Grayscale values are 12-bits, and you need to send 16 of those values before latching the data, for a total of 192 bits.
The code in the attachment is sending 1,536 bits (16*12*8).
And the method you showed in post #1 would only send 128 (16*8).
And your variable sizes aren't right. fade is a BYTE array, and can't hold 12-bit values. data1 is also a BYTE array, but you're using it like a WORD variable.
I think something like this will work better ...
fade var WORD[16]
TempW var WORD
setGreys:
for z = 0 to 15
TempW = fade(z)
shiftout ser, sclk, 1, [TempW\12]
next z
high xlat
low xlat
Then you could ...
RampCount var WORD
ChanCount var BYTE
RampUP:
FOR RampCount = 0 to 4088 STEP 8
FOR ChanCount = 0 to 15
fade(ChanCount) = RampCount
NEXT ChanCount
GOSUB setGreys
PAUSE 50
NEXT RampCount
RampDN:
FOR RampCount = 4088 to 0 STEP -8
NEXT ChanCount
GOSUB setGreys
PAUSE 50
NEXT RampCount
Dot correction values are 6-bits. 16 of those would total 96-bits.
