTB DEFINE DEBUG_BIT 7 DEFINE DEBUG_BAUD 2400 DEFINE DEBUG_MODE 1 DEFINE DEBUGIN_REG PORTA DEFINE DEBUGIN_BIT 0 DEFINE DEBUGIN_MODE 1 PAUSE 50 ADCON1=7 CMCON=7 OPTION_REG=%10000111 TRISA=%000001 PORTA=0 TRISE=%000 PORTE=0 TRISB=%00000000 PORTB=0 TRISC=%00001111 PORTC=0 TRISD=%00000011 PORTD=0 CCP1CON=0 @ ERRORLEVEL -306 F1=0 : F2=0 : F3=0 : S1=0 : S2=0 : S3=0 main: high LED: LED=1 : PAUSE 2000 ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR1_INT, _ToggleLEDF, PBP, yes INT_Handler TMR0_INT, _ToggleLEDS, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM T1CON = $31 ; Prescaler = 8, TMR1ON @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts @ INT_ENABLE TMR0_INT ; enable Timer 1 interrupts' while 1 Start: M1A: If PortC.0=0 then mmm: for i=1 to 30 DEBUG "MT3",2,10 Pause 10 next i M1S: DEBUGIN 3000,mmm,[WAIT("MT3",2,"S")] F1=1 : PAUSE 1500 DEBUGIN [WAIT("MT3",2,"C")] F1=0 : S1=1 : PAUSE 1500 endif M1D: If PortC.1=0 then mm: for i=1 to 30 DEBUG "MT3",2,"D" Pause 10 next i DEBUGIN 3000, mm,[WAIT("MT3",2,"D")] F1=0 : S1=0 : PortA.0=0 : PAUSE 1000 endif wend '---[TMR1 - interrupt handler]-------------------------------------------------- ToggleLEDF: If F1=1 then Toggle PortD.2 If F2=1 then Toggle PortD.3 If F3=1 then Toggle PortC.4 @ INT_RETURN '---[TMR2 - interrupt handler]-------------------------------------------------- ToggleLEDS: TOGGLE LED If S1=1 then Toggle PortD.2 If S2=1 then Toggle PortD.3 If S3=1 then Toggle PortC.4' pause 100 @ INT_RETURN
I am now trying to upload this code and errors is "Target Device does not match the selected device", even though 16F877A is selected on Programmer window.
Also with the ones I programmed before - My LED does not GLOW for 2 seconds when the code starts. PIC seems to keep resetting itself - The reason is that the LED starts flickering.
I am not programming the PIC while it is in its circuit. I am using the 40PIN connector with the USB programmer.
But First thing first, please help me solve the programming board problem, so I can firstly start programming smoothly. I have attached the programmer settings screenshot. Please let me if any more information is needed. Thanks a lot.
